Machine Gun Door Lock
When I lock my doors the passenger side door sounds like a machine gun. It locks but it sounds really bad. I have not had any accidents. Has this ever happened to anyone? Anyone have a suggestion how to fix this?
Does it make the same noise when unlocking? 9dtalon is probably right, faulty actuator. If you can get in the door I'd lube it up real good with WD-40 or something like that, check all the electrical connections, and make sure it's not binding up anywhere. If that doesn't work the replace it. Good luck
Mine has done that before. My battery was nearly dead (bad alternator) and I used my key fob to lock the doors. It started making a click click click noise. Only way I could get it to stop was to turn the key to the on position.
Thanks for the reply, I'm glad I'm not alone on this one. Would anyone happen to have one of those cool blow ups of the passenger side door, with all the screws and parts. If I have to take my door apart that would be helpful. Also this maybe a good time to put in heated mirrors.
REDinLV
Aug 15, 2024 12:30 AM
magiconthetire
Oct 26, 2015 09:03 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
