Does your windshield washer spray a single stream or mist?
Old Jul 19, 2006 | 04:59 PM
n3985's Avatar
大陆弟弟
Does anyone know if our windshield washer nozzle is suppose to spray in two single streams? Because my roomies' 325i and his gf's Mazda6, AND my rental 06 Maxima SE all spray a wide "mist" onto the windshield. I hate the two single streams because if I have some dirt say on the far right or left side, the washer fluid doesn't even come close.
Old Jul 19, 2006 | 05:33 PM
00MaxSE's Avatar
Pointy Elbows
5th gens and I30's/I35's like yours spray single streams. Some people have gotten the Murano nozzles for their 5th gens, which spray the mist.
Old Jul 19, 2006 | 05:34 PM
n3985's Avatar
大陆弟弟
Oh I see, thanks for the info.
NYPD-Arnold's Avatar
Z
Quite frankly, nozzles right on the wipers = rock! My Infiniti has it like that, so does the G35 and M35.
Old Jul 19, 2006 | 05:38 PM
StL I30's Avatar
I installed Murano sprayers, which spray in a fan pattern. I'm gonna go back to the stock sprayers. It'll work on a Max, but I think we have more curve in our hoods side to side. They don't really sit flush on the hood (yes I tried to trim them) and the fan pattern isn't even across the windshield, but it is better than the two stream.
I'm wondering what the 06 Max sprayers look like. Didn't know they had fan pattern sprayers.
Old Jul 19, 2006 | 05:43 PM
NmexMAX's Avatar
dot dot dot ...
Grand Am's have that too...
Both my Maximas do what the OP's does.
Old Jul 19, 2006 | 06:00 PM
footballplyrdan's Avatar
My nozzles do not spray in a single stream. More like a fan shaped stream, but the fluid gets on the entire winshield.
Old Jul 19, 2006 | 07:17 PM
irish44j's Avatar
retired moderator
I have the Murano sprayers and they fit fine, assuming you dremel down the little tab on the inside.....they also get the entire windshield with the spray...
Old Jul 20, 2006 | 06:02 AM
NeverBepeace's Avatar
Hmmmmm only my left nozzle works!! The other one doesnt. But i notice that when I looked under the hood, theres like a black tube disconnected. I really dont know how to fix it. Any advice?
Old Jul 20, 2006 | 06:27 AM
krazysashka's Avatar
Is there a How-to for Murano nozzle change?
Old Jul 20, 2006 | 06:36 AM
beancooker's Avatar
Reconnect it to the spray nozzle!!!
Old Jul 20, 2006 | 09:45 AM
djfrestyl's Avatar
Suspension Yoda
You're kidding, right?
Old Jul 20, 2006 | 03:55 PM
BewstAdd1ct's Avatar
wow. thats like saying 'my check engine light is on and my MAF is disconnected, how do i fix this?'
or
'my car wont start, but the key isnt in the ignition, what should i do?'
anyway, good to hear about murano nozzles. i might throw some on the 5.5, and the 3rd gen
Old Jul 20, 2006 | 07:59 PM
Actually theres nothing that I can see to connect it to. So before you put your smart azz comments.....find out more info first.
Old Jul 20, 2006 | 08:13 PM
GigEmAgs07's Avatar
is this hard to swap out? how-to?
Old Jul 21, 2006 | 05:16 AM
djfrestyl's Avatar
Suspension Yoda
Did you look carefully at the underside of your hood?
Old Jul 21, 2006 | 06:34 AM
MacGarnicle's Avatar
I've never done it but I can imagine how the swap out would go...
1) disconnect the tube from the nozzle.
2) carefully remove nozzle.
3) replace with new nozzle
now this is the one that people get stuck up on:
4) RECONNECT the tube to the nozzle..
Old Jul 21, 2006 | 07:48 AM
whodatt1's Avatar
For the guy that can't find where his vacuum/water tube connects to. have someone use the sprayer while you look under the hood. you should see where the spray is coming from and quickly determine what the hose should connect to.
Old Jul 23, 2006 | 12:11 PM
no, thatll only show him that the hose hes already seeing is indeed a washer hose.
it may be under the hood insulator. if you take a look where the nozzle is on the topside of the hood, itll be on the same place on the underside, so you might be able to sneak it on without removing anything, or you might have to remove the hood insulator.
Old Jul 23, 2006 | 08:17 PM
How-to please, anyone?
Old Jul 23, 2006 | 08:25 PM
FinalJenemba's Avatar
stream for me (02')
Old Jul 23, 2006 | 09:32 PM
lowincash's Avatar
No More Maxipad
there's like 2 streams from each nozzle. but on my passenger side one stream shoots too high and it gets onto the roof. how can i aim it?
Old Jul 24, 2006 | 05:15 AM
jkayca's Avatar
I found these types would always freeze up in winter. The hose is too exposed to the elements. Much better to keep everything under the nice warm hood
Old Jul 24, 2006 | 09:35 AM
whodatt1's Avatar
LOL, I figured the black tube he was seeing was coming out from the hood, and he did not know where to connect it to. Now the problem makes more sense. do as BewstAdd1ct said.
Old Jul 24, 2006 | 10:18 AM
stick a straight pin into the hole and you should be able to aim it.
Old Nov 10, 2006 | 07:59 PM
NisTech's Avatar
I agree. I had a Grand Am and the thing always froze with -45 fluid. Had to run inside get hot water and pour it over. Getto but it worked haha.
02PearlSE
Feb 1, 2016 12:37 AM
Excalibur23
Oct 13, 2015 04:33 PM
zzznightmarezz
Sep 21, 2015 06:32 PM
bumpypickle
Sep 19, 2015 01:07 AM
