Alternator and Brake warning light....wtf?!?!?
I was wondering if anyone has experienced their alternator and brake warning lights coming on at the same time.
First it started out with the brake light coming on when I accelerated hard. The light would go out immediately when I let go of the gas pedal.
Then a few days ago the same thing started happening with the alternator light...Now not only was the brake light coming on but the alternator light as well.
Just now I went to run to the store and when I got in the car both of the lights came on and stayed on when I started the car. Then I left the parking spot and started driving and they both went off again.
I'm thinking the belt is worn out...Any ideas?
Thanks for any help guys
Low brake fluid warning light:
The light warns of a low brake fluid level. If the
light comes on while the engine is running with
the parking brake not applied, stop the vehicle
and perform the following:
1. Check the brake fluid level. Add brake fluid
as necessary. See “Brake and clutch fluid”
in the “Do-it-yourself” section.
2. If the brake fluid level is correct, have the
warning system checked by a NISSAN
dealer.
dealer.
I have not found out what the problem is yet, but I now suspect the alternator to be bad.
I drove the car Friday night and while on the highway bth of the lights stayed on constantly. I started to drive home and all of a sudden the lights dimmed out and I lost all power to the car. i had to have the car towed home.
unfortunately I have to wait until Wednesday to see my mechanic as he is on vacation, so until then, no Maxima for me
its the alternator failed or the related circuits, check the ckts and if theyre okay, replace the alternator.
sorry this image is so large guys, but its all ive got. you can see the diode between the alt and brake circuits, and the alternator causing the charge light to go on will also cause the brake light to go on.
save this image because it will dissappear in a few days
(image removed, if you need it, send me a PM)
I had the same problem last week when it rained all week. It started Monday morning, lights would come on, and then off. And it got worse progressively. Then all of a sudden The lights stopped coming on and everything is charging fine again. When the battery light was on, I checked the charge, it wasn't charging. Voltage was lower with engine running than without. Then when it was good, it was charging at 14V. So I thought it was my alternator, but then it's fine now. So I don't know, moisture? It's probably on it's way out but then, if fine now, so I'll keep driving. My car is got 102,000
http://forums.maxima.org/showthread.php?t=479268
When the brake light and battery lights come on it means its alternator time. You belts would have to be SUPER loose in order for the alternator not to work.
I experienced similar things in winter of 2004/2005, lights would be on for a few seconds after start up but would go away after like 4-5 seconds. I bought a spare alternator, and haven't installed it yet... knock on wood going good for 150+K miles so far.
here is some pics...
http://www.chicagomaximaclub.net/showthread.php?t=1178
Only to be enjoyed on non-56K modem connections please !
Andrei
Nismo98, hold on to your recepit from Nissan..... their reman alternators are about as good as those you buy from Napa, AutoZone etc. I've seen it happen on numerous occassions where the "Nissan Reman" alternator does not live up to its name.
Lil story here... years ago my alternator crapped out on my 93 Sentra SE-R, I bought a reman one from Nissan. I only drove the car maybe 2K miles that year, I sold the car to a friend of mine and the alternator crapped out 2 weeks after he bought the car off me. The 12mo/12K mile warranty ended 4 weeks before..... lesson ? Never buy REMAN parts.
Andrei
its your alternator. Even says it in your owners manual.
This just happened to me last week. Got a new alternator and everything is fine. $99 for the alternator..what a steal! LOL. Anyway, check your voltage when the car is running. Let us know your findings.
Andrew
Andrew
Andrew
Andrew
Andrei
you can usually do pretty good with local alternator shops, they reman and test everything they do, and theres generally a 'personal' attitude, so theyll generally get it right the first time and for a good price.
same goes for batteries. you should be able to get a reman battery for $15-25
Originally Posted by Nismo98
What kind of alternator did you get for $99?
Andrei
Andrei
Anything that can be rebuilt, they do it. 6 month guarantee. Thats all. I mean, its better paying for a remanufactured Bosch for $150 with the same to a bit more warranty.
btw, this place is by me on Long Island.
Andrew
All of the above apply to me as well. I bought this guy... 140 AMP Alternator for my Max.
http://cgi.ebay.com/ebaymotors/ws/eB...RK%3AMEWA%3AIT
So I'll give it a try. Anyone install there own Alternators at all? The service manual makes it look **** easy.. I'm by no means a mechanic and I think I may try myself.
I did the install a few months ago, its a pain trying to get to it but definitely do-able. I installed the alternator from the top, you need to remove the radiator fans and AC compressor to get to the alternator. Took me about 3 hours to do myself while looking up stuff online.
these are the directions that i used http://www.motorvate.ca/mvp.php/500
How to Know When Your Alternator is Dead:
1.) The needles jump. (The tachometer and the Spedometer needles "die", or drop to zero and then back to actual while driving)
2.) Headlights Dim
3.) Loss of power
4.) Stereo cuts out/comes back
5.) Car runs perfectly after a jump-start. For a mile.
