why do they instruct to reprogram the ecm when mass airflow replaced
Old Jun 22, 2006 | 07:26 PM
vinny's Avatar
hello , had to replace the mass airflow assembly today and it did help, why do they instruct with the following " the unit requires special ecm reprogramming of the vehicle, refer to TSB for the special ECM id code that must be entered in the ASIST ECM Data screen to download the correct data. is this bull........ or should this be really done. just replaced mine and the car is driving fine with no reprograming?
Old Jun 22, 2006 | 07:42 PM
Lontar1's Avatar
Puerto Rico-Maxima Lover
BS not needed the ECU will reprogram itself. I replaced mine.. no need to.
Old Jun 23, 2006 | 11:27 AM
oldngivout's Avatar
Willing to learn
Actually that advice is, well, not true. The new MAF sensor will in fact work without reprogramming the ECU, but the update is designed to work with the different operating characteristics of the new MAF.
The fact is the ECU will not reprogram itself. You may have confused the terms reset and reprogram. Taking off the negative cable for 5 minutes will reset it. Only erasing and entering new data will reprogram it. That is why you must have the Consult 2.
You should consider letting your dealer put in the latest update for your ECM. Now that you have installed the new MAF yourself, it shouldn't be that much $100<. You could be pleasantly surprised.
Old Jul 6, 2006 | 09:45 AM
oskarol's Avatar
Mass Air Flow
Just hoping you guys can help me out here with replacing my MAF sensor.
My Maxima is 2000 GLE and it was bought in Toronto, Ontario. I have been looking online and found that prices for MAFs range anywhere from $600 at my dealer to $103 here: http://www.drivewire.com/nissanparts...massmeter.html
Just wondering, is the first part listed above correct for my car? I don't understand how there could be such a HUGE difference in price. As well, how can I check the manufacture date as the part in the link above says "Fits: 04/1999 - 06/2001 Nissan Maxima 3.0 GLE"
Thank you so so much for any help available!
Old Jul 7, 2006 | 05:52 AM
oskarol's Avatar
Maf
Can anybody offer any advice?
Old Jul 7, 2006 | 06:44 AM
larsony's Avatar
That one will work, but read this thread for some excellent info on MAF sensors for 5th gens...
http://forums.maxima.org/showthread.php?t=398513
tsi6001
Oct 3, 2022 10:23 PM
doctorpullit
Oct 11, 2015 10:28 AM
iflexsteel
Sep 15, 2015 03:37 AM
ChrisIve
Aug 22, 2015 03:04 PM
kirkhilles
Aug 8, 2015 10:53 AM
