Polyurethane Bushings on 2003 Max
Old May 31, 2006 | 10:49 PM
dansmax2003's Avatar
I just received my LTB Stage II from BlehmCo. What a great guy to deal with. Product looks very nice too.
To my questions ...
In the instructions on how to install the LTB, it says that it is a very good idea to install "Polyurethane Bushings" while doing the LTB install. My car has 80k+ miles on it and i am sure that the original OEM bushings are getting old. It may not be a bad idea to do it now. Am i wrong??
1. Are new Polyurethane Bushings a good idea/nice improvement? Any negative sides? They are not cheap, so i wonder if it is all worth it??
2. Do i need new Polyurethane Bushings only for the control arms? Do i need to replace them on the sway bar as well or this is too much extra/unnecessary work?
3. Where is the best place to buy Polyurethane Bushings for 2003 Maxima? I can't find more than one place that sells them.
Thank you in advance!
Old May 31, 2006 | 11:53 PM
ecsdesignz's Avatar
Codename: Frankie
I think Cattman had good deal on Energy Suspension bushings also check Redlinemax.
I would do it while you install the LTB, nice and stiff not all floaty like the rubber stock stuff.
Old Jun 1, 2006 | 04:43 AM
Puppetmaster's Avatar
To my questions ...
They are worth it. The front sway bushing replacement is supposedly really easy too.
http://www.suspension.com/nissancars.htm
http://www.sportcompactonly.com/ (talk to Steve G aka Y2kSESteve)
http://www.mattblehm.com/ (talk to Matt Blehm aka Matt93SE)
Old Jun 1, 2006 | 08:53 AM
Thank you!
I just ordered a control arm set and sway bar set from http://www.sportcompactonly.com/
Lets hope that the install will not be complicated.
Thanks!
Old Jun 1, 2006 | 09:10 AM
Thank you!
Thanks!
This should help:
http://doug.maxima.org/showpost.php?...29&postcount=2
Max139617
Oct 19, 2016 11:34 AM
Starrider
Dec 18, 2015 04:43 AM
Maximan190
Dec 16, 2015 06:01 AM
NewMax03
Oct 7, 2015 08:27 AM
