vibration after rotor change
Old Jun 19, 2006 | 05:57 AM
Lovemycar's Avatar
hey guys i changed my back rotors and pads yesterday now i get vibartion
at around 65MPH it was smooth no issues till i put those rotors on i don't think it's a bearing issues it was fine before i did this should i rebalance
Old Jun 19, 2006 | 06:02 AM
LoSt180's Avatar
perhaps the new rotors were warped. I've had that happen before.
Old Jun 19, 2006 | 08:36 AM
danger300z's Avatar
new rottors warped i never heard that before
Old Jun 19, 2006 | 08:54 AM
LoSt180's Avatar
very rare, but a set i got from Oreilly's 5 years ago for my 240 were warped. Took them back the next day, they put one on a lathe to prove it was warped and gave me a refund. Never bought anything from there again.
Old Jun 19, 2006 | 09:04 AM
Lovemycar's Avatar
it doesn't shake when i hit the brake that would be warped rotors right? it's time for a
rotation so i'm going to have the them rebalanced i may have not tightend the lugs well
enough as well
Old Jun 19, 2006 | 09:12 AM
Lovemycar's Avatar
hey did it shake when you applied the brake
or just driving
Old Jun 19, 2006 | 09:39 AM
LoSt180's Avatar
only braking.
My maxima is shaking now also in the front, there's like 5-6 active threads about breaks in different areas of the forum right now. I guess maximas have an issue with warping their rotors, or the rotors are very sensitive to how tight lugs are. I was thinking it's just my car!
Old Jun 19, 2006 | 06:40 PM
igzy's Avatar
I Know Kwaliti
Things to consider are new ones could be warped, I had many sets with that problem. Another one is when driving, pull on your hand brake slowly and feel the car, last time I did my rear brakes it was the rear rotors that gave me the vibrations and not the fronts...
Old Jun 19, 2006 | 06:52 PM
alpinestars™'s Avatar
THIS IS...
Very possible. FTL.
Old Jun 19, 2006 | 07:57 PM
Maxgig's Avatar
I agree with igzy, try the hand brake test. My car is in the shop right now because my rear brake started to stick. I drove 4 miles to the car wash this past Saturday and burned the crap out of my finger when I touched the rotor. (it was super hot) You may have a warped rotor or a sticking caliper. (one shop told me I wash my wheels too much)
Old Jun 20, 2006 | 04:32 AM
Lovemycar's Avatar
right but at braking or just driving
Old Jun 20, 2006 | 06:53 AM
igzy's Avatar
I Know Kwaliti
When does your car vibrate? Is it when you apply brake?
If it is when you brake then look at what the guys and I mentioned. If you get vibrations without brake applied then that may have nothing to do with brakes and your post title could be misleading to us that are trying to help you
Vibrations without braking could be caused by anything including off-balance wheels, warped rims, shifted tire belt, breaks in tire belt, uneven tire wear, ball joints, wheel bearings, sticky calipers, grease on rims, tie rods and the list goes on...
Old Jun 20, 2006 | 07:13 AM
Lovemycar's Avatar
It Happens on the highway around 60-65 miles an hour it comes and goes
no vibration at braking i don't understand it was smooth before i changed the back rotors what WTF and ideas? could it be bearings that fast the wheel are tight
Old Jun 20, 2006 | 07:48 AM
Lovemycar's Avatar
i guess i forgot to leave out tht rotors were only 17.00$ a peace very cheap
Old Jun 20, 2006 | 07:53 AM
Spartuss's Avatar
buy higher quality rotors like brembo or bendix
Old Jun 20, 2006 | 09:19 AM
igzy's Avatar
I Know Kwaliti
Why? My $20 rotors are working well after 30K...
Old Jun 20, 2006 | 09:21 AM
igzy's Avatar
I Know Kwaliti
Did your rotors come off easy when you replaced them or did you have to hammer them to get them off? If you had to hammer them, that could have damaged the bearings...
Is the vibration in your seat or the steering wheel?
Old Jun 20, 2006 | 09:44 AM
Lovemycar's Avatar
i had to bang them off not that hard though how could i check that
the shake is in my seat and wheel
02PearlSE
Feb 1, 2016 12:37 AM
alahjahwan09
18
Sep 21, 2015 09:12 PM
RWCreative
Sep 21, 2015 11:01 AM
Bonka
Sep 14, 2015 11:18 PM
thenewguyy
Sep 12, 2015 11:12 AM
