Front sway bar = waste of money???
I just ordered a strut tower brace and will do sway bars pretty soon. Or at least a rear sway bar, but there's no love on this site for front sway bars. Is it just unnecessary? I think the progress bars are the one(s) I'd get unless you guys suggest otherwise.
Originally Posted by Gapp
Do it man. It's gonna stiffen up the front a little, plus looks bad azz.
There is NO aftermarket FSB available for the 5G maxima.....the only upgrade for that area is to put the 23mm SE FSB onto a GXE/GLE (which comes stock with a 22mm bar), and to install poly bushings on the FSB (Energy Suspension).
what sites? I would love a stiffer front sway, buthave never found one.
Also, you should check out:
http://www.blehmco.com/suspension.htm
stage I or II lower tie bar....works wonders
The stage1/2 look good but I wonder about ground clearance especially since we visit the inlaws which require driving down gravel/dirt roads
Originally Posted by 6SpeedTA95
Thats wayyy cool, I just looked at the two websites the front sway bars were for 89-94 cars, sorry for the confusion...
the ltb goes directly between the wheels, so the only time you'd scrape is if the road has an extremely high "crown" to it, or maybe on really high raised manhole covers...
That looks pretty good, what'd it do for your steering feel? For front wheel drive the maxima isn't bad...and I'd suspect something like that makes it much better.
Originally Posted by LA02MAX
i can't even describe it....i think that the LTB did the most for my suspension (even more than my h-techs and illuminas)...the steering response is greatly increased, the ride is much smoother, and there are no dash rattles anymore!
Originally Posted by chr0nos
i will be getting a stage 2 from matt soon, and getting rid of my stage 1. i dont knwo which one you wanted to get, but if you want a used stage1, its yours for $25+shipping.
have you guys checked out www.warpspeedperformance.com? they have sub-frame connectors, anyone have any experience with those?
Orlando
Orlando
Orlando
Orlando
If you guys could find an aftermarket front sway bar, that would be ideal. Maxima fwd with the engine/tranny hanging out there really needs it. I put one on my 3 gen and it was great. Might want to ask Progress or Suspension Techniques if they have anything
i can't quantify the difference b/w stage1 and stage2 bars. irish and matt both said there is more stiffness when cornering or autox with the stage2, but nobody can put any numbers on that.
i did not mean to turn this into a classifieds thread. i will be swapping stage1 for stage2 in a month or so, and will post an actual fs post. i have this thread bookmarked, and will also contact all the interested parties when i have it off my car. thanks for the interest.
Orlando
Orlando
if you feel like waiting about a year for them to be made, if ever...
so, there still is no good alternative to warspspeed for sfcs? i know serveral people were looking into getting measurments to take to their local shops.
SFC's don't make that big of a difference. A 35mph corner is basically a 90 degree corner on a 4 lane road. You wont be able to go 70 on a similar corner...I dunno that comment just made
Most of the time, a stiffer front sta-bar will increase understeer even though there is less roll. More lateral load transfer up front = less front lateral grip, and that's where you already need more. It's true that your dynamic camber situation improves (due to the reduced roll), but the increase in grip due to better camber is usually more than offset by the LLTD effect. It is possible to have flatter cornering in any given turn with less ultimate cornering g potential.
In a nutshell, that (and the typical installation hassle) is why there isn't much in the way of aftermarket front sta-bars for any FWD vehicles.
If you really think you need more roll stiffness up front, stiffer springs are a better way to go.
Norm
Norm
Thanks for the post Norm...I know front sway bars will increase understeer, and there are none available so its kind of a moot point. I've got a strut tower brace on order, when I get paid the 15th I will order the STS and rear sway bar.
I agree with your theory, but I disagree that the maxima doesn't need a stiffer sway bar up front. I used to think the same as you. But when I put my sway bar on my 3-gen, it eliminated the severe front end dive that all maxima experience when turning. Allowing the front to work harder, also transfered more work to the rear, letting the whole suspension work together. VS having each corner dive in, upsetting the rest of the suspension.
I also disagree that using stiffer springs is the answer. Stiff springs will just make the ride that much harsher all the time. Where the swaybar will only increase harshness when one tire hits a bump and the other doesn't. If both wheels hit a bump, then there is no increase in harshness.
Norm
Norm
I had to removed Matt's lower tie bar (2) it was scrapping a lot, but my car is quite low, I barely have 2 inches of ground clearance. If you are not running coilover you should be all fine, I mean the LTB2 is a must to have.
