Anyone do housecor's rear window wind noise fix?
Old Jun 16, 2006 | 10:19 PM
n3985's Avatar
大陆弟弟
Has anyone attempted this?
http://www.innerbean.com/housecor/wi...ind_noise.html
I'd like some tips to remove the window seal. Do I just pull on it? Use a flat head?...etc.
And any testimonial as to how much it reduced wind noise would be great too. Thanks!
Old Jun 16, 2006 | 10:38 PM
OutMaxxed's Avatar
i did it on my max and it helps alot. My mom drives an i35 and it is so dam loud, i dunt kno how rear passengers can tolerate it. Just pull on it on the corner. And u just have to put the stripping in the right area's. I mean its not dead quite like some cars on the highway but like i said b4, it helps ALOT. Its and inexpensive fix n takes like 15 min max. Just do it, what do u have to lose?
Good luck
Old Jun 17, 2006 | 06:55 PM
getbigtony's Avatar
yea like he said, just pull. almost the whole top will go, except the part all the way by the front, cuz its bolted on up top and right under the window. u can pull it right off by the little quarter window too. it is a metal beam that holds the rubber fitting
Old Jun 18, 2006 | 01:54 PM
BLK2BLU's Avatar
I only did the rear left and can tell the diff in the driver seat. I still have to do the right one tho.
Old Jun 18, 2006 | 02:21 PM
Lontar1's Avatar
Puerto Rico-Maxima Lover
pull the weather strip out and you are done once you add 3M strip.....it makes a big difference.
Old Jun 19, 2006 | 01:45 PM
inspiredbykev's Avatar
You should thank my D***
where did you buy that 3m weather strip
I couldn't find that size anywhere
Old Jun 19, 2006 | 01:48 PM
Metal Maxima's Avatar
SHIFT_om nom nom nom
You won't. Just use a similar size.
Old Jun 19, 2006 | 02:39 PM
CoolMax's Avatar
is invisible
I did it this weekend, couldn't find the exact same product so I found the next closest.
Old Jun 19, 2006 | 02:48 PM
n3985's Avatar
大陆弟弟
Was it easy to peel off the the weather strip? And how do you like the difference afterwards?
Old Jun 19, 2006 | 04:11 PM
steven88's Avatar
Need A Light?
how loud exactly is this TSB? i mean, i currently don't hear any unusual noise inside the cabin during freeway driving....only road noise from my low profile tires....is this TSB VERY noticeable? should I be worried if I don't hear anything?
Old Jun 19, 2006 | 07:45 PM
TheBigDu's Avatar
I tried to do this once or twice, and I could've sworn I bought something very similar to the size housecor stated, but apparently the stuff I bought was too thick, because I could not get it in there and get the seal to go back all the way. Anybody else have this problem?
Old Jun 19, 2006 | 08:02 PM
darkse2501's Avatar
i did this on my car a few months ago. it is a great improvement on the wind noise in my car. my foam was thick as well and prevented the trim from going back in all the way at first, but after having the windows up for a week or so it was back to normal.
Old Jun 19, 2006 | 08:37 PM
n3985's Avatar
大陆弟弟
I swung by my local hardware store today and bought some generic rubber foam weather trim. It is 3/4 wide and 1/2 thick, is that too thick? housecor's tape says 1/2 too, but the tape looks really thick....
Old Jun 19, 2006 | 09:04 PM
Just jam it the fawk in there...foam...compression...you see where I'm going.
Old Jun 19, 2006 | 09:06 PM
n3985's Avatar
大陆弟弟
Cool, good to know
Old Jun 19, 2006 | 09:08 PM
Cool, good to know
And just peel the trim back with your fingers. I am still not 100% satisfied with it, there is still some noise coming from the rear right window.
I also have a'ssloads of deadening in there, so it might just be making that section all the more noticable.
Old Jun 20, 2006 | 05:01 PM
Zero Deuce SE's Avatar
I used the tape listed in the TSB. Nissan part number 80339-2W100. It cost about $3.25 for a strip of it. I installed it and the noise went away.
Old Jun 20, 2006 | 05:19 PM
NYPD-Arnold's Avatar
Z
I got some soft sticky foam like stripping -- and the wind noise was all gone. I did this over a year ago probably.
Old Jun 20, 2006 | 05:20 PM
MONTE 01&97 SE's Avatar
I did as well!
Old Jun 21, 2006 | 07:15 AM
DaReaper9's Avatar
on installing some stripping and it didn't seem to help. I can still hear the noise, but it goes and comes. I may just order some of that stripping that's mentioned in the TSB...A few posts up it said it was only around 3 bux for a strip...
Old Jun 21, 2006 | 09:33 AM
alicious's Avatar
the org...not what it was
like everyone else said it works like a charm and if the stripping seems like it wont fit just stuff it, or get a smaller one and put a lot more in there.
Old Jun 21, 2006 | 12:15 PM
steven88's Avatar
Need A Light?
Old Jun 21, 2006 | 12:40 PM
You basically answered your own question there. Why would you worry about it if you can't hear it?
stevesmax
Dec 17, 2020 11:57 AM
Huttig2009
Sep 25, 2015 03:31 PM
homeyclaus
Sep 3, 2015 06:15 PM
mpbclutch33
Aug 21, 2015 06:09 AM
doctorpullit
Aug 20, 2015 05:15 PM
