"performance" alignment?
Old May 23, 2006 | 05:13 AM
Y2k2maxse's Avatar
I was reading that some people that like to drive more aggresivly sometimes get their alignment done in a performance tune. this means setting the camber and toe and all that good stuff to the maximum for performance...but WITHIN the manufacturers suggested range. say for example (completely random) the camber should be within 1-10 usually set at 5 by the factory...10 being the performance side they would set it at ten, get what I mean? anybody have this done? I am getting new tires so also getting an alignment..thought id give this a try.
Old May 23, 2006 | 07:56 AM
Edward Lee's Avatar
Camber? Just tow, unless you get a camber kit.
Old May 23, 2006 | 11:36 AM
Y2k2maxse's Avatar
this is what it said:
performance alignment consists of using the vehicle manufacturer's range of alignment specifications to maximize the tires' performance. A performance alignment calls for the manufacturer's maximum negative camber, maximum positive caster, and preferred toe settings. While remaining within the vehicle manufacturer's recommendations, these alignment settings will maximize tire performance. (copied off of tirerack.com)
Old May 23, 2006 | 11:47 AM
DrKlop's Avatar
Driving is the next best thing
Here's a good guideline for what you are planning to do:
http://www.nissanclub.com/forums/nis...k-part-ii.html
Old May 23, 2006 | 03:49 PM
irish44j's Avatar
retired moderator
on a maxima, camber and caster are NOT adjustable from the factory - only Toe angle.
the only way to adjust camber is with camber bolts (which are unreliable) and camber plates (which are difficult to find, since Stillen no longer makes them).
NewMax03
Oct 7, 2015 08:27 AM
06maxima55
Sep 28, 2015 04:29 PM
DC_Juggernaut
Sep 28, 2015 04:07 PM
ivorton23
Sep 26, 2015 09:47 AM
