HOW-TO WORKLOG: LED Loaded Instrument Cluster (+60 LEDs!) BRIGHTEST ORG CLUSTER YET
Old Jul 21, 2006 | 12:13 PM
  #121
Catch22's Avatar
I think the dash lights are waaaayyy to dim - I though I had a bulb out or something. This is a great thread - I might have to do this........Once you work out all the gotchas ;-)
Old Jul 21, 2006 | 06:28 PM
  #122
siren001's Avatar
Thats awsome metal, I'm thinking of doing that when i get to that part of the car, I starting at the back and working my way forward, dont know what Im gonna do with the dash area yet.
Old Jul 21, 2006 | 10:07 PM
  #123
maximillien's Avatar
i hope dat dun blind u when u drive....god its hard enough when i drive wid my tv on at night...
Old Jul 25, 2006 | 06:51 AM
  #124
illlojik's Avatar
I C U
Originally Posted by Metal Maxima
Yep! Just use the OEM bulb holder, slide an LED through it, and bend the ends...attach a 510-ohm resistor to the negative side, twist in to contact, and enjoy.
You could also do this...
I was wondering, when you did your climate control, what size Led bulb did you use? And from the instructions you gave in that thread, I take it there is minimal or no soldering involved? Thanks for any help you can provide in advanced.
Old Sep 29, 2009 | 12:17 PM
  #125
Skunk83's Avatar
can you reupload the pics please! you the bomb!!
Old Sep 29, 2009 | 01:11 PM
  #126
jowo9's Avatar
-yeah please??? I want to do this (ordered LEDs and everything) and this would help so much. I can tell it's an awesome write-up, even without pics!
Old Sep 29, 2009 | 02:30 PM
  #127
Metal Maxima's Avatar
SHIFT_om nom nom nom
Lemme see if I still have them...
Old Sep 29, 2009 | 03:11 PM
  #128
jowo9's Avatar
awesome! thanks metalmaxima. you're the best.
Old Sep 29, 2009 | 06:15 PM
  #129
LOL, I never finished it. I will tonight. Updating the rest of the steps
Old Sep 29, 2009 | 06:51 PM
  #130
HOW-TO completed, pics updated
Old Sep 29, 2009 | 11:24 PM
  #131
jowo9's Avatar
haha, aaaannndd.... 3 years and 3 months later, its finished!! This is awesome, thanks for the time!
Old Sep 30, 2009 | 12:34 AM
  #132
avciugroar's Avatar
This thread just may get popular! (again)
Metal... I know its been three years but I hope you can still answer questions on it...
Does it get too hot? Dont the SMT's get pretty warm?
Were there any plugs on the back of the cluster that you did not plug back up? (since you have your own lights)
When testing, you connect it to the car battery?
When you used goop to mount the boards, you paste it right on the original board with electrical tape all over it?
Old Sep 30, 2009 | 01:45 AM
  #133
Revs2Hard's Avatar
BARF
Originally Posted by 03on18s
can i ask why? why do you need your instrument cluster to look like a spotlight? i don't get it....
I dont get it ether, I enjoy being able to see out of my front window at night.
Old Sep 30, 2009 | 03:01 AM
  #134
Nope. The advantage of LEDs is that they DON'T get hot. If an LED is getting warm, it means one thing: over exceeding the amperage rating is occuring and will result in a quick thermal death...hence the TO220 regulators.
None.
Yes. The voltage regulators require a full load to get the energy across.
Ah, no, good question. Just around a good portion of the circumference.
Old Sep 30, 2009 | 03:02 AM
  #135
The pics are not 100% accurate in that the lighting is a bit overaggerated...a Sony DSC is not exactly "professional" equipment. Moreover, nothing a single resistor on the primary connection cannot dim down.
Old Sep 30, 2009 | 09:56 AM
  #136
jowo9's Avatar
-what kind of resistor would I need to put on the primary connection to dim it slightly?
