Slotted rotors and stock pads
A little history here first, I installed the Blehmco BBK kit about 10k ago, with 05 Zinc plated and slotted iRotors. Warping is gone, but when I brake hard or come of an exit ramp for example, the brakes make a crazy sound, and vibrates the car(not warping vibration but like buzzing). I know slotted rotors tend to hum but this is so bad the rearview mirror shakes like I have subs in the back and passenger ask me if my car is ok.
is this because I have stock pads still on? or is it really the slots in the rotors?
I'll try get some video up.
did I little check up this weekend on the problem and this is the result....glad to be alive.
http://filebox.vt.edu/users/prpatel/Maxima/IMG_1752.JPG
Yeh the metal thing on the left is my brake pad...now i'm rolling Hawk HPS...love em. again glad to be alive.
Originally Posted by SEmy2K2go
Uhhh, where's your back pad? Those look older than the front ones.
Originally Posted by Jeff92se
Nice guess
Your pad was worn down to the metal in just 10k?
Was only outside pad worn down? How much friction material was left of the inside? What about the other front wheel?
That looks to me like your caliper is seized, or possible needs some grease but with that much dragging its probably bad. You'll want to replace them both and since you already have pads I would get unloaded calipers, that should solve your problem.
Originally Posted by ryant35
And my slotted rotors are as quiet as my stock rotors.
Originally Posted by maxS
more bbk problems... did you check if your pads have full sweep area/contact with rotors, i.e. do not hang over the edge of the rotors....
BTW great choice in pads pri63
04-16-2020 05:15 AM
