6th gen needs help with crank pulley removal...
Old Apr 9, 2006 | 06:03 PM
greg hazlett's Avatar
Can someone please tell me once and for all the way to remove the crank pulley bolt? I read the stickies and can't find evidence if it is left hand or right hand thread? Thanks!
Greg
Old Apr 9, 2006 | 08:39 PM
BlackBIRDVQ's Avatar
drag racing is for wussies
Impact gun and a socket, then the pulley should come right off the crank snout.
Old Apr 10, 2006 | 03:59 AM
Used a 19mm socket and 2 different air gus and 2 men weighing 500lbs combined moving in a clockwise direction and that thing did not budge. Any other ideas?
Old Apr 10, 2006 | 09:31 AM
Fezzik's Avatar
Get a breaker bar, and set the bar where it rest on concrete, blip the engine. and wala. Your bolt should be loose.
Old Apr 10, 2006 | 11:41 AM
bladerunr's Avatar
Bravo! Hear, Hear. I second that emotion.
Old Apr 10, 2006 | 02:42 PM
I stopped at my Nissan dealer today and spoke with the shop sup who said that the crank bolt is a right hand thread. For the starter method, which way should the ratchet be to hold the bolt while the starter engages-loosen or tighten?
Old Apr 16, 2006 | 10:26 PM
Fezzik's Avatar
The bolt is righty tighty and lefty loosy. Be carefull if u place the breaker bar on the control arm... i bent in my oil filter lol. Had to change the oil anyway. If you are looking at the crank pulley straight on. The breaker bar should point to about 4-5 oclock and rest it against the concrete and then blip the engine. Be sure you dont start it.
mvm062
Nov 30, 2020 09:00 AM
BkGreen97
Apr 2, 2016 05:47 AM
Max139617
Sep 20, 2015 07:25 PM
Max139617
Sep 20, 2015 07:09 PM