Old Oct 3, 2009 | 06:41 PM
  #137
Skunk83's Avatar
Thanks! That is sweet work you did. Kudos buddy!
Old Oct 4, 2009 | 02:01 PM
  #138
Mynameismcgyver's Avatar
Awesome work... but wayyy to bright for my liking. Like staring at the sun.....
Old Oct 7, 2009 | 08:37 PM
  #139
jowo9's Avatar
Hey Metal Maxima I just had a question and I didn't wanna PM you cuz it might help out others who were wondering... anyway, how did you do the LEDs behind the odo display as shown here?
Old Oct 8, 2009 | 05:27 AM
  #140
OK, now this one was a 3x3 array (IIRC) of PLCC-2 style LEDs with a 270-ohm resistor attached to each of the negative leads on the series.
As far as your other question goes, I would get a few 1-W resistors (330-ohm, 560-ohm, 1.1k-ohm, and 2.2k-ohm, etc.) and test away until the idea brightness is achieved. Your alternative to provide a dimmable cluster would be to add a PWM to change as desired.
I have the original boards for sale if you want them...$40 and they're yours.
Old Oct 8, 2009 | 10:39 AM
  #141
jowo9's Avatar
-alright, thanks for the info.. umm... we'll see if I want those boards... I'll let you know if I do, but i have a bunch of LEDs coming in the next couple days and kind of have a similar idea for doing this that I wanna test out. Thanks!
Old Oct 10, 2009 | 10:45 PM
  #142
jowo9's Avatar
Hey, Metal Maxima, I just have one more question. When you did the needle LEDs, like in this pic, did you tape the back of the PCB or what? Will it hurt the magnets/motors/whatever controls the needles to have the metal from the LEDs/resistors touching the copper here? Thanks for your help...
Old Oct 13, 2009 | 08:06 PM
  #143
jowo9's Avatar
-Hey Metal, I don't get how to hook up the voltage regulators. (the ground part)
Do I hook the ground coming from the LEDs to the ground lead on the voltage regulator? or do I ground the middle lead on the voltage regulator AND ground the ground from the LEDs? I'd guess I'm doing the latter? but why does the voltage regulator need to be grounded? i thought it was just regulating input voltage...
-Also, how do you clear the 5.5 gen needles? I plan on doing white faces with blue needles, but I want maximum blue needle light up! hehe. What should I do to maximize the light diffusion from the blue needle LEDs into the needles?
Old Oct 13, 2009 | 08:49 PM
  #144
maxboy01AE's Avatar
good job thats next on my to do list.
Old Oct 14, 2009 | 03:19 AM
  #145
350maxima02's Avatar
i know this thread is fairly talked about already just wanted to say congrats, i think our 5th gen gauges really have no bam factor to them and seems you turned a negative into a positive if i had the rocks to do this mod, i would def do it myself.
Great job..
Old Sep 2, 2011 | 08:31 AM
  #146
PrinceOfPal's Avatar
This looks amaaaaazing. I am waiting for my T5 74 BLUE 3 CHIPs SMD BLUE LED LIGHT BULB to do my cluster. Can't I just take the original bulbs from the cluster out and place the LEDs in without a resistor? They do fit perfectly and I was told they are just plug and play.
Any information would be helpful
Old Sep 2, 2011 | 08:43 AM
  #147
OHH NOES's Avatar
6spd Swapped
There's a whole 50 page thread on this.
Old Sep 2, 2011 | 09:54 AM
  #148
RA121625's Avatar
But to answer your question, yes they are plug and play because you are buying premade bulbs and not just the single LEDs like the OP.
Slamrod
Apr 10, 2016 05:24 PM
MaxLife17
Sep 8, 2015 02:36 PM
umnitza
Sep 1, 2015 01:03 PM
Stelianos
Aug 19, 2015 02:07 PM
220k+ A32
Aug 17, 2015 03:57 PM
