Screeching Sounds!!
Old Apr 1, 2006 | 10:26 PM
panchosmax00's Avatar
Screeching Sounds!!
hey guys...i think my brake pads are really wearing out esp. my front right one..everytime i brake even a lil it start screeching like kinda loud and when i turn right it also screeches..but im not braking when im turning right...somtimes when im goin kinda fast turning it screeches..any ideas?? bad rotors or should i just replace the pads?? how are the PBR pads?? thanks guys
Old Apr 2, 2006 | 06:26 PM
foodmanry's Avatar
Da Roller Coaster!
Sounds like you have two separate issues....one the pads (and probably rotors by now) are worn out. Definitely get your pads replaced and inspect your rotors, if they show uneven wear or grooves replace the rotors (do not resurface if you have stock rotors).
The other issues sounds like a wheel bearing or CV joint. You can check the wheel bearing by lifting front, right of the car. Then grab the wheel at the 12 and 6 o-clock position. Try and jiggle the wheel back and forth. If its loose at all then your wheel bearing needs to be replaced.
Mahmuth
Aug 16, 2024 08:23 PM
Miket2006
Mar 1, 2021 03:55 AM
AaronL
Aug 8, 2020 10:31 AM
Need help
23
Oct 2, 2015 08:56 AM
DC_Juggernaut
Sep 28, 2015 04:07 PM
