PO171 = Bad #5 injector ?
Old Jul 22, 2006 | 03:27 PM
doublea's Avatar
Hey guys, my cousin has a 2k maxima, his car has been pinging for a while
but for most under harder acceleration like when you want to pass another car. He was told by his local mechanic ( not a nissan dealer ) that the injector #5 need to be replace, he apparently plug some scanner and figure out it was the injector. Does anyone ever had that PO ? can you confirm if that's related to injector or what's the cure.
Thanks for helping.
Old Jul 22, 2006 | 06:31 PM
EastSideMaxima's Avatar
A swift Bimmer driver
http://forums.maxima.org/showpost.ph...&postcount=100
P0171 - Fuel Injection System Too Lean (Bank 1)
Old Jul 22, 2006 | 10:03 PM
oldngivout's Avatar
Willing to learn
Classic symptom of bad MAF sensor.
Get the new updated one at your dealer or online at www.courtesynissan.com.
Old Jul 23, 2006 | 12:43 PM
BewstAdd1ct's Avatar
why was cylinder 5 isolated?
if the issue is indeed in cylinder 5 and not the others, it isnt a MAF issue.
Old Jul 23, 2006 | 06:02 PM
AnalogKid2112's Avatar
Was going to replace MAF, now car won't start
Well, I got the PO171 code as well as pinging and almost stalling after start on my 2K5 SE. Searching the forums I have decided that the MAF is going bad. I changed the coils on the car myself so I figured I could do this one myself as well. Well, I started to take the MAF out today to look at it.
I disconnected the negative lead on the battery and then was going to work on the Torx screws holding the sensors only to realize my torx screwdrivers are not for the type of screws on the car. My brother says they are "security torx" screws. So I figured I'll run out and see if I can find some at AutoZone.
I re-connected the battery and then went to start the car; stupidly the key was in the on position when I connected the battery (that can't be good). It cranked and cranked but would not fire. Note that I hadn't done anything except disconnect and reconnect the battery; albeit with the switch ON.
I then searched on here again for a possible reason and found that if the security light stays on while cranking that the Nissan Vehicle Immobilizer System (NVIS/NATS) is locked. I went out to try to start it again and sure enough, the light is on when the car is in the ON position. So I tried the procedure here:
http://forums.maxima.org/showpost.ph...&postcount=101
to try to get it out of lock. No luck.
None of my keys work. I have disconnected the battery again, to see if it will start in the morning after being disconnected all night, but I am not hopeful. I fear that I may have blown the ECM or something by connecting the battery with the car ON .
HELP!!!
P.S. Sorry to hijack the thread, but I don't have 15 posts to start a new thread. This thread seemed closely related to my problem. I did get a PO171
Old Jul 23, 2006 | 07:18 PM
I hope the overnight trick works for you man!
I would hate to see you get hit with Diagnostic fees by the dealer!!!
Good luck pal!
My MAF recently blew (second time in 2 yrs) and I went through he!! to get everything done without breaking the bank!
Old Jul 24, 2006 | 04:38 AM
doublea's Avatar
I've driven the car yesterday and when you stomp on it the car ping and take forever to accelerate, I'm going to check at the local junckyard to see if I can buy a 2k MAF for cheap just to see if that cure my cousins problem.
Old Jul 24, 2006 | 11:06 AM
Well, the dealer can't get it out of lock mode to re-program the keys so they have to replace the IMMU (the immobilizer) at $330. They think that it was probably just coincidence that it failed now; not anything that I did.
Old Jul 24, 2006 | 05:00 PM
ouch!
Old Jul 30, 2006 | 06:08 AM
Well, they replaced the IMMU and reprogrammed my keys and I went ahead and had them replace the MAF ($264 including ECU reprogramming) and now the car has it's spirit back!
jmlee44
Oct 2, 2022 02:13 PM
aw11power
Oct 10, 2021 04:57 AM
chisam14
Nov 6, 2018 08:56 PM
RealityCheck
Oct 2, 2015 06:34 PM
Andy29
Sep 29, 2015 05:32 AM
