LED mod for AT Shifter lights?
Old Apr 13, 2006 | 12:58 PM
BigL0U's Avatar
Did a bit of searching for such mod however no details on "how-to"s ... Hoping to match the AC unit and window switches in blue. Has anyone made thier shifter light brighter? Pics?
Old Apr 13, 2006 | 01:05 PM
Metal Maxima's Avatar
SHIFT_om nom nom nom
Old Apr 13, 2006 | 01:24 PM
BigL0U's Avatar
Originally Posted by Metal Maxima
Thanks. But im looking for LEDs in the shifter lights. Do you have one LED on each button for your AC unit or just replaced the stock sockets?
Old Apr 13, 2006 | 01:30 PM
And those aren't shifter lights? Do you mean the gear lights in the climate control?
Old Apr 13, 2006 | 01:56 PM
BigL0U's Avatar
No sir ... The lights illuminating the following P ,R ,N, D, 1, 2 ... right by the auto tranny shifter. They light up very dim.
Old Apr 13, 2006 | 02:09 PM
XyNoix-HIC's Avatar
Man i wanna see both how-tos, i jus ordered a bunch of LEDs, slow coming but i can't wait to start doing my windows and clock, instrument panels, and what not, the only how-tos i'm missing are for the radio, AT shifter, AC controls, and the passenger windows =(
Old Apr 13, 2006 | 02:16 PM
BigL0U's Avatar
as far as the clock is concerned i think ure only able to apply a colored film behind it. i.e. Blue Film for blue and Red film to make white ...etc... same for digital AC screen ...
Old Apr 13, 2006 | 02:41 PM
MIXXMAX's Avatar
It only appears dim because there is only one bulb in there to illuminate the whole shifter panel. Not sure if you can modify this or not. The bulb is in a tight spot and where it's placed, it's only designed to do what it's supposed to do...shine/spread light to read the shift indicators. I changed my shift indicators in the guage cluster from those nasty green LED's to bright blue LED's if you wanna see pics?
Old Apr 13, 2006 | 02:48 PM
BigL0U's Avatar
oh crap! yes please. i didnt think that was possible. what size LEDs? any additional information would be appreciated.
Old Apr 13, 2006 | 02:55 PM
MIXXMAX's Avatar
Anything's possible once you take things apart...here ya go! I also changed the turn signal indicators.
Old Apr 13, 2006 | 03:05 PM
BigL0U's Avatar
looks good. what size LEDs? i assume theres not write up for it. seems like there might be soldering required... is there?
Old Apr 13, 2006 | 03:24 PM
MIXXMAX's Avatar
For the shift indicators, I used 5mm 5000mcd's (stock ones were 5mm also) and for the turn signal indicators I used 3mm 5000mcd's. Yes, soldering is required but is very simple if you are familiar with soldering jobs. Sorry, no write-up, but if you know how to get to the gauge cluster, it only involves taking the cluster apart. Very simple.
Old Apr 13, 2006 | 03:27 PM
BigL0U's Avatar
good stuff ... thanks ...
Old Apr 13, 2006 | 05:40 PM
BigL0U's Avatar
dumb question BUT just in case... do the turning signal LEDs have to be flashing LEDs? doubt it but ya never know ...
Old Apr 13, 2006 | 07:57 PM
MIXXMAX's Avatar
No. They are hooked in line with the turn signal wire which sends a signal for them to flash (like a bulb).
Old Apr 14, 2006 | 03:07 PM
OHH NOES's Avatar
6spd Swapped
As for the shifter light (the P,R,N,D,etc) once you take out that whole coin holder/cigarette lighter/flasher assembly that goes around the shifter you can lift up the metalic shifter plate and you can take the whole light assembly out from underneath it. You can take the old light out and cut a PCB yo fit in there big enough to point an LED at each letter/number. I couldnt find a write up for this either so if anyone wants a writeup for this I can make on up for you guys?
Old Apr 18, 2006 | 01:25 PM
BigL0U's Avatar
yes indeed. keep me updated. thanks!
Old Apr 18, 2006 | 01:59 PM
XyNoix-HIC's Avatar
DAMN i shouldn't have gotten the 10mm 50k white LEDs =(....
Old Apr 18, 2006 | 08:46 PM
OHH NOES's Avatar
6spd Swapped
ok, I just have to take some pictures and Ill make a writeup for it.
Old Apr 18, 2006 | 08:47 PM
OHH NOES's Avatar
6spd Swapped
You can always shave them down with a dremmel
Old Apr 25, 2006 | 11:51 AM
BigL0U's Avatar
Any updates on a write up anyone?
vingodine
45
May 21, 2016 12:46 PM
Fakie J Farkerton
Oct 14, 2015 06:25 PM
spidgeon
Aug 18, 2015 05:46 AM
220k+ A32
Aug 17, 2015 03:57 PM
