HELP - Changing Brake Pads, QUESTION
Old May 29, 2006 | 07:23 AM
Metal Maxima's Avatar
SHIFT_om nom nom nom
Crap, looks like I forgot to pick up a piston compressor tool. Should I just hold off on this until I get one? Or can this be done without one?
Old May 29, 2006 | 07:36 AM
doc2278's Avatar
Doctor D I presume???
I'd definitely get one or else you might spend a couple of hours trying to compress the pistons in the rear, the fronts I used a large c-clamp and opened up my brake fluid container.
Old May 29, 2006 | 08:04 AM
Thanks, Doc. I'll give ya a ring if I hit any more stumbling points. First rotor/caliper is off, we're past the ppoint of no return!
Old May 29, 2006 | 08:45 AM
doc2278's Avatar
I was gonna say you starting with the rears was the best way to go,.... get the most difficult part out of the way first.
Old May 29, 2006 | 09:02 AM
ozzombie13's Avatar
I will eat your children
i have a caliper compressor for the fronts but not the rears and im usually hengin out with doc
Old May 29, 2006 | 10:13 AM
merovi's Avatar
i just used something flat, like a piece of metal, lay it across the piston, and a c-clamp to push it in. It usually works pretty well.
Old May 29, 2006 | 10:21 AM
Well...everything seem to be moving along right now, but it would seem as through compressing this piston (even with the tool) is a tad tou8gher than I thought it'd be.
Old May 29, 2006 | 10:37 AM
Supreme Allah's Avatar
Yeah a C Clamp for the fronts is plenty. They shouldnt be very hard to compress... did you unscrew the brake fluid reservoir cap? You want to make sure you're not pushing up fluid into the tightened cap, and also put some towels around it in case fluid leaks out.\
(last time I only had the c clamp and no piece of wood, I was holding the thing with one hand like a juggler and screwing and balancing with the other, I looked like a spaz..but i got it in the end)
Old May 29, 2006 | 11:00 AM
meccanoble's Avatar
Sports Button FTW
that piston is a b!tch to compress even WITH the tool. Well the fronts are easy but the rear is going to **** u off. Its a little different and u have to do a spinning compress instead of just pushing in. Get the tool, definitely.
Old May 29, 2006 | 11:02 AM
Yeah, ozzie is coming over to help me out. I feel like I have been turning this thing for an eternity and am making no progress. I am reapy to flip out.l
Old May 29, 2006 | 11:37 AM
n3985's Avatar
大陆弟弟
Instead of turning the little handle thing, take a wrench and turn the nut right before the handle.
Old May 29, 2006 | 12:28 PM
Lontar1's Avatar
Puerto Rico-Maxima Lover
check the seal.. if it is broken add some lubricant in... will make your life easier..
Old May 29, 2006 | 04:05 PM
Welp, everything is done. Matt (ozzombie13) came over to help me, of which I cannot thank enough. Also, big thanks to Chris (doc2278) for his help.
A quick review:
REARS
What a nightmare. The rotors came off with no problem...in fact, taking everything apart was no problem. The rear piston, however, WAS A NIGHTMARE. It took my brother, Matt, and myself to torque it down.
FRONTS
Pretty simple for the most part. Probably took about 50 mins for rotors and pads on the front. The torque member mounting bolts were seized as all hell, it took quite a bit of muscle to break them free. We also used some PB Blaster (Matt, btw, you left it here. ) to free them up.
All in all, this was pretty straightforward, but had its hangups. Glad it's over, and glad I know wtf I am doing for next time.
Old May 29, 2006 | 04:13 PM
doc2278's Avatar
A quick review:
REARS
FRONTS
no prob Dan...... I am glad you guys got it done... envious that matt got to see your interior before I got the chance LOL!!! I know those brakes can be a job!!! I have got to do my fronts again soon (Like a month from now).
Old May 29, 2006 | 04:46 PM
Don't be jealous in the least, dude. The interior is close to being done, but not quite done yet. The interior was a bit dirty, I have some LED bars to mount, the new (never before tried) cluster mod is not in, and all of the amps are out (fging the trunk...thread to come in a few days) Besides, you need to see it at night to truly appreciate it.
Thanks again, man...couldn't have done it without you guys!
Old May 29, 2006 | 05:09 PM
ozzombie13's Avatar
ill get it off you some time any way its not like its too expensive
Old May 30, 2006 | 12:03 PM
1MaXXfan's Avatar
Rears
Saw it in a thread from way back. But go to sears and get the brake tool from the hardware section for foreign autos. It attaches to a wrench or power tool, spin and the piston turns right back that way, without it the job is really crazy.
I tried it with pliers like crazy thing to do.
http://www.sears.com/sr/javasr/produ...seBVCookie=Yes
rbuswell
Nov 17, 2016 04:54 AM
homeyclaus
Sep 3, 2015 06:15 PM
Cant_Get_Ryte
Aug 28, 2015 06:41 AM
MAXSE5SPD
Aug 23, 2015 12:06 PM
RealityCheck
Aug 5, 2015 06:18 AM
