Change Struts, Change Springs?
Old Mar 22, 2006 | 04:50 AM
qballjr13's Avatar
Hey guys, I am bringing my car in to have them check the struts, I think they are gone. Now unfortunately I have the extended warranty, so If they are gone they will be covered, so between that and my 5 month old it means no aftermarket setups for me. My question is, if the struts and shocks get replaced should the springs be replaced too? Or is it all considered one "setup", shocks/struts and springs? Obviously is the springs are overly worn or damaged that they have to be replaced, but if no visible damage should the dealer replace the springs too? Anyone have any opninions?
Old Mar 22, 2006 | 04:54 AM
Progress's Avatar
It's business time.
Springs rarely fail. Unless you go after market, just save your money and keep the ones you have on there. Dealer will NOT replace those unless they are malfunctioning.
Old Mar 22, 2006 | 05:03 AM
qballjr13's Avatar
Thats what I figured but when dealing with the stealership I like to know the answer before I ask the question!
Old Mar 22, 2006 | 05:56 AM
Puppetmaster's Avatar
Like already said, there's no need to change the springs.
Old Mar 22, 2006 | 06:17 AM
Gapp's Avatar
F the stealership-get yourself some Illuminas/lowering springs. You can get a nice set up for less than $550.00 shipped!!
Old Mar 22, 2006 | 06:18 AM
Well, that's good and all, but he did say that his struts were being replaced under warranty and he has a kid that he doesn't want to subject to an aftermarket ride.
Old Mar 22, 2006 | 06:25 AM
Swisscheese's Avatar
If you need replacement springs, I have a used set for $50 + shipping, but you would probably not need them. Although there are some very similar aftermarket rides to stock(H&R + illuminas) it could run you about $600 and that is if you install it yourself, dealership charges another $375.
They most likely will not replace the springs, the shocks come as one piece with nothing mounted on them. They would re-use your springs and top-hat etc.
Old Mar 22, 2006 | 08:56 AM
super6's Avatar
i dont think they will repalce the shoks for u even under extended warantee, id expect that to be a maintnence item, like brakes. if they do great! if not go for tokico blues, cheap (about $325) and better than stock, for which dealer will charge about $550-600.
Old Mar 22, 2006 | 09:49 AM
Lontar1's Avatar
Puerto Rico-Maxima Lover
no need but while you are at it... not a bad idea...
Old Mar 22, 2006 | 10:14 AM
qballjr13's Avatar
Its not that I dont want to subject my kid to the ride, its the fact she takes ALL my money...kids are damn expensive! I know for a fact my front struts are covered but I am not sure if they will do the back shocks. I guess it depends on their attitude when they look at my car.
Old Mar 22, 2006 | 01:33 PM
Sasquatch's Avatar
Swisscheese,
Do you still have the springs? I'm looking for a little bit stiffer ride and less sagging in the back of my I30 and was told Maxima springs will help.
I would PM you but I can only reply to posts at this time.
"If you need replacement springs, I have a used set for $50 + shipping, but you would probably not need them."
Old Mar 22, 2006 | 01:35 PM
Originally Posted by Sasquatch
Swisscheese,
I believe he is still selling them in the 5th Gen Classifieds forum, as are several others. I would just check there.
Old Mar 22, 2006 | 05:14 PM
Sasquatch's Avatar
Thanks Puppetmaster
matts95max
Apr 23, 2025 10:44 AM
BkGreen97
Apr 2, 2016 05:47 AM
dvcamp
Sep 18, 2015 10:17 AM
Johnny9595
Sep 3, 2015 05:18 AM
