2k2 Transmission Problems
Old May 3, 2006 | 01:48 PM
cpuguy06's Avatar
Hello all, today I was sitting in a parking lot, turned off TCS, put it in drive and did a pretty long burnout..on the way home trans felt like it was stuck in like 2nd or 3rd, it wouldn't take off. Got home, turned off, and turned back on and the AT Check light started flashing. I turned car off and then back on and it wasn't blinking anymore...took it down to the stealership and am having them check it out now.....anyone have any ideas?? thanks..I know its kinda vague and like most of the stupid posts on here, but if anyone has any ideas it would be great help thanks in advance guys!
Old May 3, 2006 | 01:52 PM
mtrai760's Avatar
'Trynna' is not a word
Stuck in safety mode. You could have just shut it off and reset the ECU yourself.
Old May 3, 2006 | 01:55 PM
SEmy2K2go's Avatar
Go BUCKS!!!
Idea #1: Quit doing burnouts in your Maxima.
Idea #2: Quit doing burnouts in your Maxima.
Idea #3: See ideas 1 & 2
Old May 3, 2006 | 03:38 PM
Y2k2maxse's Avatar
I had the same exact thing happen to me a few weeks ago. Dont know why it does it..it was the first and last time i do a burnout in the car lol but nothing to worry about turned it off..and than back on and it was fine. only thing was the intake sounded sick taking off in 3rd lol.
Old May 3, 2006 | 03:52 PM
cpuguy06's Avatar
ya, should have posted and then waited for a response before I took it in..I just thought with how bad our transmissions are(at least thats what Ive heard) I should take it in ASAP. O well I guess 2 hours and 80 bucks later....all they did was hook it up to the consult and take it for a ride and their like couldn't duplicate problem. I was trying to check the codes the ghetto method and the service guy saw me and then accused me of clearing the codes.hehe...I guess I should be happy he at least knew what I was doin with all the pedal stompin and key turnin I was doing..thanks guys!
vq356sp's Avatar
El Mas Noob Del Org.
Old May 3, 2006 | 05:46 PM
fall97's Avatar
I had this EXACT SAME ISSUE only I did not do burnouts. I had a post on here about my issue and no one knew what it could possibly be. The diagnostic code I got was P0720 I believe.
In any event, I did some research. The service manual states that it COULD be an issue with the connection between the ECM, TCM, and the revolution sensor. There could be a faulty sensor somewhere.
I took it to the stealership and after they cleared my check engine light and told me it was ok, 2 days later they had to check it again. I was informed that it could be the vehicle's speed sensor. This is a sensor on the transmission that tells it when to change gears. Called Courtesy and they said the part was about $40. I will need to see how it is installed before I buy it though. I will let you know the outcome.
Old May 4, 2006 | 07:33 AM
Maxima570's Avatar
When I first got my 6 speed, the most popular question from my friends was "did you do a burnout yet?" and my response was "no i just got it im afraid". I'm also afraid of paying for a new transmission. Autozone and Advance autoparts doesn't charge to check what the codes are, and sometimes they will clear it for you
Old May 7, 2006 | 07:23 AM
fall97's Avatar
Finally took it to the stealership. They let me know that my issue was a 'revolution sensor' - take a look at the workshop manual for the connections. The cost to fix/replace was about 250, this is after the 80 dollar discount they owed me for telling me nothing was wrong in the first place. In any event, go to the stealership and ask them about this issue; instead of telling you 'its the transmission, buy a new car' they will probably say 'we'll fix it for 330'.
If you are DIY, just get the part from courtesy nissan, I dont think there is any write up on how to install this, I have done a little research and I couldn't find one. If you can, let me know and post the write up! It would be helpful to those with this issue (seems common on high mileage max's w/ 95k+).
Again, if you have the work shop manual, you could probably do the replacement yourself if you are so inclined; it doesn't tell you explicitly how to do it.
Old May 7, 2006 | 07:40 AM
MxdOut97's Avatar
obviously none of you 18 year olds are paying for anything on your car so mom and dad will pick up the bill when you need new tires, a new tranny, or a new car. Just because its like that doesnt mean you can drive like a rebel and do whatever you want.....one day itll catch up to you.
Old May 7, 2006 | 08:16 AM
sciff5's Avatar
Hey man I'm just gettin on my own so I'm figuring it out... its insane how much some inflatable rubber costs.
Old May 7, 2006 | 09:16 AM
cpuguy06's Avatar
Ya, **** you, I paid for my tires, my car, and my ****ing transmission if that goes out so **** off.