I had the LTB2 for about a month but man this car was litterally on rail. It was a pretty thrilling experience, I might re-install the bar soon but this time I'm going to raise the car 1-1 1/2 inche that should give me a better clearance.
I totally agree with you. I've driven my cousin's gle max, the car is bone stock but what a difference compare with my max, of course it's not a good comparison because all the suspension mods I have give me a net advantage. It shouldn't be that much of a big deal to manufacture a bigger & stiffer front sway bar... I also notice a nice improvement when I replace the stock sway bar bushing with the ES bushing.
. . . when I put my sway bar on my 3-gen, it eliminated the severe front end dive that all maxima experience when turning.
If your suspension has any rising rate effect at all (I think that most do), the unloading side will rise more than the loading side drops, exaggerating the apparent "dive".
BTW, this is not limited to FWD cars, or strut-suspended cars; I first noticed the same thing when I added a 7/8" front sta-bar to a 1964 Dodge that had been delivered without any bars at all.
Norm
A side note, for those of you who don't know who Norm Peterson is, since he doesn't post in the 5th gen forums all that much....
Norm is, in my opinion, one of the top two or three handling gurus here on the org, and his word is practically Gospel, as far as I'm concerned.....
If the front is working harder, it's the end doing relatively more work. The under-utilized rear is doing even less work. It feels more stable, partly due to the increased understeer and partly because the bump damping on the outside front is now a smaller percentage of critical (you need to consider spring + bar effects), so the ride height change on the outside front occurs slightly quicker and it approaches its steady state loading a little sooner.
Going with stiffer springs does not necessarily have to mean you have to double the OE rate or more to cut roll noticeably. My own experience is that spring stiffnesses 70% - 85% stiffer than base OE springs or 45% - 60% stiffer than the factory "performance" pieces is entirely liveable on a daily basis. Your butt-meter and those of your passengers may differ on the percentages, but stiffer springs aren't necessarily as evil as some have made them out to be. One hint for running stiffer springs (especially if they're LOTS stiffer) is to get the shocks/struts revalved for slightly less bump damping and heavier rebound damping. Another is to have enough rate to compensate for any lowering that occurs (and if the ride comfort associated with staying off the bump stops has any importance, lowering should be minimized). Most "lowering springs" and all severely cut OE springs fail this last criteria; a properly designed spring of higher rate will be no more likely to hit the bump stops in any reasonable situation than the OE springs.
Norm
i think the stage2 ltb makes a difference because it stiffens the front (trailing arms), and mainly anchors them further back along the car's chassis. meaning, when you turn and your front end flexes,t it "extends" the flex further along the chassis. since the ltb2 is anchored in more places than stage1, it wont lent the front end flex as much by itself, and puts more of the force evenly along the car. i think the ltb2 does similar things as the sfc running along car's body.
I agree with Norm. The Max largely suffers from terminal understeer, and this problem is better solved at the rear than the front. When the car was new, I HATED that wallowing "fold over on its nose to the outside of the turn. This might be slightly helped by a front sway bar, but when I learned that the Max had NO RSB, getting one was the first mod needed. The FSTB is inexpensive, looks cool and probably contributes enough front end stiffness to call it a day; no need for a front sway bar.
I went with the H&Rs for lowering springs when I found that the Max didn't come close to my SVT Contour, one of the best handling front driver I have ever driven (too bad it kept falling apart!). The H&Rs were OK in combo with the KYB-GR2, but I always hated that the drop looked lower in the rear than in the front.
So this past weekend I solved the problem. I pulled the rears and reinstalled the SE springs in the rear. I found the GR2s were fine but with rough NJ roads the H&Rs were bottoming out in the rear. Turns out this was correct because the bumpstop was really jammed on.
The wheel gap is now EXACTLY the same front and rear. There is a slight forward croutch that looks cool. Even better, the handling has been greatly improved. The car now has a nice neutral feel, the understeer is gone, I can now kick out the tail by rolling off the throttle midturn, just like I used to do with the SVT.
I believe the handling improvement is the result of reducing the spring stiffness in the rear, to give me a scootch more roll in the rear that is kept under control with the ASB and GR2s. I might suggest this mod setup for any of you on beat-up roads and a need for better handling.
just for some perspective on eliminating understeer....for those of us who often autocross in 4th/5th gens with the beam axle action, the general rule (unlike in other cars) is to put the rear tire pressures VERY high to help the rear end "rotate". In the last event, I ran 39psi up front and 42psi in the back - and the car rotated MUCH easier than with my setup last season - 41psi front 37psi rear.
