3.0 liter spark plug gap
Old Jun 16, 2006 | 10:48 AM
alextothestars's Avatar
im a 3rd gen owner; doing an oil change and replacing spark plugs on my dads 5th gen for fathers day. what is the correct gap size? forgot to ask guy at store/guy at store failed to tell me. thanks.
Old Jun 16, 2006 | 11:00 AM
Progress's Avatar
It's business time.
I suggest you return whatever you bought and get the stock plugs that are pre-gapped.
2 cts.
MerlotMax's Avatar
gap is .044, alway check the gap: BKR6ES-11 should already be gapped @ .044 from the factory.
The "-11"=1.1mm=.044.
Old Jun 16, 2006 | 12:05 PM
these are just bosch platinums...definitely not gapped at .44 yet, lol; the 6 i put in my 3rd gen 5 months ago were pregapped, though. different plugs, man.
Old Jun 16, 2006 | 12:50 PM
MerlotMax's Avatar
Please note gap is .044 not .44, be awful tough to gap a plug @ almost 1/2 an inch.
Old Jun 16, 2006 | 02:03 PM
yes i know; im tired. they are pregapped (about .045). got the oil going...no where the hell are the spark plugs? all i see are fuel rails/injectors. does the intake manifold need to come off? lol
Old Jun 16, 2006 | 02:09 PM
Metal Maxima's Avatar
SHIFT_om nom nom nom
Usually I'd flame a question like this to the high heavens and back, but I too am tired.
Look at the engine block. You will see 6 wires leading into 6 black round plugs. These plugs will all be individually secured into the block with a 10mm bolt. Remove the bolt, pull out the iginition coil. Inser a LOOOOOOOOONG spark-plug removal head, ratchet out. Good luck. The ones in the front are a peice of cake. The ones in the rear...ugh, not so much.
ALSO, BE VERY CREFUL WHEN RETHREADING THE COIL BOLT BACK IN!!!!
I stripped one of the threads on the block and had to use a helicoil kit to get her working again. Take your time, post if you get stuck. GL
Old Jun 16, 2006 | 03:14 PM
where on the engine block? i found three frontal crash sensors underneath the "3000" engine cover. lol...could see it all a lot easier if there were a distributor.
Old Jun 16, 2006 | 03:30 PM
MaxBoost925's Avatar
Drug Money
those are coilpacks.
crash sensors?
Old Jun 16, 2006 | 03:45 PM
trigger005's Avatar
Originally Posted by MaxBoost925
BIG TIME.
those r fuel injection coils
unscrew 10mm bolts keeping them in tact, unplug the harness connected to them and pull them out
the spark plugs are deep underneath them
the other 3 are at the very top of the engine bay above the manifold
those are the hard ones to get to
u seem uber clueless so i'd recommend u take it to shop or dealer to get it done
Need help
23
Oct 2, 2015 08:56 AM
wiseguy6199
Sep 29, 2015 05:00 AM
dshinn
Sep 26, 2015 08:07 PM
zmcneely13
Sep 26, 2015 02:26 PM
