How-To: Changing Spark Plugs on 5th Gen
Old 07-20-2006, 04:12 AM
jsmith24's Avatar
It's been a while since I've beein on the .ORG, so I don't know if this info is already here somewhere, but I wanted to post the link because this is a great walk-through for changing the plugs on a 5th Gen Maxima. It's not my site, I just wanted you guys to see what I found.
He has a few other How-Tos on there as well, but this was my favorite.
Jack
jsmith24 is offline
Old 07-20-2006, 06:14 AM
MIXXMAX's Avatar
Yeah, that link is for changing the plugs on the 2k2-2k3's. It's different on the 2k-2k1's. The removal of the manifold process doesn't need to be removed. But, changing them is basically the same.
MIXXMAX is offline
Old 07-20-2006, 06:42 AM
maximaownsyou's Avatar
umm the rear plugs on my 2k2 is behind the manifold too
maximaownsyou is offline
Old 07-20-2006, 06:53 AM
MIXXMAX's Avatar
Oops. Yeah, I just realized that later after I posted. Good looking out. I edited my post. Thanks!
MIXXMAX is offline
Old 07-20-2006, 07:02 AM
beancooker's Avatar
Now wait a minute, I've got an 01, but for some strange reason I get the feeling that it's not necessary to pull the intake manifold.
beancooker is offline
Old 07-20-2006, 07:09 AM
IMBOUTTOBUSTSOMEGHOSTS
sloppymax's Avatar
no need to remove the manifold on the 3.0. the only thing that could get in the way is the throttle and cruise control cable but they are easy enough to disconnect and move.
sloppymax is offline
Old 07-20-2006, 07:34 AM
MIXXMAX's Avatar
Yeah, when I changed my rears, I didn't even bother removing the harness from the coil. I managed to loosen the throttle cable a little and squeezed the coil right out without even putting any stress on it.
MIXXMAX is offline
Old 07-20-2006, 09:48 AM
beancooker's Avatar
In that whack write-up did anyone notice he never bothered to cover the wide open holes to keep debris out of the engine???
Old 07-20-2006, 11:03 AM
Jasovanni's Avatar
can anyone link an 00-01 how-to please ?
J
Jasovanni is offline
Old 07-20-2006, 11:09 AM
jsmith24's Avatar
What debris? Didn't you see how clean that bay is?
Jack
jsmith24 is offline
Old 07-20-2006, 11:59 AM
MIXXMAX's Avatar
J
Don't know of a link off hand, but it's a fairly simple process.
For front plugs:
1) Remove valve cover.
2) Disconnect harness from coils.
3) Remove the two bolts holding in coils.
4) Pull coil up from spark plug.
5) Using a socket wrench with spark plug socket (5/8), loosen spark plug and pull out.
6) Reverse the procedure for install. May want to use a torque wrench to correctly torque the plugs when tightening them back in. Some people do, some people don't. But for me, I do.
For rears plugs:
Removal is the same as fronts, but may have to loosen throttle cable and/or temporarily remove cruise control cable. This will make it easier to get around in removing the coils from the plugs.
MIXXMAX is offline
Old 07-27-2006, 12:34 PM
Mints33's Avatar
A link w/ pics for a 2000 would be super sweet.
Mints33 is offline
Old 07-27-2006, 12:53 PM
beancooker's Avatar
Look at the post directly above yours. If you pull your intake to change your plugs you're
Old 07-27-2006, 01:16 PM
CCS2k1Max's Avatar
Up 2000, the owners manuals had a how-to for the plugs in the DIY maintenance section, straight from the FSM.
CCS2k1Max is offline
Old 07-27-2006, 01:23 PM
Mints33's Avatar
Thanks ccs2k1max - unfortunately my 2000 didn't come w/ a owners manual.
Mints33 is offline
Old 07-27-2006, 01:28 PM
CCS2k1Max's Avatar
The FAQ sticky is your friend.
http://www.nissan-techinfo.com/nissa...id=&dept_id=30
Old 07-27-2006, 04:44 PM
Mints33's Avatar
CCS2k1max - yes indeed, however the site you provided is out of the manuals, they're on backorder, plus they're a whopping 15 bucks! Guess I should've asked for one from Nissan years ago.
Mints33 is offline
Old 07-28-2006, 06:59 AM
CCS2k1Max's Avatar
Download the fugging file.
http://www.nissan-techinfo.com/nissa...p?dept%5Fid=37
Old 07-28-2006, 07:39 AM
MacGarnicle's Avatar
do a search - I forget who, but someone's hosted a site with FSM for all maxima models.. don't pay for it...
MacGarnicle is offline
Old 07-08-2008, 05:56 AM
meseville's Avatar
Ok. How about a revisit of changing the rear plugs on a 2000. I have been skinning my knuckles for 40 years on cars and my observation is that the intake is directly over the valve cover and must be removed. I suspect the even if the motor was totally removed from the car and mounted on an engine stand that the intake would still need to be removed. A mechanic at the Maxima dealership said the intake does not need to be removed, that I just need to use a long extension. Problem is I can not even see/feel the valve cover with the manifold on let alone see/feel any of the three coils. There does not appear that the manifold has any access holes through it. Maybe there are different intakes used on Maximas, some with access to the plugs and some with no access to the plugs. My quest is has anyone been successful in changing the rear plugs in a 2000 (not 1999, 2001, 2002, or any other year) Maxima without removing the intake? If so how is it done? Also, if it is possible, is it better (cost or effort wise) to just remove the intake?
