Removing K-Sports Help
Old Jun 20, 2006 | 04:29 PM
hnb763's Avatar
Alright yall...im removing my ksports. i had a friend install these for me but im gonna take them off myself. The fronts should be easy since its a direct swap. But for the rears...will i need a spring compressor? thanks!
Old Jun 20, 2006 | 05:34 PM
djfrestyl's Avatar
Suspension Yoda
You dont need a spring compressor to take the mounts off the rears (or the rears off the car), but you do need one if you want to reuse the mounts for a spring/strut setup
Old Jun 20, 2006 | 05:41 PM
MWilds 01 20th's Avatar
Why are you taking them out?
Old Jun 20, 2006 | 05:55 PM
hnb763's Avatar
well i need to reuse the mounts to put on my stock rear suspension setup. correct? so then i will need a spring compressor? thanks!
im taking them off cuz im going back to stock.
Old Jun 20, 2006 | 06:49 PM
djfrestyl's Avatar
Suspension Yoda
Correct, you'll have to compress the OEM springs to get the mounts back onto the stock struts.
Old Jun 20, 2006 | 07:49 PM
hnb763's Avatar
or my friend did once just got two people to push on the springs just enough to bolt down the mounts. so when i remove the ksports i wont need to use a spring compressor?
Old Jun 21, 2006 | 04:16 AM
djfrestyl's Avatar
Suspension Yoda
That works too.
Correct, to remove them from the car you wont need a compressor.
Old Jun 21, 2006 | 05:40 AM
What are you doing with your Ksports?? Are you selling them?
Old Jun 21, 2006 | 07:59 AM
03on18s's Avatar
same question here...are you selling them? i have tokico hp's and s-techs if you're interested in them.
Old Jun 21, 2006 | 09:44 AM
MaxBoost925's Avatar
Drug Money
aww, too stiff for you?
jk
the fronts just unbolt and you can take them out.
rears you can unbolt and remove as well. but just spend $30 at the dealer to get new top-hats so that you can put them on whatever spring/shock combo you are going to replace with so that it's 10X easier.
Old Jun 22, 2006 | 03:22 PM
hnb763's Avatar
jk
it cost $30 for both top hats? i may just do that and save myself the hassle. so then i wouldnt need to mess with removing the rear top hats? so all id have to do with the new top hats is just put them on my stock suspension setup w/o spring compressor and slap them on my car? thanks!
Old Jun 23, 2006 | 05:39 AM
djfrestyl's Avatar
Suspension Yoda
Just to clarify, $30 PER top hat, you need one for each side...~$60
Old Jun 23, 2006 | 09:39 AM
Drug Money
I stand corrected.
Old Jun 23, 2006 | 11:32 AM
alpinestars™'s Avatar
THIS IS...
Hey MaxBoost do you have KSports? If so Hows the ride, I just bought a set from the GB forum.
my03maxima
Jul 28, 2024 07:40 AM
doctorpullit
Mar 29, 2016 11:08 AM
RealityCheck
Oct 2, 2015 06:34 PM
jaydot901
Sep 29, 2015 01:18 PM
Max Nu-BE
Sep 28, 2015 10:25 AM
