Aftermarket Clutch for a 6 speed maxima
Old Jun 2, 2006 | 01:43 PM
vsamoylov
Alright I am looking for opinions. I know there are people that have upgraded from a stock clutch to a aftermarket unit. Any recomndations on brands? I remember some people had problems with certain brands and some people had clutch chatter on take off. Thanks guys
Old Jun 2, 2006 | 01:54 PM
Nismo3112's Avatar
Custom User Title
If you are sticking to lower power levels, the stock one should be just fine.. Tilley showed us just how strong the stocker is.
Old Jun 2, 2006 | 04:21 PM
steven88's Avatar
Need A Light?
stock would be awesome...heard it holds alot of power....i've beat the crap out of my car before...and it didnt slip once, on back to back runs
its a good price at about $240 shipped from dave B...can't go wrong
Old Jun 2, 2006 | 04:22 PM
steven88's Avatar
Need A Light?
btw, does anybody know if its okay to slap on a fidanza flywheel onto a new oem clutch?
Old Jun 2, 2006 | 07:23 PM
Woody's Avatar
You can do it, but you will have an unsprung clutch, and flywheel.
Old Jun 2, 2006 | 07:35 PM
steven88's Avatar
Need A Light?
so whats the results of doing that?
Old Jun 2, 2006 | 08:14 PM
vsamoylov
also is it true that you can use a clutch from the 350z? i cant remember who it was that did it. reason i am asking is that there are more options for the 350z then the maxima guys.
Old Jun 2, 2006 | 09:03 PM
Derrick2k2SE's Avatar
More shock to the tranny on hard shifts. The stock disk is solid with the stock flywheel being dual mass and absorbing some of the shock. Most aftermarket disks are sprung which absorbs some of the shock.
I can't say if it would cause an issue but it will send more of a direct slam to the tranny.
I would definately avoid running the stock flywheel with a sprung disk because I had a lot of chatter with that setup. Too much moving around in there. The chatter went away when I put the Fidanza in with the same disk.
Old Jun 2, 2006 | 09:09 PM
I know we've been talking but for everyone else. 350Z pressure plate and disk will work on 3.5 Maxima. 350Z flywheel will not work without modification.
The reason to know this is a lot of aftermarket clutch makers don't market a Maxima clutch but do market a 350Z clutch. It bolts in with no modification.
Old Jun 8, 2006 | 12:49 AM
claudiusmaximas's Avatar
thanks for the info
Old Jun 8, 2006 | 09:52 AM
getbigtony's Avatar
more options in the Group Deal
Old Jun 8, 2006 | 08:13 PM
inspiredbykev's Avatar
You should thank my D***
check out my threads
http://forums.maxima.org/showthread.php?t=457994
http://forums.maxima.org/showthread.php?t=462847
schmellyfart
Sep 25, 2015 04:47 PM
MikesChevelle
Aug 10, 2015 10:53 AM
sc10692
Aug 9, 2015 09:37 AM
PhalC1
Aug 5, 2015 02:36 PM
