Exhaust Stinks
Exhaust Stinks
Does anyone else's exhaust stink when they floor it?? Mine smells awful, kinda eggy. It only does it once in a while, when it does my car doesn't pick up as fast. Anybody have any clues or same problems?
Its your main catalytic converter. Need to get it replaced. If you are under 80,000 miles you will fall under the federal warranty and can have the dealer replace it for free.
As far as not picking up fast, that may be a separate issue, but get the main cat replaced and see how it performs after.
I had a feeling it was my cat but was unsure. Would cause the ses to come on? Mine didn't come on, just curios.Yeah i'm under 80,000 miles, i'll probably take it in sometime next week. Thanks.
Originally Posted by MaxBoost925
I have a straight cat on my car. It only stinks if i leave it in idle and smell the muffler outlet.
to the question, my exhaust smelled really bad when i first put on my new exhaust. is your exhaust new or is it still oem? cause i know new exhaust smells bad for like a week or 2
hey maxboost925, check this out
you----->
<-----Me
Originally Posted by steven88
you actually dont have a straight cat....you have a custom enterprize straight pipe
you----->
<-----Me
you----->
<-----Me
That's so 007.
It's straight enough!
Originally Posted by qballjr13
This is WRONG! My 2004 4-Runner does the same thing and it deffinitly did not fail emission. Toyota actually has a TSB fix for it. BUT it does depend on the brand of gas you use. If I put Shell in it, it stinks really bad. If I use Mobile it doesnt smell at all. But there should be no connection between the smell and failing emission.
Hit me back in about 50,000 miles when your main cat has failed. BTW...what is the Toyota TSB fix? New cat? Hmm....
Jacka*s..."rotten egg" odor is a tell-tale sign that your main catylst has failed or is on its way to failing. Sure the type of gas you use may have an effect on how fast it will fail.
NewMAx, what brand of gas do you use?
Easy killer! Actually no the TSB is flush of some sort and I will post the link to the forum (but the site is down right now so I cant get on). But you were saying that if it smells than your cat is already gone. What I am saying is that mine smells (depending on the brand of gas that I use) and I still just passed emission in Mass, which the second hardest to pass next to Cali. emissions. So I dont think its correct to say the smell of your exhaust is a deffinit tell-tale sign that your cat is totally gone.
What I am saying is that mine smells and I still just passed emission in Mass, which the second hardest to pass next to Cali. emissions.
