FSTB install link help request
Old Mar 27, 2006 | 12:36 PM
1MaXXfan's Avatar
Its been awhile and a lot of new faces here, good to see.
To the matter, the How to link on the sticky thread now leads to a dead link.
Its warming up and after all the nonsense of my local dealer I'm rolling up the sleeves again to do some work of my own.
FSTB with pics would be great, the concept is easy, but just want to do my homework as I haven't done this stuff in the last 3 years and would like to avoid "dumb" problems.
:attention
Thx
Old Mar 27, 2006 | 12:46 PM
NisMoN00B's Avatar
+Cru OG
Step 1: Park car in level surface
Step 2: Unscrew strut bolts
Step 3: Install FSTB according to instructions. If hitting IM, remove FSTB and place (1) 3/8" flat washer on each tower bolt, re-install FSTB. Check Clearance on IM and Hood.
Step 4: Using a torque wrench, tighten each tower bolt to 35-40 lb/ft.
Step 5: Recheck Clearance.
Step 6: Admire the bling.
Pretty much a "rough" guide.
Old Mar 27, 2006 | 12:49 PM
Puppetmaster's Avatar
No known write-up, but its pretty simple as he said^.
Here's how I describe it:
Just remove the 3 strut upper mount nuts on each side, put the FSTB brackets over, secure the bracket down lightly with the nuts, adjust the screws in the bar so that you can fit it in with the brackets flat on the strut tower, and then torque the 6 nuts to 39-54 N-m.
Old Mar 27, 2006 | 12:50 PM
MaxBoost925's Avatar
Drug Money
Originally Posted by Puppetmaster
No known write-up, but its pretty simple.
That's not true.
There is a writeup on VQPower.com but the thing is the site is hacked by russians (according to my russian friend).
Old Mar 28, 2006 | 07:53 AM
1MaXXfan's Avatar
Thanks for the details and the torque specs, that part I would have had fun looking for. Appreciate it. BTW this is still the best forum around.
Old Mar 28, 2006 | 07:58 AM
naxray's Avatar
this link is from the stickies:
http://forums.maxima.org/showpost.ph...8&postcount=98
Old Mar 28, 2006 | 08:13 AM
DJ2Max's Avatar
one method some people use is to jack the front up so that the pressure is even on both sides once the bar is on. personally i just threw the damn hthing on.
MaxLife17
Jun 27, 2019 01:37 PM
minsbang
Sep 5, 2015 05:36 AM
TheMafia
Sep 4, 2015 08:26 AM
mikebla
Sep 3, 2015 05:37 PM
Johnny9595
Sep 3, 2015 05:18 AM
