Painted '00 Headlights Pics
hey man I live in rochester. Would you want to give me a had doing this? I'm tempted to try it myself but if I screwed up a headlight, i'd be out a headlight. It would be nice to have someone who has done it before to help out.
No worry the mod is very easy just search for write ups there a hundreds. I have done it myself it seems like a big and iffy job but it is really easy no need to be scared of it. Just search one recommend I will make is instead of rubbing use duplicolor glossy black engine enamel it matches the grill perfectly in 00-01 and gives a nice gloss. Also a pro is since it is engine enamel you know it will alst and you wont have to redo the project for any reason.
Originally Posted by spdfreak
Do you have a writeup...or better yet, where did you get the writeup from?
http://www.vqpower.com/v2/modules.ph...howpage&pid=88
Originally Posted by Metal Maxima
Is that BLOOD on your one headlight?
Prob is, I get it when I run people over...
Don't let it go for long, it gets hard to clean off after a few days... That and the cops start to ask questions.
Originally Posted by dustrman03
Are those bugs? I sure hope not.
I tried following studmans tutorial I found it worked better just with out wrapping the headlight in a towel, I just set the light on the moist towel.
fyi... I used flat back high temp grill/stove paint
Originally Posted by ColdSHO
i wouldnt think paint would stick well to the chrome so thats why i just rubbed it off. either way they turn out the same way, rock on!
Originally Posted by TDotMax
Thats what I did, man did it take forever. I was sore from first getting the housing apart.
I painted the corners on mine as well. Duplicolor engnine enamel stickes very well to anything. I would use the glossy black color. I also used paint promotor before the black coats (3 light ones). I was scared that painting the corners would screw up the output but it is fine both in daytime and night time. Plus cant see the ugly yellow bulb.
Originally Posted by BRINKLEY
do you have a close up of what you did, looks good but hard to tell. thanks
Also those worried about output should not be worried, the corners light up and are visible in bright daylight when indicating.
doctorpullit
Apr 23, 2017 05:35 AM
tv314
Apr 5, 2016 04:54 PM
zzznightmarezz
Sep 21, 2015 06:32 PM
Hdnseek
Sep 9, 2015 05:55 AM
