01 cams
Old May 2, 2006 | 07:25 AM
mensur724's Avatar
01 cams
hey i want to put more horpower into my 01 and i was thinking about replacing the cams does ne1 know where i could find some good ones
Old May 2, 2006 | 09:19 AM
5thgenmaxima's Avatar
I've never heard of any off the shelf cams, not enough demand,.. You would probably have to decide what you wanted and get one custom ground. I'm assuming if you knew what lift/duration you wanted that you could order a set of them. A quick call to comp cams would clear up alot of your questions on availiability.
Old May 2, 2006 | 09:22 AM
mensur724's Avatar
damn no off the shelves huh thanx though
Old May 2, 2006 | 09:36 AM
Custom cams really aren't all that much more expensive. Usually a hundred dollars more give or take...Like I said comp cams would have more info.
The question is would you really want a loob in a Nissan? Or better yet would you really want to spend all that time swapping cams for a few HP? Maybe 20
Keep in mind with the VIAS you would potentially have to alter your intake/exhaust to allow for larger lift/longer duration. Plus would you have to do any valve work, replace vavle covers to allow the parts to fit, etc.
Souping up a Nissan isn't really in my to do list, but that's only my biased opinion. Many others have done it.
Old May 2, 2006 | 09:43 AM
Metal Maxima's Avatar
SHIFT_om nom nom nom
I think Stillen was selling them at one point, they were $6xx. NOT one hundered or so.
In addition to the cost of the cams, installaion don't come cheap with them either. Great addition to have, but the cost...
Old May 2, 2006 | 09:53 AM
Barc's Avatar
The work alone on the cam in my Mustang was something like $250 (maybe less, maybe more, it's been a while). I'm not saying that a Nissan cam would cost that much to grind but you have to remember, you've got more of them than a 5.0 as well... Wouldn't a better option be sticking a 300ZX set in there? Does anyone know if they are the same or will fit? Have you looked in the All Motor section?
Old May 2, 2006 | 09:54 AM
UMD_MaxSE's Avatar
Got Bent?
I think he meant that the cams custom built were only 100 or so more than the pre-fabbed ones...
Old May 2, 2006 | 09:55 AM
UMD_MaxSE's Avatar
Got Bent?
wrong engine...
Old May 2, 2006 | 10:02 AM
Barc's Avatar
Originally Posted by UMD_MaxSE
wrong engine...
I agree. I never said they were one in the same... I asked if anyone knew if they would fit.
frankd121's Avatar
check the all motor forum..
nismo and jwt make cams...
not really worth it unless you're looking to make serious power (NA/forced induction)
Old May 2, 2006 | 10:54 AM
mensur724's Avatar
the thing is i want something thats gonna give me power i already have the intake and cat back exhaust im planning on headers and a straight pipe instead of a cat but is there ne thing else that can give me significant power?
Old May 2, 2006 | 11:35 AM
chris'smax's Avatar
Wrong fellas. You CAN buy off the shelf cams from JWT for around $1100.
Honestly the best mod you can do for your car with cams and other bolt ons is to get yourself a Emanage ultimate to tune the car w/. Many people have seen significant gains w/ tunning. Google it for more info
Old May 2, 2006 | 01:15 PM
NewLoveI30's Avatar
on that Chris
Get those headers and tune!
Old May 2, 2006 | 01:39 PM
mensur724's Avatar
hmmmm sounds good for 500 $ how much hp do i expect?
Old May 2, 2006 | 03:17 PM
123
Old May 2, 2006 | 05:46 PM
frankd121's Avatar
with headers and tuning i'd say you'll be somewhere around 210-215 whp..thats if everything else is in good working condition.
Old May 3, 2006 | 06:41 AM
mensur724's Avatar
210?????? what am i on right now??with intake and exhaust?
Old May 3, 2006 | 09:29 AM
cmoore135's Avatar
go do a dyno and find out. some intake and exhaust combos sometimes rob u of power so the only way to know for sure is to dyno. oh by the by if i remember right stock is about 180 whp.
spazma7ik
Jan 12, 2017 09:38 PM
gustavison
Oct 4, 2015 06:50 PM
Max139617
Sep 29, 2015 06:44 PM
conansriver
Sep 11, 2015 10:26 AM
