2000 Maxima trans TSB
Old Apr 9, 2006 | 03:48 PM
Spin20's Avatar
I have a 2000 maxima with 45,000 miles and im starting to notice a first to second gear slip at WOT. I want to take it to nissan for the TSB for it but I want to know if I should be aware of anything before I go. I have full suspension and some other mods, I dont want them to bust my chops because of that and I want to make sure my max fits the description of the vin numbers mine is JN1CA31A9YT020070 I think that falls into the ones that they will take care of but I just want to be sure. Basically if anyone has any advice or can tell me that my car is definitely one of them that will get fixed I would greatly appreciate it. thanks
Old Apr 9, 2006 | 08:56 PM
BlackMaxima21's Avatar
maf sensor??
Old Apr 9, 2006 | 08:57 PM
Gennady7's Avatar
No i have the same problem
except nissian didnt do crap for me. I just got used to it.
Old Apr 9, 2006 | 09:00 PM
foodmanry's Avatar
Da Roller Coaster!
Take a print out of the TSB in with you. Your mods do not affect the TSB. If the dealer gives you BS show the TSB and ask to see the service manager if need be. In the far off chance they still refuse to repair under the TSB, then take it to another dealer.
Old Apr 9, 2006 | 09:51 PM
dafertilizer's Avatar
yeah I have the same problem, but the valve solenoid they have to change is like $280 just for the part, not to mention the labor. and you can read on the TSB, it says if the first to second slippage is not fixed by this then repalce the transmission control module, and if still not fixed, procede to repair manual for transmission.
This is why I have not done this, With my luck I'll go spend $1000 for a new valve solenoid and TCM, then they'll tell me I need a new tranny 2 weeks later...
Old Apr 9, 2006 | 11:16 PM
SilverGLE's Avatar
I'm watching you, boy...
^ That sounds about what happened to me... Got my Max back in January, and about 2 weeks later, I would accelerate hard, then the power would suddenly drop off at 3500 rpm's... regardless of the grade I was on. Took it in (after researching the TSB's, of course), and it turned out to be a valve body on the transmission. The part and installation labor was about $900... Thank God I had the 50/50 warranty for 30 days...
Old Apr 10, 2006 | 04:15 AM
Spin20's Avatar
I thought that with the TSB there is no cost, its almost like a recall, now im getting worried about having to pay a lot for this.
Old Apr 10, 2006 | 04:45 AM
qballjr13's Avatar
I think a few .org'er have discussed this on previous thread and IIRC TSB's are not recalls. They are just recommendations for typical problems that occur on the vehicle. If you are out of warranty then you may be required to play for it. Someone correct me if I am wrong.
Old Apr 10, 2006 | 08:06 AM
SilverGLE's Avatar
^ That is correct! My car's factory warranty was dead before I bought it, so the TSB had to be paid by me. Thankfully, I had a 50/50 30 day warranty on my Max. I was under the assumption that TSB's were free fixes, then learned that those who had them fixed for free had some type of warranty.
Old Apr 10, 2006 | 08:41 AM
Omar's Avatar
Does this TSB also apply to the 2000 I30t?
Old Apr 10, 2006 | 09:41 AM
Edward Lee's Avatar
I HAD THE SAME PROBLEM AT THE SAME MILEAGE It's your tranny and it is covered under the 60k engine and drivetrain warranty.
TAKE IT IN TO THE DEALER. MY VIN #JN1CA31
Old Apr 10, 2006 | 10:58 AM
Spin20's Avatar
No kidding, thanks for the info, Im gonna bring it there within the next 2 weeks, Ill let you guys know what happens.
Old Apr 12, 2006 | 05:46 AM
nismomaxct's Avatar
I have a 2000 Maxima GLE with an automatic and had the same problems. My car was not under warranty and I had to get the valve solenoid and the transmission control module replaced, and it didn't really fix the problem. I took the car right back to the dealer that fixed the car and they had a mechanic drive around with me. When the car is under WOT the car seems to bang into gear. I know that sounds strange, but it is the only way I can think to describe it. The mechanic that was with me said that that was ok and it was normal and there was nothing else they could do. I have no mods on the car at this time. I am thinking about replacing the transmission. what do you think? What are the possibilities? I hope this helps you guys. O, and the parts and labor for the repairs was around 2500.
Old Apr 12, 2006 | 07:31 AM
Edward Lee's Avatar
Wow, you got ripped. Sorry to hear that. As far as the banging into the next gear, I would think that that would be a good thing. Well, maybe not for a GLE since it's luxury but isn't that what a valvebody recalibration does? Doesnt' it make it so that the shifts are quicker and more solid?
When I had the problem, my car would rev up in 1st, rev in between the shifts like it was in neutral and then bang into second. I think that the in between gear rev was more the concern than the bang.
Old Apr 12, 2006 | 08:03 AM
Spin20's Avatar
Mine is the exach same way, it feels like it is in neutral for about 4 seconds then will shift into second, it doesnt really bang but the neutral thing bothers the hell out of me. I am scheduled for tuesday morning to drop off my car and i have the tsb with me, I will keep you guys posted. Wish me luck, and I only have 2 weeks left on my extended warranty.
Old Apr 14, 2006 | 09:11 AM
Jaws's Avatar
Yes, it is covered under the 60k mi or 5 YEAR (whichever comes first) warranty. The dealer will reference the "in service" date of your car and if it is greater than 5 years, you are SOL. Sorry to to be the voice of reason, but the dealer is under no obligation to fix something that is out of warranty unless they are being very nice to you. TSB means nothing.
ef9
Aug 13, 2015 01:19 AM
follyburr
Aug 12, 2015 08:57 PM
Hawkeye61
Aug 12, 2015 06:45 PM
jholley
Aug 11, 2015 09:38 AM
niZ
Aug 7, 2015 10:18 PM