6.) Typically happens at night/during rain. The car can run completely fine and normal during a sunny day, but turning on defroster, headlights, foglights, stereo, etc. triggers the abnormalities.
This has happened to me in 3 cars. Signs were all the same, on a Subaru Legacy, a Toyota Camry, and an 01 AE Nissan Maxima. If you have these symptoms, time for a new alternator.
2.) Headlights Dim
3.) Loss of power
I just had mine rebuilt at a local place. They also offered a lifetime warranty, so I'm not too worried about it. I also had them do the labor on it. It was around $250 with labor (to remove and replace) and the rebuild.
Once it gets cold here in a few weeks, my originaly 6 year old battery is going to need to be replaced as well.
I have a complete power loss and all my lights dim constantly; however I have had this problem for good 5-6 months. I think if it was an alternator it would've been dead by now...
2.) Headlights Dim
3.) Loss of power
2.) Headlights Dim
3.) Loss of power
Definitely time to get a new battery, especially w/ the cold getting near. My battery died on me earlier this week. The new battery runs like a champ!
ill bet you drove through a LOT of water and did something to your breaks and fried your alternator?.......
i did that once; no splash guards
ps: get something good that has high cold-cranking amps...im talking NOT from walmart..been there...done that. warranty doesnt mean **** when they keep telling you its still good even though the battery wont retain its amperage after so much polarity is dissipated.
Brake and Battery Lights lit today....
Bump.....hopefully I'm not braking any rules by doing so...
Drove the Maxima to work this morning when I noticed the lights dim, a few moments later, both the brake and Battery lights lit up. They remained lit until I got to work. Seems like the Alternator is going to die, so hopefully it can at least get me home later on today.
I'm in Peru, and had my 2000 Maxima shipped here. When it arrived from Canada, it wouldn't start properly, and the Battery eventually died. Bought a new one 10 days ago.
Another concern that might be related, is that two days ago, I heard a "Whining" sound....sounding like it was coming from the belt. But it went away yesterday and I never heard it again. Although this light problem seems more severe.
If someone can help, I would definitely appreciate it.
dash brake warning light and battery light coming on at the same time means you need to replace your alternator. You can check the voltage at the battery with a volt meter before starting the car and after it's running. The voltage should go up to around 14 or so, if less than what you started with, it's your alternator that needs to be replaced. Check your brake mater cylinder to make sure you have enough brake fluid just in case you're low. But coincidences like that are rare.. But you never know.
You need to change the alternator. The brake warning light and alternator are "like" on the same circuit... the alternator voltage is lower than it should be, it triggers the brake warning light too. If you read through the whole thread, it's been discussed.
Good luck.
Good luck.
Thanks for your quick reply Young...
I've been reading quite a few threads about this, and I'm defeinitely leaning towards the Alternator.
The only "off" factor was that whining sound. Not sure if the belt is related. Would be good if anyone experienced something similar and how it was resolved.
If the car makes it home this afternoon, will definitely test the voltage before and after starting it.
As far as the belt is concerned....what should I be looking for? Just that it's secure in place and tight? Look for ware?
Those 2 lights coming on simultaneously is Nissan's code for "your alternator just died".
Your battery will follow shortly if you don't replace the alternator...
You can replace it on your own but it is a PITA job, be sure to have a 6-pt 14mm wrench; a socket will not fit and a 12-pt will strip the nut for the alternator belt adjustment.
(I'm amazed that Maximas are not available there).
Yeah Nelsito65...
Appreciate the comment. When I heard that whining sound, I knew something was up. But as long as it's "Also" Alternator related....then hopefully it'll get resolved with the Alternator repair as was the case with you.
Did the voltage test before and after starting it, and it remained at 12.4 VDC. Meaning it was running completely on the Battery.
I was amazed that they don't have Maximas here either, but then again, they have other Nissan models that we don't have in North America "Almera" for example, which looks like a cross between an Altima and a Sentra.
Since Nissan sells the Almera, the altenators stand a good chance of being the same. Check into the amperage output of the Almera model and if its the same, you should be good to go.
if you're interested, here is some info on the Almera. The Almera name was essentially the European export-market name for the Nissan Pulsar / Nissan Sentra / Nissan Bluebird Sylphy.
http://www.cars-directory.net/history/nissan/almera/
If the belts havent been replaced in a while, just replace it.
Unfortunately, I don't have any space to work on my car where I moved to.
A peruvian mechanic came over to look at it, and said he will either rebuild the alternator or try to source one.
We'll see what happens....
Hate this new helpless feeling.
Just saw your post DennisMik...
Cool link.
The Almera it talks about was discontinued in 2006. The ones that look like a cross between an Altima and a Sentra are 2010 and look like this:
http://www.nissan.com.pe/sp/web/mode...ry/gallery.htm
