Starts then dies unless I put it in gear
Old May 15, 2006 | 12:11 PM
Supreme Allah's Avatar
I've been noticing some sputtering starts in the past few days on my 2000 max, and today just during my lunch break when I started it, it would rev up to 1k rpms, then die down quickly and the engine would die. It did this two or three times until I started it, then QUICKLY put it in drive, and it stayed alive and drove without a problem. Could this just be dirty battery terminals, or... well I like to start with the easiest possible solution.
Old May 16, 2006 | 05:58 PM
trigger005's Avatar
Try throddle body clean
if that doesnt work then maybe its the MAF
Old May 17, 2006 | 11:58 AM
dank104's Avatar
sounds like the start of the maf going bad.
Old May 17, 2006 | 01:16 PM
chisam14's Avatar
I have almost the same problem with my 03 maxima with a 3.5. If it sits for about 45 minutes or longer it takes forever to crank back and sometimes dies. Nissan dealer cant figure it out. MAF, Throttle Chamber, fuel pump, regulators, CT sensor and air filter have all been changed but no progress has been made. After the pump was replaced it worked great for a few days and then starting messing up again, I took the pump out and looked at it and it worked a few more days and then started acting up again. If anyone has any suggestions let me know.
Old May 18, 2006 | 06:36 AM
nailz420's Avatar
Same here. Engine revs up higher than usual (to about 2k) then drops to about 600 like it's about to die, then comes back up to 1.4k. When it was cooler outside it would stall out sometimes , but that didn't happen in a while. I think it works better when I turn the ignition on, without starting the car and wait till the fuel pump primes, and then start the car.
Old May 18, 2006 | 03:23 PM
mockba98's Avatar
I have the same problem, except my car is stick shift. When I start the car it works fine but when i drive it, it stalls sometimes in neutral. I cleaned the throtlle body, it helped a little bit but the car still stalls. It does not however stall if i put the heat on the windows on. Can anyone telll me what i shoudl do. I have a 2000 maxima gxe.
Old May 18, 2006 | 05:46 PM
Wiredmax's Avatar
I got the same problem, as all of you guys and i have a 2003 maxima, its been in and out of the dealership as well as my private mechanic and no one could figure out the problem yet...
Old May 18, 2006 | 06:03 PM
mockba98's Avatar
I dunno, Ive been told that it might be the 02 sensor, have any of you tried replacing it? And the weird thing is that the car stalls when it feels like it. One day it might drive without stalling and an hour later it might stall everytime i put it into neutral. Its just annoying to drive. Im trying to get it fixed.
Old May 18, 2006 | 06:08 PM
Wiredmax's Avatar
Yup that sounds like my car, i actually having 02 sensor problems, that i am trying to get resolved, but no one can figure it out, ever since i got my headers and exhaust installed, i have had this problem
Old May 18, 2006 | 06:10 PM
mockba98's Avatar
My car is stock and its having the problem. What are the possibilities you think that might be wrong with it?
Old May 19, 2006 | 06:55 AM
dank104's Avatar
i don't think it's the O2 sensor b/c when it goes bad you usually don't know notice any change in normal driving. a bad O2 sensor may give you horrible gas mileage though.
Old May 19, 2006 | 07:02 AM
nailz420's Avatar
Well, I have horrible gas mileage (around 12mpg), but I attribute it to the fact that I drive 2-3 miles a day in Brooklyn traffic and most of it looking for parking. Btw, I have a torn exhaust ground and I read somewhere that could hurt the gas mileage due to lowered O2 sesor readings. Just out of curiosity, anyone else has that?
Old May 19, 2006 | 07:16 AM
cash_ims's Avatar
I'm having the same problem to. Sometimes my car will go for days without stalling. Then all of a sudden, on ramdom days it will die when i'm idle on drive or when i put it on park. I've had the throttle body cleaned but hasn't changed anything. I own a 2000 Maxima GLE
Old May 19, 2006 | 07:20 AM
pkchoban's Avatar
in most cases that i have heard about this problem or have come in contact...the best case scenario is it is the MAF or a Faulty new MAF the worst case scenario to fix this problem is replacing the computer...yeah it hurts
Old May 19, 2006 | 07:21 AM
nailz420's Avatar
You do not have the same problem. Your car dies while you drive, or after you already started it. The original post refers car dieing when you just start it, not after.
Old May 19, 2006 | 08:20 AM
samsonite's Avatar
Got my money on the MAF sensor. That sounds exactly like what happens when the engine starts getting funky readings from incoming air. The air/fuel gets all fubared. might want to try cleaing it. see if it gets better. If it does then just go ahead and replace it. I cleaned mine and it ran great but only took about a week before symptoms started reappearing. I am going to just replace it. Good luck.
Old May 19, 2006 | 08:22 AM
nailz420's Avatar
I cleaned it with the MAF cleaner mentioned on the board earlier. Didn't help much.
Old May 20, 2006 | 06:40 AM
super6's Avatar
DUDE, i have the same problem, i changes maf and IACV!!! wht did u do to fix it, do u still have the problem????
Old May 20, 2006 | 02:02 PM
nailz420's Avatar
Still have it. Didn't do nothing.
CorollaULEV
30
Aug 9, 2021 08:11 PM
Samedi
24
Apr 19, 2016 12:49 PM
305head
Aug 26, 2015 09:03 PM
Maxboy23
Aug 11, 2015 11:59 AM
sc10692
Aug 9, 2015 09:37 AM
