01 se needle gauge help!
Old 03-28-2006 | 08:47 AM
makaveli3004's Avatar
Hey i took apart my gauge cluster to install indiglo gauges but they didnt fit and i went to put the stock back on and my needles wont go back to normal. This is a picture of what they look like in accessory mode w/o the engine on. how do you fix this.
Old 03-28-2006 | 08:50 AM
Larrio's Avatar
The Definitive AE Master
unfortunately the spring holding the needles in place are terribly easy to break. However, I recall on a 4th gen I worked on the needle reset itself on the stopper after a few days of driving.
Old 03-28-2006 | 01:41 PM
EdgeX's Avatar
Did you calibrate the needles before you took them apart?
if you calibrate the needles before you disasseble, it gives you a guarunteed spot to point the needles to when you are done putting them back together, if you did not do that, you may have permanently damaged them.
however if all the neeldes still move, it may possibly reset after a few days driving, unfortunately in my case it didnt and I was forced to buy a new cluster
best of luck man
Old 03-28-2006 | 01:49 PM
irish44j's Avatar
retired moderator
call daveb for a new gauge cluster...
Miket2006
03-01-2021 04:55 AM
captchaos
03-15-2016 01:18 PM
220k+ A32
18
09-22-2015 12:39 PM
RWCreative
09-21-2015 12:01 PM
kadespraggins
09-14-2015 01:04 AM
