OEM Navigation Back-Up CD Swap
I will gladly make a copy of the disc for you. I will make an ISO file and upload it so you can download and burn it. I will do that for ya tonight.
I have the following CDs and am in need of discs 3 and 6 (but wouldn't mind a full set or upgraded MCA4). I have a 2002 Infiniti I35, but the discs are the same as the Nissan ones.
MCA5 v 5.5
MCA4 v 5.3
MCA 8 and 9 versions unknown (is there a way to find the version?)
I read in earlier threads about an FTP site. I would be glad to post my zipped ISO files.
Email me at vanryck@gmail.com
Thanks.
MCA5 v 5.5
MCA4 v 5.3
Thanks.
Download it here buddy!
Hey guys,
So, I have MCA7 (Northeast USA) Version 5.4, and I am willing to upload, provided you guys can give me some direction on how to do it and where to upload it to safely.
By uploading this CD, can someone else upload MCA8 and possibly MCA9? I desperately need the maps for VA and (somewhat) NC, as this is where I spend all my time.
Finally discovered a file host that will allow me to upload these and am attempting to upload now.
It'll be MCA 1-9 + the 5.5 program update.
Here's the link to the folder. Nothing is in there yet, still uploading. Upload from home is pretty slow.
https://docs.google.com/folder/d/0B-...lfT25wOFk/edit
Update: its all there you'll need a program called WinRAR to uncompress them. You can download it at http://www.rarlabs.com
Nah, I have MCA7 5.4 working fine. But did you burn it to the disc as a straight ISO file, because that's no good. You have to use something like DVD Decrypter and write the ISO image to the disk. Whatever program you use, make sure it's in ISO write mode, and write it at no more than 8x just to be on the safe side.
I was trying to figure out what map number I need also an i came across this site..
http://www.navigation.com/is-bin/INT...gationMenu=YES
Alright, so I got the program file to work. I downloaded DVD Decrypter and wrote the file at 4x in ISO mode and it worked great. However, neither MCA 8 (where I live) nor MCA 9 (where I travel) have worked- any ideas? Perhaps CD-RW or a lower MB count on the CD-R (currently 800mb)??
UPDATE: I now have MCA 9 working by writing at 1x, however MCA 8 is not working regardless of speed. I'm going to re-download the file and see if I can get that to work again and I will let you guys know
Problem found!!!
Darkstonian- MCA 8 was uploaded as MCA 8 5.5. Because of this, the file is not recognized as an ISO file, but rather a ".5" file (which does not exist). I can re-name the file to a .ISO, but that still doesn't fix it. In order for this map to work, the file must be re-uploaded and re-named. Is it possible you could re-upload MCA 8 5.5 but call it say "MCA8v55.ISO"? This will surely fix the issue. Sorry to have to ask this after all the work you did yesterday man.
Thanks so much for your help- you've helped us all out a ton!
It works... here's how
Ok, I saw what your were talking about with the .5 on the end. What you have to do after you download and extract the file is instead of .5, make it .iso, so erase the 5 and put iso. loaded it up in dvd decrypter, and burned it ok. So try that and let me know what happens. Sorry for the late reply by the way, my 4 year old just started preschool last week, was a busy one...
Lol, it's all good man. I don't have kids yet, but my friends that do certainly have their hands full!
I tried re-naming the file as an ISO, and I was successful in doing that on my CPU. It was acknowledged properly as a disc image file. However, it just doesn't seem to work, even when burned correctly. Any ideas? I get the feeling we might just be out of luck.
Thanks man
Thanks man
