How do I remove 2000-2001 headlights I am trying to do AE mod
Old Apr 9, 2006 | 11:22 AM
scheibler's Avatar
I am trying to remove the 2000-2001 maxima headlights as we speak. I would like to do the AE mod were I remove the chrome finish in the oem headlights. How do I remove the headlights? I have gotten the four screws that are obvious off located on the tabs. Help me from there please
Old Apr 9, 2006 | 11:28 AM
alpinestars™'s Avatar
THIS IS...
Read the stickies. There should only be two screws on the top of the lights. There are two tabs that you have to release the headlight from.
Old Apr 9, 2006 | 11:31 AM
MaDxKiLLa's Avatar
Just pull really hard while holding the tabs up..it is pretty tough to get out sometimes
Old Apr 9, 2006 | 11:40 AM
upstatemax's Avatar
Smash them to little pieces with a hammer, they should come out really easy then.
All you have to do is remove the top screws and put some force on it from behind to pop the bottom holders from the clips and the post that is behind the blinker.
Old Apr 9, 2006 | 11:43 AM
scheibler's Avatar
I removed the to screws from each headlight and then released the plastic clip on each right next to the bolts. It still feels like the outer corner of each headlight is held back by something Is there another clip or screw behind or on the side of the lights?
Old Apr 9, 2006 | 11:44 AM
BRINKLEY's Avatar
first one is always the roughest, once you get the ***** to put some **** into it, and pull it out, you'll see the post on the rear corner that was holding it, and see why it took a little more than expected. good luck.
Old Apr 9, 2006 | 11:49 AM
upstatemax's Avatar
There is a post that slides into a clip behind the blinkers...
Show that housing who is Boss and use some muscle!
He is un-screwing the post in this pic:
scheibler's Avatar
so just yank them out...****. I hope nuthing breaks casue I gotta be at work tommorow past dark!
Old Apr 9, 2006 | 11:52 AM
upstatemax's Avatar
Tape them to your front end, problem solved.
Old Apr 9, 2006 | 11:55 AM
scheibler's Avatar
I jsut got them out. I see what youa re talking aboyut...the metal post. I was afraid it was another plastic clip.
Any1 know where the best how to for doing the 5th gen AE mod is?
Old Apr 9, 2006 | 11:59 AM
upstatemax's Avatar
http://www.cardomain.com/ride/2190617/3
i used this one, But dont use water to remove the chrome, use PlastX, it is WAY easier.
Old Apr 9, 2006 | 12:26 PM
scheibler's Avatar
Is the shiny diamond shaped chrome refletor in the mainheadlight supposed to comout to or is it safe to leave it unsecure in the headlight?
Won't the wet towel dry up and catch on fire
Old Apr 9, 2006 | 01:17 PM
upstatemax's Avatar
Leave the reflector in and no, the towel will not dry up and catch on fire.
Old Apr 9, 2006 | 01:37 PM
scheibler's Avatar
Wow...still Workin On The First Headlight. This Is Truly A Biotch To Get The Damn Lens Off....
Old Apr 9, 2006 | 08:49 PM
Maximized2000's Avatar
Hey upstatemax, I added your suggestion of PlastX to my writeup.
Hey scheibler, Glad to hear your having fun doing the AE mod. I know it does take some time to do but the end result is worth it.
Old Apr 10, 2006 | 07:30 PM
ctrent86's Avatar
I recently did the AE mod myself (pics up soon). I did the remove the chrome game by using plastx but still wasnt satisfied with the cblack color contrast. I did with the suggestion of someones writeup here on the org I believe and painted them. I couldnt be happier wit hthe results well worth it. I used glossy black engnine enamel. Why engine enamel two reasons. It is paint rated to with stand extreme temps found in engine bay so you know it is going to last. And it takes less coats. Just take the chrome bezel from the housing. It is two screw once you get the housing seperated I believe and spray away. Caution do not spray the chrome reflective housing that the bulb sits in. You can either cover the chrome part of the reflective housing or Just remove the chrome embelze. I painted over the chrome embelze and it emits way more than enought light to be seen at night (people's biggest question). Again I want to reiterate that you do not paint the reflective housing the bulbs sits in only the chrome embelze. Over all very happy with the engine enamel mod. It is well owrth doing and adds just a little bt of professional paint shine to it.
Old Apr 10, 2006 | 07:35 PM
upstatemax's Avatar
Originally Posted by ctrent86
You can either cover the chrome part of th ereflective housing or paint over it. I painted over it and it emits way more than enought light to be seen at night.
You sprayed over the refector housing?!
Bad idea buddy...Please do not even suggest it as an option for other people to do.
Old Apr 10, 2006 | 11:00 PM
westler92
I agree 0
Old Apr 11, 2006 | 05:42 AM
I agree with ^^
Old Apr 20, 2006 | 05:53 PM
Gennady7's Avatar
today i recieved my headlights to do the AE mod.
I got done with one headlight except after it came out of the oven, these weird sweat marks appeared all over the lense. How can i remove it, water wont work.
Gene
Old Apr 21, 2006 | 08:16 AM
Gennady7's Avatar
After these headlights baked, 10 mins and 10 mins, the lense got really nasty and its not coming out. What can i DO?
Old Apr 21, 2006 | 09:59 AM
scheibler's Avatar
they should just go away when the lights cool. I used plastx produced by the same manufacturer as scratchx. You should try that or another plastic polish
Old Apr 21, 2006 | 10:15 AM
Gennady7's Avatar
They did not which is what I found so weird.
I have to find some polish. Did you use a polishing tool such as the one that has a cloth and spins quickly?
Old Apr 21, 2006 | 10:58 AM
ctrent86's Avatar
I revised my post sorry for the miscommunication.... That was my bad I had left in on my computer and I left to go get some mass air flow sensor cleaner and my bro posted it with out me obvisously with some fillins I am sorry to everyone for this misinformation.
AaronL
Nov 15, 2020 11:52 AM
03VQMAX
Nov 10, 2015 03:39 PM
Vistance
Sep 17, 2015 05:17 AM
Hdnseek
Sep 9, 2015 05:55 AM
mpbclutch33
Sep 8, 2015 06:21 PM
