power drops after 3500 rpm .. engine stalls during warm up period ... need help
Old Apr 1, 2006 | 09:10 AM
hcn101's Avatar
I don't even know where to start here. My car's not been really good lately. First of about the stalling problem, during the warm up priod which is about first 15mins the engine would stall everytime i come to a stop. After that it'll be perfectly fine. I tried cleaning the throtle body 3 times already and it didn't help.
Secondly, there's huge power drop once i get past 3500rpm. The car would still go all the way through redline though but slow.
I did some search about VIAS issue that many other members here have encountered and decided to open mine up. It turns out to be fine the cup is still intact with the shaft. There's no looseness but I think i'm gonna apply some JB weld on there just in case.
Any help would be appreciated.
Old Apr 1, 2006 | 01:17 PM
WasatchY2KMax's Avatar
Sounds like a plugged fuel filter or bad fuel pump. Or possibly a bad TPS
Old Apr 1, 2006 | 01:49 PM
BRINKLEY's Avatar
maybe MAF? Is your SES light on?
Old Apr 1, 2006 | 01:51 PM
drdrum's Avatar
Me Too
My 01 SE AT (87k) does the same thing. Above 3500 RPM it looses power, and if I don't let it warm up for 5 min. and get the idle stabilized, it'll die as soon as I put it in gear.
I have now changed the PCV valve, new mobile 1 oil change, new NGK plugs, new fuel filter. Once warm, she purrs like new. But still I have both those problems.
If you figure it out, please PM me or follow up this thread. I'll do the same if I do.
Ted
Old Apr 1, 2006 | 02:42 PM
hcn101's Avatar
No, SES light is not on...
I think you could be right. Because I talked to DaveB earlier and he said those are the symtomps of a faulty MAF. So I went ahead and ordered one. We'll see about it next few days.
Old Apr 1, 2006 | 03:01 PM
BRINKLEY's Avatar
I was right? wow, thats something new, lol. Good luck and let us know how it turns out. Dave B is the mang!!!!
Old Apr 1, 2006 | 04:12 PM
OutMaxxed's Avatar
sounds like a MAF to me..
Old Apr 1, 2006 | 04:53 PM
attomica
I had the exact same problems and a new MAF (also from DaveB) cured it all. Made it feel like a new car!
Old Apr 1, 2006 | 05:10 PM
SilverGLE's Avatar
I'm watching you, boy...
^ I agree. Had the same issue, MAF fixed it quite nicely!
Old Apr 2, 2006 | 08:33 AM
super6's Avatar
MAF..... had same problem
Ted
MAF here too
Old Apr 2, 2006 | 10:21 AM
hcn101's Avatar
Update:
I applied some JB Weld on VIAS, let it sit overnight and put it back together few hrs ago.
Also I went to look for CRC Mass Air Flow sensor cleaner but couldn't find it so I bought the electronic cleaner (liquid spray). Since I just oredered a new MAF I decied to try if this cleaner really works. I took the old one out and sprayed it down for good 2-3 minutes. I tried not to touch it at all.
Guess what guys, IT WORKS !!!!!!!!!
The car revs hapily again. It's got the power back. I drove it hard for 20 mins and found nothing wrong. Gotta love the engine tone once the it hits 5000 rpm.
In my case i personally think that maybe the MAF just got dirty, not completely dead like some others', so electronic cleaner stuff was able to cure it.
Thank you all for your help.
Old Apr 4, 2006 | 05:21 PM
MAXDADDY98's Avatar
Maxima.Org Bishes
I have the Same Problem but in the 4th Gen. I'm thinking it's the Fuel Pump. In the Morning I will jump in the car start it and throw it into Gear and the engine will Knock and instantly shut off but if I let it warm up then it's Good
Old Apr 4, 2006 | 07:05 PM
super6's Avatar
you may need to clean ur IACV and maybe TB
Old Apr 4, 2006 | 07:13 PM
MAXDADDY98's Avatar
Maxima.Org Bishes
The Motor is new and I just cleaned the MAF with Eletrical Clean and the car Ride like new
Old Apr 4, 2006 | 08:19 PM
hcn101's Avatar
You owe me $90 J/K
... yeah .. the electronic cleaner really works (in case you can't find the MAF cleaner at the store)
at least we have another solution for the MAF now beside replacing it of course...
Old Apr 5, 2006 | 08:21 AM
orlnd0's Avatar
check your maf, sounds like that, does it stutter when you gas it?
Old Apr 5, 2006 | 10:32 AM
cmuehlenb's Avatar
Do you guys run a K&N filter? Is it possible that oil from the filter it screwing up the MAF?
I had the same problem. Replaced the MAF, problem solved. I run a K&N.
Old Apr 5, 2006 | 06:36 PM
MAXDADDY98's Avatar
Maxima.Org Bishes
I run a Monster Flow from Cattman but I have another issue now /when I rev the engine my Oil light flicker on and off but not all the time. I checked Oil and put more in but light still flickers
CorollaULEV
30
Aug 9, 2021 08:11 PM
kjlouis
Nov 24, 2018 06:09 AM
Finkle
Sep 27, 2015 09:53 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
