OBD II Code 0011
Old Jul 28, 2006 | 06:39 PM
Jules Maximus's Avatar
OBD II Code 0011
I have a SES light on and plugged my neighbor's scanner into the port on my 2003 Maxima and it gave me code 0011. Anyone know what this means? His manual didn't have that code in it.
My car is bone stock and has 55k miles on it.
Old Jul 28, 2006 | 07:23 PM
irish44j's Avatar
retired moderator
P0011 - IVT Control (Bank 1)
Posted a while back by link-master Puppetmaster:
The crankshaft position sensor and camshaft position sensor (data provded: engine speed), along with the engine coolant temp sensor (engine coolant temp) and speed sensor (vehicle speed) send inputs to the ECM for intake valve timing control, which controls the IVT control solenoid valve.
This mechanism hydraulically controls cam phases continuously with the fixed operating angle of the intake valve.
The ECM receives signals such as crankshaft position, camshaft position, engine speed, and engine coolant temperature. Then, the ECM sends ON/OFF pulse duty signals to the camshaft timing control valve depending on driving status. This makes it possible to control the shut/open timing of the intake valve to increase engine torque in low/mid speed range and output in high-speed range.
DTC detecting condition: There is a gap between angle of target and
phase-control angle degree.
Possible causes:
-Harness or connectors (Intake valve timing control solenoid
valve circuit is open or shorted.)
-Intake valve timing control solenoid valve
-Crankshaft position sensor (POS)
-Camshaft position sensor (PHASE)
-Accumulation of debris to the signal pick-up portion of the camshaft
Fail safe mode: The signal is not energized to the solenoid valve and the valve control does not function.
FYI, for future reference:
http://forums.maxima.org/showpost.ph...&postcount=100
Old Jul 28, 2006 | 10:48 PM
Dan5.5's Avatar
The crankshaft position sensor is on recall for some Maximas, just got mine replace for free by nissan, so if the code is for that, go to the stealership.
Old Jul 29, 2006 | 01:26 PM
EnemyKhan's Avatar
hmm, so if that's bank1 then what would it mean if your code is bank2?
Old Jul 29, 2006 | 04:40 PM
frankd121's Avatar
probably the camshaft sensor on the other bank of cylinders. (i believe bank 1 is closer to the front of the car and bank 2 is closer to the fire wall. correct me if i'm wrong).
Old Jul 31, 2006 | 05:52 PM
Nvious's Avatar
yea its the opposite. bank 1 is closer to the bulk head.
Old Aug 1, 2006 | 02:39 PM
Actually, I took it by a trusted local mechanic who hooked his shop scanner up to my car and it gave code 0011 and 0021. So, both banks are throwing a code. He reset the light and it hasn't been back on since. I'll call the stealership and see what they say but I'm not taking it there unless it is under warranty.
maxinout93
Oct 31, 2015 02:04 AM
Kyle Lee Cleveland
Sep 28, 2015 09:01 PM
dshinn
Sep 26, 2015 08:07 PM
zmcneely13
Sep 26, 2015 02:26 PM
