hot weather...poor performance
Old Jul 5, 2006 | 03:06 PM
Y2k2maxse's Avatar
Ive been noticing this summer that when the temp gets to like 90 degrees my car gets to be pretty sluggish. im talking 0-60 times of about 9 seconds (auto) and slow on the highway also, no other cars i drove felt sluggish like this. I have a berk intake and i put my stock back on once didnt really notice a difference. car is super quick when it gets colder out...would that lead me to believe that my MAF is dying?
Old Jul 5, 2006 | 03:14 PM
Metal Maxima's Avatar
SHIFT_om nom nom nom
It would lead me to blieve that with hot air and your a/c on, yes, it will be slower.
Hotter air = less air mass for combustion
Old Jul 5, 2006 | 03:17 PM
Pri63's Avatar
idk know if you have a GAB, but I swap mine back to stock...it's makes the world's difference.
Old Jul 5, 2006 | 03:19 PM
KCMC582's Avatar
yeah but even with my AC on, the car still moves...given i have a couple more mods than him, but nothing major for performance. yesterday it was 90+ here and i was coming back from dons with the AC on, and i as usual, its only a slight drop in performance, much less than previous cars ive had. if your performance is truly dropping that much, i guess it is possible something is wrong.
the car is going to be a litle more sluggish when its hot tho, hot and muggy. usually fall and spring the cars seem to perform and respond the best, but the difference shouldnt be as drastic as you are experiencing.
Old Jul 5, 2006 | 03:24 PM
Y2k2maxse's Avatar
well i know about the hot air thing less combustion..and i tried a/c on, a/c off....EVERYTHING (radio lights etc etc) on and no difference at all. you know when you start your car and its cold and it feels a little slower than usual..thats how it feels in hot. I dont like the GAB because theres too much of a chance of dirt getting into the intake. Ive tried it before.
Old Jul 5, 2006 | 03:27 PM
Y2k2maxse's Avatar
isnt there some kind of temp sensor of something on the 2K2 MAF? would that have anything to do with it? cuz 90 degrees should NOT be chopping of 2.5 seconds off a 0-60 run. or make it barely be able to accelerate on the highway up a hill.
Old Jul 5, 2006 | 03:36 PM
n3985's Avatar
大陆弟弟
Over the weekend it is was 100+ in Southern Indiana, I was driving with my gf up a steep hill with the AC on, and no problems for me.
Old Jul 5, 2006 | 03:38 PM
alpinestars™'s Avatar
THIS IS...
Driving yesterday up thunderbird mountain with A/C on and 113 degree temp. No issues.
Old Jul 5, 2006 | 04:55 PM
sloppymax's Avatar
IMBOUTTOBUSTSOMEGHOSTS
how are you measuring your runs? i hope its not with a stopwatch.
Old Jul 5, 2006 | 04:59 PM
NYPD-Arnold's Avatar
Z
Not a single issue here. The car's every bit a monster in the cold as it is in the warmth.
Old Jul 5, 2006 | 05:25 PM
Y2k2maxse's Avatar
looks like im alone here with the problems. its not with a stopwatch im timing..in my head but still i can count almost exact on second..point is i have a huge power loss in the hot. I may go for a 2K1 MAF and just transfer the sensor and see what that does.
Old Jul 5, 2006 | 05:29 PM
n3985's Avatar
大陆弟弟
Why not doing something basic like buying a tank of good gas (Chevron 93?), changing the air filter...etc first?
Old Jul 5, 2006 | 05:40 PM
sloppymax's Avatar
if you are going to throw money at it, then get a dyno and make sure you are having a power loss and then have the ablility to see where it might be occuring.
Old Jul 5, 2006 | 05:52 PM
black97's Avatar
Man i have the same problem i dont know what to do my car feels very sluggish when it's hot and i got to push on throtlle much harder then usual to get the same accel. and i'm loosing gas because of that....any ideas guys
Old Jul 5, 2006 | 06:33 PM
Y2k2maxse's Avatar
thank you finally SOMEONE WITH my problem. I always use premium gas, nothing but and that wouldnt make a difference. i changed my filter/intake setup to srock...same thing. How much does a dyno usually go for?
Old Jul 5, 2006 | 07:20 PM
black97's Avatar
Yeah man i've changed my air filter, plugs, fuel filter, use premium gas only no CEL codes at all knock sensor has been replaced...f**ck that i'll be driving it until it dies on me anyway
Old Jul 5, 2006 | 07:47 PM
footballplyrdan's Avatar
I too found a difference in performance when the weather is hot. Slower than normal. Could it be the high humidity also? (like 90% here in NJ)
Old Jul 5, 2006 | 07:57 PM
96blkonblkse's Avatar
there will be some difference in performance, maybe not noticeable on the butt dyno, but there will be because of the higher intake air temps means that there will be a higher chance for pre-detonation, which means the knock sensors will kick in and reduce timing to prevent it. same principle on forced induction cars, lower intake temps(intercooler) mean less chance of pre-detonation which means more boost can be run safley.
Old Jul 5, 2006 | 08:03 PM
A33 VQ30DEK's Avatar
knock sensors
Old Jul 6, 2006 | 05:05 AM
sloppymax's Avatar
ive seen it go anywhere from 45-75 bucks for 3 pulls with air/fuel. if you think it could be a knock then hooked up a obd2 scanner and watch the timing. if its not retarding the timing then its not the knock sensor.
Old Jul 6, 2006 | 03:06 PM
Y2k2maxse's Avatar
well ima get the SES light pulled tonight and see what it is. update soon.
Old Jul 6, 2006 | 03:46 PM
Y2k2maxse's Avatar
OK...just got the code pulled...DOUBT IT has anything to do with my issue...but its P0455 "EVAP Emission control system leak (large)" What does that mean? Sometimes I can smell gas around my gas filler (im not DUMB i know there will be some smell of gas but its much stronger than it probably should be..but the gas cap passed inspection) so next is maybe try a new MAF....made mircacles happen on my 2K with a new MAF sensor.
Old Jul 6, 2006 | 03:55 PM
HotshotVQ35's Avatar
yeah, get a drop! holy 4x4!
Originally Posted by black97
any ideas guys
Old Jul 6, 2006 | 04:06 PM
Y2k2maxse's Avatar
way to go off topic....
Mahmuth
Aug 16, 2024 08:23 PM
jmlee44
Oct 2, 2022 02:13 PM
tarun900
19
Dec 20, 2021 06:57 PM
Socalstillen
Sep 26, 2015 12:01 PM
