LED upgrade for climate control and stock headunit
Old Jun 4, 2006 | 07:35 PM
frankd121's Avatar
Does anyone have a link for a HOW-TO on this? I've tried searching for it, but am not having any luck finding it. Thanks.
Old Jun 5, 2006 | 09:17 AM
sarmstrong's Avatar
Try this.. http://forums.maxima.org/showthread....54#post3542154
Old Jun 5, 2006 | 10:30 AM
frankd121's Avatar
yeah, i found that earlier, but i'm not sure where to solder the leads of the LED's to...
does anyone have pictures? that would help greatly too.
Old Jun 5, 2006 | 12:43 PM
sarmstrong's Avatar
i know that someone has a link to their own site that shows step by step instructions with pics....not sure who that was.
Old Jun 5, 2006 | 05:05 PM
frankd121's Avatar
bump...does anyone have a write up???
Old Jul 25, 2006 | 07:08 PM
illlojik's Avatar
I C U
bump, I believe Metal Maxima would be the man to help us out.
Old Jul 25, 2006 | 07:50 PM
irish44j's Avatar
retired moderator
this should help you a bit...this is mine:
sorry, I don't have a real write-up though...
Old Jul 25, 2006 | 08:01 PM
illlojik's Avatar
I C U
I saw the thread for that one. Great job btw, however, I'm looking help on the Auto Climate Control. That one uses those weird twist in bulbs. I'm trying to recall, I believe Metal MAx said something about just using the stock bulb holder to hold the led and twist it in.. something like that. Pics would be great.
Old Jul 25, 2006 | 08:04 PM
irish44j's Avatar
retired moderator
mine pictured above is the auto climate control....I drilled small holes the size of the LEDs into the backside of the clear grid and stuck an LED in each hole (glued)...the 3-4 stock bulbs are gone, and the LED series is wired directly to the lighting power wire....
Old Jul 25, 2006 | 08:11 PM
illlojik's Avatar
I C U
Hmmm really now? I didn't see that plastic peice inside the assembly, the only thing remotely looking like that is the plastic difuser(sp?) that illuminates the hazard light. I'll take a look again tommorow just to be sure.
Old Jul 25, 2006 | 08:19 PM
irish44j's Avatar
retired moderator
I assure you, it's there
IIRC, you have to pull off the circuit board of the climate control. When you take the climate control apart, the clear grid piece is sandwiched between the board and the front buttons. It's held in by 3-4 little clips on the sides - careful when pulling it out, they are pretty fragile, as is the entire grid piece (i broke mine in half and had to glue it back together)
Old Jul 25, 2006 | 08:23 PM
illlojik's Avatar
I C U
Now that you mention the position I'll def check again. What size Leds did you use? Also did you use any resistors,which ones 510, etc??? Thanks
Old Jul 25, 2006 | 08:28 PM
irish44j's Avatar
retired moderator
IIRC I used 3mm 50mcd red clear LEDs.
I did two "chains", one with a 1ohm resistor and one with a larger resistor (less LEDs in that chain). I'm not really a pro at LED stuff, I just winged it and it worked after some trial-and-error.
I got the LEDs at www.eleds.com, which are very high quality...none of them has failed or burned out after a couple years having them in the dash, switches, etc....
Sorry can't remember the specific part numbers or power of the LEDs...
Old Jul 25, 2006 | 08:31 PM
illlojik's Avatar
I C U
no prob. Thanks anyways, I'll check out Radio Shack tommorow and see if I can work with what they have.
Old Jul 25, 2006 | 11:45 PM
Yayomax's Avatar
still brewin'
I've been to radio shack a few days ago to replace my damn bulbs, as all mine are blown. They have a vast selection of L.E.D.'s. I never got any cause I didnt know what watts, amps, or what resistors to get.
Old Jul 26, 2006 | 05:19 AM
zero2sixtyZ's Avatar
You embarrass me.
Irish, nice work on yours. I like the red.
Personally, I want to do the superwhite look even brighter than stock, but just wish there was a better how-to. The lights above the shifter area are my main concern.
Old Jul 26, 2006 | 05:57 AM
illlojik's Avatar
I C U
I believe this is what you may be looking for:
http://forums.maxima.org/showthread....hlight=leds%5C
Old Jul 26, 2006 | 09:50 PM
XyNoix-HIC's Avatar
ok ok this is for the radio
http://www.cardomain.com/ride/631349/3
if metal's one is hard to figure out
Old Jul 27, 2006 | 05:07 AM
Pri63's Avatar
check out my cardomain site also I did my stock unit and auto climate write-up
http://www.cardomain.com/id/626dx
Old Jul 27, 2006 | 05:44 AM
djfrestyl's Avatar
Suspension Yoda
Wow Josh, that looks real good
BkGreen97
Apr 2, 2016 05:47 AM
Maxboy23
Sep 9, 2015 10:37 AM
Maxboy23
Sep 4, 2015 06:04 PM
