Must-have mods on a modest budget?
Hey, have had an AE 5-speed for a few months now. So far, I've done FSTB, Berk intake, Z-rated tires, and Y-pipe. What are some other good performance mods on a modest budget? I'm considering a RSB and Illuminas, but like the stock ride height. Are there any performance springs that don't lower the car hardly any? Has anyone done just Illuminas but left the springs stock, and did it have a noticable effect on handling/body roll? What about other acceleration mods? Can the timing be permanently advanced on an '01, and if so, how? Are the UDP's any good? Just getting back into the Max scene (had a 4th gen that was fairly modded) and wanted to know what are the best and newest things to do to these cars, short of a super/turbo charger.
Thanks a million!!!!
If you want a more stock ride height and better handling you can go with H&R, Tein H-Techs, or Eibach springs. They have a very mild drop and help the car handle better.
UDP's do not do much and most cost to much to justify the gains.
If I were you I would concentrate on making the boat handle better, if you are still on factory struts they are most likely at the end of thier life anyway. I would say; springs and struts and then a rear sway bar.
And yes, timing can be permanantly advanced on any 5th gen.
Originally Posted by dentalstud
Can any shop do the timing advance? Or do I have to get a chip/ECU mod?
Nissan dealer, you have to use the Consult tool for Nissans. Should cost under $70, you can try and catch one of the techs on the side for $20 cash in pocket to do it.
I would suggest either H&R (1.4F 1.3R leaned back look) or H-Tech (1.6F 1.0R leaned forward look...although if you only want to lower it a little this may be a tad too low in the front for you, but it looks nice) springs and a rear sway bar...it makes a HUGE difference...I got the Progress rear sway bar but there are other brands and I don't think it matters which you get...and I also suggest tint...it makes any car look nicer.
Called my dealer, he said it would be $39.95. Is the idle adjustment necessary as well when doing this? I heard it bumps your idle up a little, which I don't see as being a big deal.
Some re-adjust, some dont... its up to you.
Hey this is a good thread, im wondering some of the same stuff and wanna sk some questions along those lines, like how hard is it to install a rear sway bar? Most likely wouldnt do it myself but in terms of labor hours at a decent shop. Also ive heard some bad things about the timing advance, what exactly does it do? Just advance your stock timing from 14 degrees to 17? And you have to run premium right? Also what are some good aftermarket front swaybars, or are they not worth it if your doing struts/springs and a RSB?
They are worth it even if lowered, IMO.
http://forums.maxima.org/showthread.php?t=412478
Also, do you think that just doing struts and not springs would be worth my time, performance-wise?
Nice mod.
Also, with our roads here I can't imagine taking a lowered car over them.
Originally Posted by Ice Train
The advanced timing thing, what is that all about? Should I do it on an automatic?
Originally Posted by Puppetmaster
Subframe connectors are only around 300$ installed and they supposedly improve your ride, allowing you to run more aggressive springs.
There are a couple guys on here with subframe connectors and coilovers and they actually say their ride isnt bad at for running such high spring rates
Originally Posted by sciff5
Ohh thats so F'in helpfull. I was expecting that link to actually provide some info on advancing timing
http://forums.maxima.org/search.php
Hey, don't knock my tires "mod". It's the best thing I've done for the overall performance of the car. Anyway, about the timing...I went today on my lunch break. A few minutes after taking my car back, the "master" tech came by to tell me that changing the timing "wasn't possible". I said "I'm not trying to tell you you're wrong, but you can." He said "No, all I can do is reset the self-learn with the Consult." I said fine, I'll go find the procedure online. I drove off but wasn't happy. I went right back in to the service manager (who scheduled my appointment and quoted me the $39.95) and said "Your tech says the timing can't be altered". He says "I know, that's what I told you on the phone. I'll go talk to the tech". He comes back about TEN minutes later only to say, "The only way to change it is through the timing belt". Another "Master" tech is there and overhears...he says, no, you can change it with the Consult, it just will go back to stock once you turn your engine off". Now we're getting SOMEWHERE...I tell him "NO, that was true until 2000 models, now it will stay". He said, "I've been working on Nissans for 22 years, and I know what I know". I said, "I'm willing to give it a shot". He says allright, hang on. About another 5-10 minutes pass, and a girl who works in the service dept. says, "are your keys in the car?" No, here, I say. I tell her "I've got about 10 minutes max before I have to leave to go back to work. She says, allright, and goes back to talk. She comes back out and says, "he can't do it in 10 minutes, so you'll have to reschedule". I was soooooo PO'd. But I'm going back tomorrow, with a copy of the printed procedure, and I'm going to watch the guy do it and see what he says when I have proven him wrong. I shouldn't even go back, but I'm not leaving it alone with them having the upper hand. They've been a decent dealership, they just are ignorant about any mods whatsoever.
They've been a decent dealership, they just are ignorant period.
Btw, bring this for their dumb@sses to follow:
http://forums.maxima.org/showpost.ph...90&postcount=1
Originally Posted by Gapp
I'm not knockin you man! I think its funny the link Puppetmaster gave to
Sciff5. Mod on!
Sciff5. Mod on!
I supposedly had the timing advanced today. They didn't charge me anything...I don't know if they felt bad about yesterday, or if they really didn't do anything and therefore have no liability...it honestly feels no different at all. Should I feel a definite difference? My butt-meter is pretty sensitive, but I am a five-speed...if that matters. Is there a way I can check it short of another Nissan dealer's Consult?
Apparently, according to responses here, the 00-01 guys feel a difference when timing is advanced. But don't quote me on that.
zzznightmarezz
Sep 21, 2015 06:32 PM
