Oxygen Sensor replacement for dummies
Old Jul 5, 2006 | 05:27 PM
steelymatt's Avatar
Hi,
I need to replace the oxygen sensor with the white harness. I understand how to get it out of the cat. But how do I remove the wire harness? Also, is there a trick to removing the plastic clips that are used to route the wire underneath the car.
Old Jul 5, 2006 | 09:29 PM
Maxn2theMax's Avatar
Recently replaced the rear Bank 1 sensor on a Cali Spec Maxima. Only thing that caused a little headache was reinstalling the clips in the brackets. No trick just press one end and pull from opposite end. See this PDF file
for help.
Old Jul 6, 2006 | 05:20 AM
Puppetmaster's Avatar
The wire harness unclips from the front of the engine bay. As for the plastic clips, I removed em using needle nose pliers and didn't reinstall them; I just ziptied the wiring using the brackets where the clips used to be so if I ever have to replace the O2, I'll just cut the zipties instead of worrying about the clips.
Old Jul 6, 2006 | 05:32 AM
UMD_MaxSE's Avatar
Got Bent?
Just cut out the plastic clips when removing the old sensor...
Doesn't the new sensor come with those clips anyways?
Old Jul 6, 2006 | 10:26 AM
BigFly_2K2SE's Avatar
To remove the harness, squeeze the tabs on the electrical connector near the engine bay and pull it out. As for the clips, I actually found them to be the biggest PIA of the whole job by far. Assuming you have new clips supplied with your new sensor, use a pair of needle-nose pliers and just start reefing on those suckers. Still wasn't that easy IMO, especially the ones in the tight locations. I can't imagine trying to take all those clips out if you actually have to reuse them.
mrc00l88
Jan 25, 2024 01:14 PM
Maxboy23
Aug 21, 2015 11:02 AM
doobadoo
Aug 15, 2015 06:43 PM
Superbform
Aug 11, 2015 08:10 PM
