Bad Muffler at 64k miles? (plus annoying loud rattle)
Old Jul 21, 2006 | 05:35 AM
Mikeb120's Avatar
It looks like I have a hole in my muffler - its a 2k with 64k miles.
the Nissan site said the emmisions warranty is 2 yr 24k.
But i remember it was longer - would the muffler even be covered by the emmissions warranty?
How could it be bad so early -
My legend was 15 years old until I need one....
Anyways - there is a also a really annoying rattle coming from back there....any thoughts? Could that be the muffler as well ? (may be its loose?)
Thanks in advance
Mike
Old Jul 21, 2006 | 05:55 AM
sloppymax's Avatar
IMBOUTTOBUSTSOMEGHOSTS
i doubt they would consider the muffler an emissions component. im unfamiliar with the weather in MD, do they use alot of salt or slag on the road? most emissions components are covered 7yr/80k miles iirc but that is mandated by a federal means.
Old Jul 21, 2006 | 06:03 AM
Y2K2Driver's Avatar
You probably have the same problem myself and others have, the rear section of the exhaust system rusts out at the flange connecting to the B-pipe. The connection is just behind the passenger rear wheel if your interested in looking at it yourself. The rattling you are hearing is the pipe hitting some of the surrounding metal.
Old Jul 21, 2006 | 06:23 AM
MacGarnicle's Avatar
you're probably right.. which is insane. the whole exhaust sytem is a key component of emissions ratings...
I got a little rattle too.. whenever I go over a big bump I can hear something big down there shaking around. Definitely some exhaust pipe whose bracket came loose.. I'll have to go underneath and take a looksy
Old Jul 21, 2006 | 07:29 AM
tkostiuk4's Avatar
Happened to my 2k at 85,000 in the exact spot that Y2K mentioned. Now you can get a better muffler.
Old Jul 21, 2006 | 08:44 AM
Mikeb120's Avatar
The weather is typical of the northeast except not as much snow.
Hot summers, cold winters with snow. But last year we had almost nothing.
Its bad enough when this stuff happends - its worse when I hear my maxima brothers feeling the same pain.
At least - here is my chance to get something aftermarket... :-)
(that is if the wife lets).
Later.
Old Jul 21, 2006 | 09:24 AM
Trurida18's Avatar
ohhhh, ok gotcha
Old Jul 21, 2006 | 09:30 AM
trigger005's Avatar
o snap
****, i really think thats what i've been hearin all this time w/my car then
anyone have a PICTURE of this connection point?
Old Jul 21, 2006 | 02:47 PM
DAP's Avatar
DAP
Also be caerful when washing your car with the nose downhill. Water can enter the exhaust easily and sit. Not sure if our mufflers have weep holes or not.
Old Jul 21, 2006 | 04:26 PM
MIXXMAX's Avatar
Originally Posted by trigger005
o snap
This is what you're looking at--muffler connecting to the B-pipe. This is a pic of my Nissan stock muffler when it rusted out at the flange. Instead of a repair weld, I just ended up buying a new muffler and installled it myself. It was scary at first, but I installed it with no problems (being with the car on jackstands with the back end 2 feet up in the air ). Yeah, the early 5th gener's are proned to having their stock mufflers rusting out at the flanges. It seems to be a common problem for all of us. For all the noises that people may be experiencing, these noises could possibly come from the pipe hitting the rear beam axle. This could be caused from worned out rubber hangers holding up the muffler.
Old Jul 21, 2006 | 06:09 PM
trigger005's Avatar
the horror
the horror...
thx mixx, nice max
only way i can tell its a 2k is the grill
off topic:
where is your auto dimming mirror hooked up to?
Old Jul 21, 2006 | 06:27 PM
MIXXMAX's Avatar
off topic:
Thanks! Do you mean where it's wired to? I have a temp. sensor mounted inside the front bumper, and the mirror is tapped into the cigarette lighter circuit. (Sorry, for the off topic answer and hijacking. )
Old Jul 21, 2006 | 06:46 PM
frankd121's Avatar
Thanks in advance
Mike
It is definitely the flange that rusted out. Your exhaust will sound quite a bit louder, and it will rattle/clank/bang around when you go over some bumps. You can either get it welded together (prob around 30-40 bucks at your muffler shop) or upgrade to an aftermarket rear muffler section (or entire catback if you have the money).
My exhaust flange rusted out at around 80k; 64k sounds a little bit early.
Old Jul 21, 2006 | 07:55 PM
STyLeZ4o1's Avatar
Im having the same problem. 01 max with 58k miles. bit early wont ya say?
Old Jul 21, 2006 | 10:57 PM
Y2K2Driver's Avatar
Well, I have an '02 with 51k miles and mine rusted out, so I'm really early in having this problem. For now I don't mind the noise and just deal with it. Sounds cool really.
Old Jul 22, 2006 | 05:10 AM
xnyc's Avatar
Thanks in advance
Mike
i believe emissions warranty is applied only to cars that cant pass emissions within 2yr/24k miles after vehicle is purchased new. exhaust leak at the flange isnt covered because o2 only measure until after precats, therefore your MIL wont light up. the exhaust on these cars will always have certain rust issues due to us being in the NE where they use salt frequently. even the cars that come into the dealership 2004/2005 have problems with the bolts and surface rust. the rattle could be a worn hanger, rusted heatsheild, loose nut, etc. bring the car to your mechanic and ask him to check it out or even easier is to just jack the car up and take a look. shake the muffler and try to pinpoint where the sound is coming from.
Old Jul 22, 2006 | 06:48 PM
EastSideMaxima's Avatar
A swift Bimmer driver
Guys... this happened to my Maxi last month!
It's an '02 with 46k miles...
The harsh New England winter seasons claimed mine!
I got a RPM aftermarket muffler from Lou's Custom exhaust...
A week after that my heat shield got loose and it rattles every now and then! Oh well I am just gonna let it fall off!
Old Jul 22, 2006 | 06:52 PM
I know but it gets worse... I was going on a date and I was like... I gotta get it fixed up, cuz with my luck the muffler would fall off right after I picked her up! haha...
I was enjoyin the sound too, but it got worse after 2 days and I couldnt take the chance...
raywluce
Mar 10, 2025 09:34 AM
Matt93SE
May 24, 2019 02:58 PM
FlaMark
25
Aug 28, 2015 10:15 AM
hot04
Aug 24, 2015 07:07 AM
erictown
Aug 20, 2015 08:01 AM
