Custom Sidemarkers
Old Apr 18, 2006 | 08:44 AM
qballjr13's Avatar
Custom Sidemarkers
Ok, so I smoked out my side markers this weekend and wanted to share some pictures. I used Lamin-X (www.lamin-x.com) charcoal film. It was pretty easy but it’s definitely nice to have an extra set of hands to help you. The part number I ordered was #2-612, it was a set of two 6”x12” sheets. It was perfect for the four side markers. I cut each sheet in half the long way, making 4 – 3”x 12” pieces. We started to follow the directions by applying soapy water to the lens and applying the film but actually found it to be easier if you just applied it directly without the water. The hardest part was fitting it around the rounded ends of the markers. This requires your wife’s hair drier and cutting a lot of little relief slits in the film. The hair drier is huge in fitting the film. The product is very thick and not easily workable until you heat it so soften it.
STOCK
IN PROGRESS
Old Apr 18, 2006 | 08:45 AM
qballjr13's Avatar
Part 2
FINISHED
Old Apr 18, 2006 | 08:47 AM
GigEmAgs07's Avatar
looks good!
Old Apr 18, 2006 | 08:52 AM
KCMC582's Avatar
that does look pretty good. more even coverage that nightshadesobviously since its a film, and it seems to make them pretty dark. not bad at all. i may want to try this on another set of clears and see how it looks.
Old Apr 18, 2006 | 08:54 AM
Bluesbrekr's Avatar
Doctorate in Detailing
Looks good. A great alternative to Night Shades. (which is how I did mine)
Old Apr 18, 2006 | 08:55 AM
qballjr13's Avatar
I forgot to add that the set of film cost me $30.90 (shipped) still cheaper than ANY set of "smoked sidemarkers" that go for like $40 for just the fronts...and they are darker.
Old Apr 18, 2006 | 08:57 AM
hybridioN's Avatar
all teh single ladiez
eat that, ce.
looks good. i may just have to try this.
Old Apr 18, 2006 | 09:01 AM
qballjr13's Avatar
Originally Posted by hybridioN
eat that, ce.
EXACTLY, that is why I wanted to post this so bad!
Old Apr 18, 2006 | 09:10 AM
chr0nos's Avatar
holy ****. can you use regular llumar or solar gard film? its about $2 per square foot. or is this stuff made for plastic?
Old Apr 18, 2006 | 09:14 AM
qballjr13's Avatar
Here is what I learned from talking to a couple of people. This product, Lamin-X, is similar to a 3M Clear Bra. I believe Llumar and Solar Gaurd are both window tint??? I asked the guy who did my tint if I could use just a window tint and he said no. He said that tint will not hold up with the moisture on the exterior of a car. It will just bulb and peel off.
Old Apr 18, 2006 | 09:39 AM
2kprlmax's Avatar
can you take pics of the side markers on at night and the day so we can see how it looks.
Nice job also.
Barc's Avatar
I've actually tried that... Sadly, I couldn't make it work using standard tinting techniques. Maybe it would work with heat or something, but I just ended up painting mine.
Old Apr 18, 2006 | 09:52 AM
qballjr13's Avatar
Nice job also.
These were taken in my dark garage. But I can say that they barely look different with the lights on, which is what I wanted so no one hassles me about them. The pictures really dont do it enough justice, but I will share to try to help out.
Old Apr 18, 2006 | 09:54 AM
qballjr13's Avatar
There is no way you can work with this stuff without heat. Its 17mm thick and very rigid, you absolutely have to warm it up to work with it at all.
Old Apr 18, 2006 | 11:18 AM
hybridioN's Avatar
are you using regular bulbs or did you get brighter ones?
Old Apr 18, 2006 | 11:29 AM
qballjr13's Avatar
They have to be stock, the brighter bulbs are too hot and will melt the film from what I was told (by a 3M Clear Bra installer)
Old Apr 18, 2006 | 12:05 PM
cutter's Avatar
Originally Posted by qballjr13
IN PROGRESS
Nice job....how did you cut yourself? There are some blood drops near the sidemarkers
Old Apr 18, 2006 | 12:09 PM
qballjr13's Avatar
No blood, which is unusual for me! Thats red paint from another project...my workbench gets used very often!
Old Apr 18, 2006 | 12:12 PM
cutter's Avatar
lol....oh that definitely looks like blood to me.
Old Apr 18, 2006 | 12:20 PM
qballjr13's Avatar
Maybe I should have said it was....that would have been a better story!
Old Apr 18, 2006 | 01:42 PM
Barc's Avatar
That stuff is over half an inch thick? (17mm = something like 2/3")
Regular wnidow tint just doesn't stick properly nor does it stay stuck once you do get it "looking" right. I was referring to the fact that you may be able to melt it on! lol
Old Apr 18, 2006 | 04:24 PM
qballjr13's Avatar
Oops, I meant 7mils...not 17mm...sorry about that. I guess I was way off on that one.
Old Apr 18, 2006 | 07:00 PM
Lontar1's Avatar
Puerto Rico-Maxima Lover
i'm getting tired of the clear sides..does anyone has a whte pearl with the dark markers??? it looks nice.. I like it
Old Apr 18, 2006 | 07:15 PM
scheibler's Avatar
I'm getting ready to. I can't decide wether to stick with stock sidemarkers and smoke them or get clears and then smoked them. Iw ill post pics when I do.
Old Apr 19, 2006 | 03:30 AM
qballjr13's Avatar
Thanks! Check out the Lamin-X website, they have two different "smoked" films. One is called "smoked" and the one I used was "charcoal" (obviously darker than the smoked). They also have blue and yellow but I have a feeling those would look like crap or serious rice on side markers.
Old Apr 19, 2006 | 03:31 AM
qballjr13's Avatar
I was trying to spend as little money as possible yet do it right. So I obviously chose to do it over the stock side markers. Just make sure if you use the clears that you use a bulb that is not hotter than the stock bulb...it will melt the film (so I have been told).
Old Apr 19, 2006 | 04:27 AM
SoonerFan's Avatar
Cletus
me and irish used black spray paint followed by a clear coat...$5 for 8 sidemarkers.
Old Apr 19, 2006 | 04:38 AM
qballjr13's Avatar
[QUOTE=soonerfan]me and irish used black spray paint followed by a clear coat...$5 for 8 sidemarkers.
QUOTE]
Yeah I saw your cars and they both look sweet done like that. I was just going for something a little less permanent. This film can be removed if need-be without buying new lenses. Now I know it would be a PITA to remove it but I think it can be done. If you dont care about that, than painting them is the way to go. I know Irish is the of the $5 mod!
James92SE
142
Jan 2, 2024 09:23 AM
Apr 16, 2020 05:15 AM
VQ'ed
Forced Induction
Feb 29, 2016 08:05 AM
carid
Sep 17, 2015 05:00 AM
0m3nc0w
Sep 11, 2015 05:21 PM
