Car is pulling to the left AND right!?!?!???
Old Apr 24, 2006 | 08:48 PM
mannetti21's Avatar
I've noticed on the highway, and when I accelerate from a stop, the my car will pull either left or right. The direction seems totally random and varies between one way or the other on my 30mile drive to work. There also seems to be a very slight shimmy/vibration in the steering wheel that is hardly noticeable. Tires have about 3,000 miles on them. I noticed the first change in pulling direction after they were rotated @ 1,000miles (don't ask).
I assumed at first that it was my alignment, but when it started to pull in the opposite direction, I started thinking that it might be something more serious. Any ideas?
I'd like to have some knowledge before I bring it in to the dealer this weekend so I don't get ripped off with some bull$hit maintenance.
Old Apr 24, 2006 | 09:23 PM
whazzzzuup's Avatar
If it is pulling left or right from a stop with your hands off the steering wheel, then it is probably just torque steer (normal). If it is pulling either left or right randomly while cruising, then it is your toe (alignment).
Old Apr 24, 2006 | 09:44 PM
ravens2552's Avatar
nice write up!
Old Apr 24, 2006 | 10:25 PM
melvinman2003's Avatar
On a side note. I noticed my maxima likes to chirp alot off the line .
Old Apr 25, 2006 | 06:03 AM
zero2sixtyZ's Avatar
You embarrass me.
Yeah, whazzzup pretty much explained it. After I got mine, minus the torque steer, mine pulls to one direction while cruising. The dealership did 3 alignments and 2 wheel balances, still pulls to one direction. I kinda gave up on them. Might go to Firestone and get the lifetime one. Hope its not a suspension issue.
Old Apr 25, 2006 | 08:51 AM
TONYKUJAWA's Avatar
It can also be a tire issue if it is pulling to both sides. Mine was doing the same thing and I had it aligned twice. The guy that aligned it swithced left and right tires on the front and it went from pulling slightly to the left to slightly to the right afterwards
Old Apr 25, 2006 | 10:02 AM
Maxima570's Avatar
My car also pulls, I'm thinking its the tires, although when the wheel is turned all the way in either direction, the front end suspensions or axle creaks going over a bump. I have michelin pilot sports that I bought the car with and I think that is part of the problem
Old Apr 25, 2006 | 10:08 AM
sciff5's Avatar
Every single time my car accelerates from a stop it pulls one way and than the other... just torque steer
Old Apr 25, 2006 | 10:40 AM
FriscoMaxima's Avatar
easy off the gas pedal...
Old Apr 25, 2006 | 11:33 AM
Loonee02SE's Avatar
Somes times a front to back rotation will ease/solve the problem - could be a tire or rim issue.
Old Apr 25, 2006 | 12:14 PM
rule da road's Avatar
maybe its just the roads?
Old Apr 25, 2006 | 12:26 PM
Hoooper
dont drive through puddles with only one tire.
Old Apr 25, 2006 | 12:50 PM
chr0nos's Avatar
lol. you should turn around and make sure to hit the same puddle with all 4 wheels.
Old Apr 25, 2006 | 01:16 PM
KabirUTA13's Avatar
IN IRAQ MAXIMA.ORG-ING :)
if its going left and right at the same time u should be good... its going straight...
Old Apr 25, 2006 | 03:00 PM
cutter's Avatar
Definitely can just be a tire problem. I know that when my car was pulling to the left while just coasting on a flat road, I switched my front driverside tire with the back driverside tire and the problem went away.
Old Apr 25, 2006 | 04:14 PM
KCMC582's Avatar
as stated, its probably torque steer, but do you have aftermarket rims? or directional tires on your OEM wheels? high performance tires, usually of course on aftermarket rims, are directional and have a tendancy to follow grooves in the road. each tire is different how it responds, but its just something to think about if you have them.
Old Apr 25, 2006 | 04:33 PM
RA030726's Avatar
I'm nutty for Nissans
Check the wear on your tires. Then report back.
Old Apr 25, 2006 | 10:04 PM
mannetti21's Avatar
Tire wear looks normal, perhaps slightly greater at the outside edges of both front tires. I'm going to get the alignment next Friday morning, hopefully that takes care of the issue.
Old Apr 25, 2006 | 10:28 PM
AceofSpds's Avatar
wat
Might wanna check the air pressure in those tires, correct me if im wrong but tire wear that is greater at the edges hints to underinflation.
Old Apr 25, 2006 | 11:19 PM
Edward Lee's Avatar
Don't do that, the problem is that you own a Maxima. I have the exact same problem and took it to Goodyear 6 times within the week on my lifetime warranty. They could never get it fixed. I then took it to Westend alignment and it's now better. It still has a little drift to the right but it's barely noticable. Once Firestone gets it within spec, they no longer have to work on it.
Old Apr 26, 2006 | 07:06 PM
Hoooper
i think he means the outside edges meaning the right side of the right tire and left side of left tire. which would mean that he has a camber (or caster, not sure which is which) issue. if its both edges of each tire then it is underinflation.
Old Apr 26, 2006 | 07:17 PM
AceofSpds's Avatar
wat
that makes sense too
Old Apr 26, 2006 | 08:20 PM
MaximaGT-R's Avatar
I'm a Happy Man!
i've done three allignments and my suspension is brand new so i just concluded that its torque steer.
Old Apr 27, 2006 | 05:11 PM
RichP's Avatar
I actually had this exact problem fixed today - depending on the road, the car would either pull to the left or the right. I didn't really understand what the mechanic was telling me (something about "toe" on all four corners?), but it just needed an alignment. The car tracks straight as an arrow now!
Old Apr 27, 2006 | 05:46 PM
Edward Lee's Avatar
Toe on all 4 corners?
Old Apr 27, 2006 | 08:26 PM
Hoooper
uhhh, not really sure how you get toe in the back, but alright. he probly meant toe in the front. that would make you track into grooves in the road much easier than with a properly adjusted toe.
Lakersallday24
Jun 16, 2019 01:35 AM
trasmadean
Feb 1, 2017 08:20 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
Flores94
Aug 11, 2015 12:53 PM
kirkhilles
Aug 8, 2015 10:53 AM
