Big Thanks in order!!!!! IRISH44J AND EVERYONE ELSE INVOLVED
Old May 16, 2006 | 06:55 PM
doc2278's Avatar
Doctor D I presume???
A BIG THANK YOU to Irish44j and everyone else involved in the pcv blow-by unit project. I installed this mod recently and wow power is returned!!!! no more retarded timing due to bad mixture!!!! So my hat is off to all involved.THANKS AGAIN.
Old May 16, 2006 | 07:00 PM
irish44j's Avatar
retired moderator
no prob...though I certainly wasn't the first to do this or write it up
Old May 16, 2006 | 07:08 PM
00MaxSE's Avatar
Pointy Elbows
Wow, I'll def need to be doing this soon.
Old May 16, 2006 | 08:28 PM
LA02MAX's Avatar
just got all my supplies today
all i could find was the clear braided tubing, but i want to look for some high temp black tubing...it'll just make me feel better
Old May 16, 2006 | 08:32 PM
steven88's Avatar
Need A Light?
hope you enjoy it doc...let us know how much you collect...
Old May 16, 2006 | 09:00 PM
mforrest100's Avatar
Is this for 3.5 engines? Will I benefit since I will be swapping a VQ35 in my car or does it have to be in a 5th gen??
Old May 16, 2006 | 09:58 PM
steven88's Avatar
Need A Light?
it can be any car for that matter...as long as it has a pcv valve...
Old May 17, 2006 | 05:15 AM
bpe383's Avatar
That clear hose isn't the best stuff. I used it and it got hot then Collapsed in the bends. I ran a much shorter peice than the pic, because I didn't like the look of that long hose running all over the engine area.
Advance auto parts has hose made just for the PCV valve.
I tried fuel line but it to collapsed. Even if the hose feels strong the heat kills it.
Keep in mind most of the hose people are using is designed to take pressure not vac.
Old May 17, 2006 | 07:11 AM
rbrown81's Avatar
But why is teh Rum gone?
Im going to see if I can get some custom stainless steel braided line fabricated for the job. Have to find a place locally that will do it without charging an arm and a leg.
Old May 17, 2006 | 07:43 AM
beancooker's Avatar
Thanks for the good idea Irish44j. heading to home depot today. You should do a step by step for this mod. The hose connects back to the crankcase under the VIAS right?
Old May 17, 2006 | 07:48 AM
merovi's Avatar
how come when I did mine I could hear a very audible suction (or blowing don't remember which one now) noise. I inatalled everyting correctly but I could hear airflow that I couldn't hear before, and it was comming from where my pcv valve was. Is it just me? Was it the wrong hose? or is that normal?
Old May 17, 2006 | 07:59 AM
kcowden's Avatar
Mine made the same noise. I have to assume it's normal because I've had mine on for about 6 months now with no problems.
Old May 17, 2006 | 12:00 PM
doublea's Avatar
Hey guys, sound like a nice little project to do over the week-end. Where can I found the part list ?
Old May 17, 2006 | 02:19 PM
doc2278's Avatar
mos def steven88!!!!!!. so far in just a day of driving I had collected enough to fill a small thimball. thats alot for one day!!!!
Old May 17, 2006 | 02:20 PM
doc2278's Avatar
try power steering line, made for heat and pressure
Old May 17, 2006 | 02:22 PM
doc2278's Avatar
sounds like air is leaking from the lines, get some air line fittings to tighten the hose down ( home depot) compressor fittings section in hardware. see if that works
Old May 17, 2006 | 03:03 PM
Glude's Avatar
I wanna do this for my 6th gen, anyone have a link to the 3.5 write up?
Old May 17, 2006 | 03:18 PM
nicks79's Avatar
yeah, where is the real link?
user 11122324
42
Jul 18, 2022 03:35 PM
mkaresh
Mar 12, 2018 06:48 PM
bigfrank
Oct 1, 2015 12:51 PM
Marc2theMax
Sep 28, 2015 08:13 AM
