Need Help - Coolant TB Bypass
Old Jun 4, 2006 | 03:17 PM
MaxHind's Avatar
Hey if anybody know's where the hoses that carry the coolant into the TB are please tell me, I think i found one on the foward side of the TB but am unable to find the other hose. Please help, I already got the 1$ part to do this. Thanks in advance!!!
Old Jun 4, 2006 | 03:31 PM
5thgenmaxima's Avatar
TB? Throttle body?
Old Jun 4, 2006 | 03:32 PM
MaxHind's Avatar
yea __________
Old Jun 4, 2006 | 03:36 PM
Never heard of bypassing the coolant flow thru it. To prevent the coolant from heating the air I assume?
Old Jun 4, 2006 | 03:39 PM
MaxHind's Avatar
yea its a cheap mod, its from the factory to prevent freezing up during hard winters... I live in FL and never need it. so to bypass a 190 degree fluid through my TB i bought a little metal hose joint. Just cant find\locate both of the hoses.
Old Jun 4, 2006 | 03:47 PM
Intresting....
Find your thermostat and see if there is a hose connected nearby going to your tb
Anyhow free bump
Old Jun 4, 2006 | 05:37 PM
MaxHind's Avatar
help anybody? bump
Old Jun 4, 2006 | 09:15 PM
xlcrew's Avatar
I’m Back
the hose goes in on the bottom and out on the front side. if you look closely you'll see it.
Old Jun 5, 2006 | 07:44 PM
MaxHind's Avatar
Found it!!! Thanks xlcrew, It was a BIZZO to get to but ultimatly snagged it. Used a 1\4 hose joint (metal) from home depot for like $2 and some 60cent screw clamps. Thanks for the help!!
Old Jun 5, 2006 | 08:19 PM
sciff5's Avatar
my buddy did this with his camaro and the tb got stuck at wot so make sure you live somewhere warm if you do it.
Old Jun 5, 2006 | 09:40 PM
Before you do this warm your engine up and pull your intake off. Feel the inside part of the TB. My guess is that it doesn't get much warmer than IAT anyways. Maybe I'm wrong.
Old Jun 6, 2006 | 05:16 PM
MaxHind's Avatar
I live in fl and the coldest it gets here during winter may be in the high 20's at sunrise. other than that most of winter is in the 40's. I usually let my car warm up those days anyway (which are few days of the year). Engine coolant sits around 190 degrees if im not mistaken.
Old Jun 7, 2006 | 08:56 AM
VQ30GTR's Avatar
I do not understand how this kept his camaro stuck at wot? I had a96 Pontiac Grand Prix and it had the same feature. Last I checked Coolant will not freeze, even here in Chicago.
Old Jun 7, 2006 | 10:03 AM
sciff5's Avatar
Well the coolant isnt running through the TB thats the whole point of the TB bypass. So the coolant really has nothing to do with it. I think my buddies TB started to freeze up because I know as air moves fast it gets colder. I dont know why. And I know when that air is high in humidity as the temperature of the air goes down the water becomes ice crystals which I guess started to collect around the TB.
Old Jun 7, 2006 | 11:34 AM
9DTALON's Avatar
The coolant flows through the IACV valve. It is primarily used to heat the cold idle wax pellet type thermo valve. This valve allows more air to bypass the TB at first start up then as the coolant warms up the wax expands and closes the valve. If you live in a cold state you may not want to do this.
Old Jun 7, 2006 | 11:52 AM
20max01's Avatar
fyi, I am mostly a Mustang guy, this is an old trick we used in the late 80's early 90's to keep the hot coolant from heating the TB, does a teenie tiny bit, but most used to advise against it, when the car is warm it keeps hot coolant from heating the metal of the TB...if anything its maybe .5-.75HP ...not worth the time IMO....
Old Jun 7, 2006 | 01:22 PM
MaxHind's Avatar
I think your partly correct. Air temp does drop when it moves through an area of low pressure but this senario usually only happens in carbureted engines. The main part of the carburetor is called the venturi which would usually be the point where carb. Ice would form. It can happen in almost (Low RPM's) any time up to and sometimes above 70F with higher humidity. I never heard of TB icing before, but maybe somewhere in hard winters it may cause some problems without the coolant.
Miket2006
Mar 1, 2021 03:55 AM
05' MaximaMan
Oct 8, 2017 06:36 PM
captchaos
Mar 15, 2016 12:18 PM
msellas
Sep 23, 2015 09:16 PM
junito1
Sep 23, 2015 12:14 PM