Thanks, Bob
meseville is offline
Old 07-08-2008, 06:03 AM
ecrash's Avatar
All the FSM's are here in the download section.
http://www.phatg20.net/
ecrash is offline
Old 07-08-2008, 06:05 AM
Turbo'd Saab
DrunkieTheBear's Avatar
I have changed my spark plugs on the rear bank numerous times.
you should take a mirror and a flash light and look down the intake mani openings, it is possible to do them
DrunkieTheBear is offline
Old 07-08-2008, 06:18 AM
dot dot dot ...
NmexMAX's Avatar
The IM is designed to allow the changing of the rear spark plugs without having to remove it (the IM).
The same cannot be said about the 02+ IM.
NmexMAX is offline
Old 07-08-2008, 06:25 AM
'02_EMILBUS's Avatar
So it is impossible to change the plugs on my '02 w/o removing the upper IM? I guess the dealer does it the same way?
'02_EMILBUS is offline
Old 07-08-2008, 06:53 AM
hi-tek22's Avatar
Originally Posted by CCS2k1Max
you have to be a member genius, it wont work unless you sign up
GEEZ!
how complicated can it be to just Upload the FSM pdf to sendspace?
hi-tek22 is offline
Old 07-08-2008, 06:54 AM
Whitebread's Avatar
Unequivocally. You won't even be able to get a screw driver in there to get the coils out unless you were to drop the motor. Taking the upper plenum off isnt that difficult anyway. I did it last weekend in 2 hours. Dissconnect something like 5 or 6 vaccum lines, a few electrical connectors and a couple screws and it comes right off. Just remember to replace the gasket between the upper and lower pieces.
Whitebread is offline
Old 07-08-2008, 06:59 AM
hi-tek22's Avatar
how much does the dealer want for spark plugs?
and which ones are better...these Denso, or the NGK?
hi-tek22 is offline
Old 07-08-2008, 07:01 AM
dot dot dot ...
NmexMAX's Avatar
If you can turn a socket wrench, you could change the plugs on an 02+.
I paid ~ 8$/plug for my Iridiums and it takes an hour or 2 for the procedure.
NmexMAX is offline
Old 07-08-2008, 07:07 AM
I do not know. I wouldnt go to the dealer for anything unless its an OEM part.
Get plugs from the parts store. I'm going to do the plugs myself, its just seems more intense in the write-up. Give myself 3 hrs and I should be good? And when its done I'm also going to do the NWP Intake Spacers that are spoke highly of... No gasket needed then
Old 07-08-2008, 07:15 AM
dot dot dot ...
NmexMAX's Avatar
If I were you, I would do it all at once. (Spacers & Plugs).
NmexMAX is offline
Old 07-08-2008, 07:25 AM
hi-tek22's Avatar
ohhh, what fun.......where would one obtain the spacers, have there been more problems with the spacers, and do these replace the gaskets
hi-tek22 is offline
Old 07-08-2008, 07:28 AM
dot dot dot ...
NmexMAX's Avatar
There have been zero problems with the spacers. You can get them by contacting Aaron@NWP
http://www.nwpengineering.com/Phenolic_Spacers.html
Yes, they replace the gaskets.
NmexMAX is offline
Old 07-08-2008, 07:33 AM
jasonmax's Avatar
I would do valve covers, spacers, plugs
jasonmax is offline
Old 07-08-2008, 08:04 AM
Thats what was meant.
Why do people do valve covers (gaskets, I assume)? Do you have oil leaking through them?
Old 07-08-2008, 08:11 AM
jasonmax's Avatar
yeah, and almost every 5.5th gene has this problem.
jasonmax is offline
Old 07-08-2008, 08:21 AM
Whitebread's Avatar
+1
I've got oil all over the forward most bank.
Old 07-08-2008, 08:22 AM
dot dot dot ...
NmexMAX's Avatar
Mine doesn't yet, 105.5k / Mfg date 10/02.
NmexMAX is offline
Old 07-08-2008, 08:34 AM
jasonmax's Avatar
not noticeable in the front, take a look on the back.
jasonmax is offline
Old 07-08-2008, 08:36 AM
dot dot dot ...
NmexMAX's Avatar
Just recently did plugs / spacers and nothing was out of the norm back there.
NmexMAX is offline
Old 07-08-2008, 08:37 AM
hi-tek22's Avatar
ohhh, kool. Thanks bro
oh wait....is there one that works with the 01...if there isnt...and it doesn't look to be one
is there a substitute for the 00-01 3.0L 5th gens
hi-tek22 is offline
Quick Reply: How-To: Changing Spark Plugs on 5th Gen
