Auto transmission kickdown
Old Jun 28, 2006 | 02:10 AM
willy431's Avatar
I have searched the fifth gen forums and found a lot of people have the slow 1-2 shift I have been experiecing, but found no mention of the kickdown issue. I have seen lately where in just about all gears but 4th, when I am around 3000-anything less than redline, I get no kick down of gears at wot.
It just revs up, I hit the power at the 4500k engine manifold butterfly change, and it goes to redline and shifts up. There is a huge dead are from 3000-4500 and it doesn't kick down. Is this normal? My 4th gen would kick down at anything less than 5k.
Thanks for any tips or hints. I am at 66k miles.
Old Jun 28, 2006 | 01:25 PM
maxS
something is wrong with TCM/TPS/ATF level etc.?
Old Jun 28, 2006 | 08:40 PM
SilverGLE's Avatar
I'm watching you, boy...
Does it feel like there's no pull in the 3k-4.5k range?
Old Jun 28, 2006 | 08:53 PM
shift_2kmaxima's Avatar
hahah if his answer is YES
than its MAF sensor man.....
i had the same problem, and i got new MAF, and wow.....what a difference.....
iam 99.9% sure that its his maf....
huso
Old Jun 28, 2006 | 11:35 PM
spdfreak's Avatar
I'm not sure if this has anything to do with this, but I just read something on http://www.mattblehm.com/index.htm
about grounding kits and causing a smoother ride and also something with downshifts. Hope this "might" help.
Old Jun 29, 2006 | 12:07 AM
SoonerFan's Avatar
Cletus
it wont
sounds like a TCM issue to me. its not sending the signal to the tranny to downshift at initial hard acceleration.
i had a bad TCM on my 2000 and had to replace it (cant be reset or reprogramed)
Old Jun 29, 2006 | 02:47 PM
willy431's Avatar
It is in fact dead from 3500-4500.
I will try a new maf and see if that helps first.
Thanks for all the tips.
user 11122324
42
Jul 18, 2022 03:35 PM
BobTX10
Oct 7, 2015 08:43 AM
Pied
Sep 26, 2015 03:29 PM