Old May 7, 2006 | 03:39 PM
Zero Deuce SE's Avatar
From the looks of the location in the 2002 Max FSM it looks like the rev sensor and vehicle speed sensors are on the firewall side of the transmission and held in place by a single bolt. If you can access it from beneath you can probably disconnect the harness connectors, remove the bolt and replace the old sensor with a new one. The diagram on page AT-285 shows a good photo of the sensors locations.
Old Jun 17, 2006 | 03:18 PM
tmaculate1's Avatar
Any update on the location of these sensors? I had this same problem this week and diagnostic tests show that the Output Speed Sensor Circuit (P0720) is the cause.
Thanks for any updates you guys can provide.
Old Jun 17, 2006 | 11:40 PM
FriscoMaxima's Avatar
Maxima is classified as a FAMILY SEDAN... What do you say to your wife when you get home, "Honey I am home, let's go do burnouts!!!"???
Old Jun 18, 2006 | 12:20 AM
cpuguy06's Avatar
haha if a manufacturer makes a car such that it can do burnouts...why not...and if I had a wife...even one that wanted to do such things, then yes I would. But as I have learned from people on here, burning out does bad things to your car, so I haven't done so in a while.
Old Jun 18, 2006 | 04:54 PM
Hoooper
yay for people that know nothing. if it wasnt for them the world would have a clean gene pool. just because you do one burnout doesnt mean your saying f the world and trying to screw your parents. everyone here has either done a burnout or has an unbelievably boring life, and i feel sorry for you. in other words, yay burnouts, nay people with boring lives.
PS: i payed for my car and everything on it, including the tires.
Old Jun 18, 2006 | 04:57 PM
NmexMAX's Avatar
dot dot dot ...
A little defensive are we..
Old Jun 18, 2006 | 05:07 PM
fall97's Avatar
I had my work done on the 2k1, I did not see this in my workshop manual, but I will take a look
Old Jun 18, 2006 | 05:12 PM
fall97's Avatar
Thanks Deuce
Old Jun 18, 2006 | 05:28 PM
Thanks Deuce
You're welcome Fall97.
Old Jun 18, 2006 | 05:41 PM
cpuguy06's Avatar
I tried to say this in not so many words and got banned...thanks for rephrasing it in such a way...I can't believe people think that just cuz we are 18 we don't pay for our stuff...just because all the other people didn't work their asses off at 18 to pay for a nice max, doesn't mean were spoiled....thanks hooper!!!
Old Jun 18, 2006 | 05:45 PM
NmexMAX's Avatar
dot dot dot ...
SOME 18 y/o are ... Not ALL..
Old Oct 16, 2006 | 07:23 PM
BLK2BLU's Avatar
At least he is 18 driving a max and not a honda....
Old Oct 16, 2006 | 07:29 PM
NmexMAX's Avatar
dot dot dot ...
Posting in a 4 month old thread FTL
Old Oct 16, 2006 | 07:45 PM
streetzlegend's Avatar
Did you at least put it in 1st gear to do the burn out? or did you let it shift during the burnout?! next time u wanna mistreat your maxima like that, at least put it in 1st so it dosnt shift.
Old Oct 16, 2006 | 08:45 PM
BLK2BLU's Avatar
now we both have
Old Oct 16, 2006 | 08:59 PM
NmexMAX's Avatar
dot dot dot ...
I actually posted in it 4 months ago.....
But you dug it up, that's FTL... Where's my cookie.
Old Oct 17, 2006 | 12:28 PM
Teufelhunden's Avatar
heres your solution: stop doing burn outs on your max = no tranny problem =worthless thread avoided
Old Oct 17, 2006 | 12:48 PM
707SE's Avatar
I had a 93 Altima (auto no less) and was in love with the burn out until one day my reverse didn't work. The gears had all slipped after revving in neutral and slamming into drive for the peel out. The tranny was never the same but to fix it I had to rev in neutral and slam in reverse! Kinda scary with the jerk motion but it fixed it. I did that twice and the second time was the last. The solution above is the way to go
Old Oct 17, 2006 | 02:26 PM
sciff5's Avatar
Neutral drops... just about the worst thing you could do to a tranmission other than maybe roll backs.. congrats you should get a darwin award
sctludwig
Sep 1, 2022 01:32 PM
Mar 12, 2020 12:06 AM
boomerbrian
Oct 31, 2018 10:25 AM
The Wizard
24
Oct 1, 2015 08:47 PM
