LTB question
Old May 26, 2006 | 12:23 PM
98SEdriver's Avatar
LTB question
searched using google and its advanced search feature on here but did not come up with everything i wanted to know about the stage 1 ltb.
i'm pretty sure i want the stage 1 because the only suspension mod that i have made so far is the rsb.
to those of you who have installed it yourself, is it easy? i did the rsb myself, but found two write ups, plus the bar came with instructions so i felt confident with attempting it myself.
does anyone know of a link to a write up on installing this bar?
thanks in advance.
Old May 26, 2006 | 02:19 PM
irish44j's Avatar
retired moderator
thanks in advance.
The stage 1 is super-easy to install....all you do is remove the control arm nut, and loosen the lower bush pin bolts (4 in a row, you'll see what I'm' talking about). Slide the bar on. Tighten bush pin bolts Snug, but do not torque down control arm nut yet. Lower car to ground. Torque down control arm nut now. Done.
The stage 2 required a bit more muscle/work...
Unclejunebug
Apr 2, 2016 05:42 AM
Stagnet04
Oct 11, 2015 08:16 PM
Socalstillen
Sep 26, 2015 12:01 PM
