Oil in Intake Plenum??
Old Mar 27, 2006 | 03:34 PM
foodmanry's Avatar
Da Roller Coaster!
I was checking into my VIAS today and found a good amount of oil residue in the cup. I investigated further removing the intake plunum (what a b!tch) and found a lot of oil inside the plenum. Obviously there was oil on the VIAS power valve. See pictures below...
Is this normal for a 2k with 125,000 miles on it? Also what should I use to clean the plenum and power valve? They are both made of plastic and I don't want to use a solvent that will eat away at it, any suggestions?
Should I consider removing my intake manifold to check and clean as well? The plenum was the b!tch to remove, the manifold does not look that difficult.
Old Mar 27, 2006 | 04:17 PM
NmexMAX's Avatar
dot dot dot ...
Both my Maximas look that way.
Old Mar 27, 2006 | 04:55 PM
kcowden's Avatar
might want to consider a catch can to capture some of that oil blow by. Not sure what to use to clean it... mabye some sea foam... You've probably taken apart the hard part, may as well take it as far down as your comfortable with. Good luck and let us know how it goes.
Old Mar 27, 2006 | 04:56 PM
MaxBoost925's Avatar
Drug Money
Irish's catch can FTW!
Old Mar 27, 2006 | 07:00 PM
steven88's Avatar
Need A Light?
Oil catch can is your best friend...
Seafoam is also your best friend....FTMFW
Old Mar 27, 2006 | 08:59 PM
upstatemax's Avatar
Does not help that you are a 2000 with an EGR also, between the blowby and EGR you will get a ton of "gunk" built up in your intake. When I took mine off last, I cleaned it all out and it was gross.
Old Mar 27, 2006 | 09:01 PM
Drug Money
well i have yet to look in that disgusting pit.
Old Mar 27, 2006 | 09:15 PM
steven88's Avatar
Need A Light?
Do cali spec 1999-2000 maxes have EGR? Cuz Supposedly 2001 don't have EGRs even tho they VQ30s
Old Mar 27, 2006 | 09:16 PM
Drug Money
I believe you're correct
Old Mar 28, 2006 | 10:02 AM
foodmanry's Avatar
Da Roller Coaster!
Well...I ended up using brake cleaner (all I had last night) and got it by hand with a rag as best I could. I ended up not taking the valve covers off, I already made the project a bigger issue than I had anticipated.
It was weird as I was cleaning it I felt a good amount of silt/soot. Could it be my K&N filter is not doing the job? I am going to order an Apexi filter just in case and slap that on there.
And the real b!tch...I dropped by VIAS spring down in my engine bay somewhere and I cannot find it!!! You can't order just the spring from Nissan so now I have to either find the old spring, or get a substitute. Does anyone know some specs on the spring by chance to where I can get a substitute?
DAMN....
Old Mar 28, 2006 | 10:24 AM
foodmanry's Avatar
Da Roller Coaster!
Ok...does anyone have any picture of their VIAS spring? I need to check it and compare it to something at the hardware store. Or does anyone have any specs for it at all?
Old Mar 28, 2006 | 11:07 AM
Larrio's Avatar
The Definitive AE Master
IMO, the oil helps to lubricate the power valve inside the runners cut into the intake chambers.
Although mine doesn't look anywhere as close as that because I don't have EGR
Old Mar 28, 2006 | 05:22 PM
upstatemax's Avatar
Cali spec 2000's have EGR's, they dont have them in the 01's.
user 11122324
42
Jul 18, 2022 03:35 PM
Fbana41
Aug 29, 2016 12:18 PM
VQ'ed
Forced Induction
Feb 29, 2016 08:05 AM
bumpypickle
Sep 19, 2015 01:07 AM
