ABS Codes?
ABS Codes?
The ABS light started coming on on my '01. The service manual says to ground pin 8 of the link connector, turn the key on, and the codes are flashed. It doesn't seem to be working for me. Someone must have experience with this, right?
A while ago, I also had an ABS light on solid and it was due to the actual ABS sensor being faulty. I don't know what the actual code was for the issue though. It was one of my last remaining extended warranty repairs, so they pulled it and fixed it at Nissan.
12 Self-diagnosis could not detect any malfunctions.
21 Front right sensor (open-circuit)
22 Front right sensor (short-circuit)
25 Front left sensor (open-circuit)
26 Front left sensor (short-circuit)
31 Rear right sensor (open-circuit)
32 Rear right sensor (short-circuit)
35 Rear left sensor (open-circuit)
36 Rear left sensor (short-circuit)
41 Actuator front right outlet solenoid valve
42 Actuator front right inlet solenoid valve
45 Actuator front left outlet solenoid valve
46 Actuator front left inlet solenoid valve
51 Actuator rear right outlet solenoid valve
52 Actuator rear right inlet solenoid valve
55 Actuator rear left outlet solenoid valve
56 Actuator rear left inlet solenoid valve
57* Power supply (Low voltage)
61 Actuator motor or motor relay
63 Solenoid valve relay
71 Control unit
71 Control unit
71 Control unit
71 Control unit
Kyle Lee Cleveland
Sep 28, 2015 09:01 PM
