My CD player doesn't work when it's humid. It makes me want to smash it.
Old May 3, 2006 | 06:11 AM
SkoorbMax's Avatar
This is definitely the most annoying thing about my otherwise nice car. It's a 2000 Max SE and the damn Blose stereo won't work in the mornings when it's humid unless the AC is running. I can't drive to work with the windows open because the POS will just not read a CD. This, plus the fact these head units clearly have no memory buffer (good shock absorption but sometimes I can hit a stiff bump and it will skip immediately; i.e. no memory buffer, which even a $30 discman has these days) really instills such a hatred of Bose. Insult to injury, I can' teven replace the head unit without a bunch of extra crap so that the silly speakers' impedence will be compatible.
At least its sound quality is decent (when it works). Oh yeah, the tape doesn't work, so i can't hook up an mp3 unless I get a radio transmitter.
Old May 3, 2006 | 06:25 AM
Maxima570's Avatar
I feel u man, my bose skips out when the car is just started, and then when you change the song, its like a 5 second delay before it plays. It occcasionally skips out even when the car is warmed up. I just got it, I can't wait to see what the humidity will be like...
Old May 3, 2006 | 06:27 AM
TXT-1's Avatar
Time to go aftermarket.
Old May 3, 2006 | 06:38 AM
Penguin215's Avatar
Amen to that, and some good, but cost efficient stuff out there. Head to the Audio and Electronics forum if interested,
Old May 3, 2006 | 07:03 AM
chr0nos's Avatar
u can get another one on ebay or other web sites for about $60-100. i thnk the max's bose is made by clarion, which is not the highest quality head units.
Old May 3, 2006 | 07:23 AM
boondoxmax's Avatar
Damn my Bose unit has never skipped over bumps or had the dreaded cut out problem....Sound quality is pretty good also over the base audio system.
Old May 3, 2006 | 07:38 AM
maximaownsyou's Avatar
you might wanna knock on wood after sayin that boondox...
Old May 3, 2006 | 11:07 AM
StillenMax80x20's Avatar
dude.... same problem in my SUXXX (Bose) CD player, doesn't even play enough time toi consider it skipping.. If i put a burned cd in there it would almost play once.... A YEAR AGO
I gave up... though i will never add an aftermarket dash to my beautiful console... there are parts that give you an input (AUXNISS) and have a 1 gig shuffle.. never worry aboiut music again... always works cheaper than a new HU and lookst much nicer than the frankenstein addition of aftermarket parts in my otherwise beautiful DASH.
MY $0.02.
Old May 3, 2006 | 12:02 PM
biggy8481's Avatar
makes me glad I didn't get a max with bose... but for some reason my stock head unit, also made by clarion will play just about anything I put in it. I took out a dvd head unit to put the stock one back in because the dvd unit didn't like cd's
Old May 3, 2006 | 01:09 PM
FriscoMaxima's Avatar
just turn on the heater...
Old May 3, 2006 | 01:25 PM
sciff5's Avatar
Hey it could be worse.... You could live in Miami
I am pretty sure you could just throw your head unit away if you came down here its so damn humid
Old May 3, 2006 | 03:33 PM
honestly it used to make a difference with heater on and cold air in my old MAXIMA... but this one... just friggin laughs when i put a cd in... scratches it... then says 'Err' .... no matter what, cold/hot out heat or A/c. Period.
Old May 5, 2006 | 07:39 AM
ctownmax's Avatar
every time there is a heavy rainfall, my bose head unit wont play a cd for about 30 mins.... stupid pos!
Old May 5, 2006 | 07:40 AM
ctownmax's Avatar
edit** and it hails
Old May 6, 2006 | 11:08 AM
Spartacus2002's Avatar
Mine just had the display die... Nissan wants $300 just to remove and see if it CAN be fixed...
Old May 6, 2006 | 11:36 AM
SuperStasiu's Avatar
If you pay that i will shoot you. You can get a new head unit for that much
Personally i have never had mine do that works fine since day one the only thing is the volume know sometimes i have to push it down so i can adjust the volume that way, but hey for a car i hae had since day 1 and now has 90k im pretty happy.
Old May 6, 2006 | 05:29 PM
Maxgig's Avatar
Have you run a CD lens cleaner through it? I put a Bose from a 02 Pathfinder in my Max and it skipped whenever I played burned discs until I cleaned the lens.
Old May 6, 2006 | 09:47 PM
icewake's Avatar
when mine does that i take the CD out and rub it on my shirt then put it back in. it has only done this to me once but that was my solution
Old May 8, 2006 | 06:18 AM
SkoorbMax's Avatar
I've not tried that. I've tried a bit of compressed air, but not a lens cleaner...that is probably a good idea, actually. Maybe I can replace the brush with steel wool and put this damn thing in its grave
dr3am
25
Oct 22, 2015 08:53 PM
jerrod99_se-l
Aug 27, 2015 08:27 PM
Samedi
Aug 13, 2015 04:05 PM
Flores94
Aug 13, 2015 01:17 PM
kenc15
Aug 5, 2015 08:29 AM
