2002-2003 Fuel Filter Replacement Write Up.
Old Aug 5, 2006 | 06:19 PM
Orgullo's Avatar
$$ Ballin on a Budget $$
Tools you'll need to compelte this job.
1) Philips Head Screw Driver
2) Flat Head Screw Driver
3) Socket Wrench / 10mm Socket.
4) Need Nose Pliers
5) Latex Gloves
6) Absorbent Pad to soak up excess fuel.
7) Part Numbers for 2000 - 2003 Nissan Maxima.
2K0 / 2K1: Filter: 16400-2Y922 Seal / O-ring: 17342-01A00
2K2 / 2K3: Filter: 16400-2Y505 Seal / O-ring: 17342-01A00
I ordered mine from Everything Nissan. The filter is $10.49 and the O-ring is $6.76. Total came out to be $22.00 after shipping DHL, I got it in two days.
Link to Everything Nissan: http://www.everythingnissan.com/
MAKE SURE YOUR CAR HAS BEEN SITTING FOR AWHILE BEFORE DOING THIS REPLACEMENT, ALSO OPEN YOUR GAS DOOR LID TO HELP VENT THE TANK.
Remove back seat and expose the tank top. You'll use the 10mm Socket Wrench to remove these three screws or a phillips head Screw Driver.
After removing the three screws lift straight up on the plate gently, you'll see that it's plugged in. Remove it and set it aside.
Use your needle Nose Pliers to pinch the clips ends and pull toward you on the connection. Place an absorbent rag over the top before unclipping it because fuel will come out. Pull gently not to get fuel everywhere. After removing the connection take off the six screws that hold the plate in place.
Lift up on the plate and set it aside.
Gently pull up on the filter support and be aware of the fuel indicator on the left side. Completely remove this and set it on your absorbent cloth outside of the car.
Orgullo's Avatar
In order to get the filter off of the assembly you'll need the Flat Head Screw Driver.
The clips are marked. Use the flat head screwdriver as a wedge while gently pulling down. Once you've gotten the ledge cleared from the tab hold in place with your fingers and repeat on the other side while pulling down. Be careful how much pressure you put on the tabs they will snap. Just exert enough pressure to clear the ledge.
When you've managed to get all the ledges under then gently pull down. It's kind of snug do to the cone. You must be careful because there is a wire that is connected inside. Pull down but don't try to pull it off if you know what I mean.
After it is exposed you'll see the wire connection I was talking about. Unclip it and put it aside.
Old Aug 5, 2006 | 06:20 PM
Orgullo's Avatar
You will unclip the top part off the fuel filter the same way you did the bottom. You do not need to unsrew that "fuse plate" but be extremely careful when pulling it down. It is snug in place but It will come off. You can see how to when you're doing it.
Remove this clip by pushing out the sides and pulling it backwards. Put it aside.
You will remove this by just pulling straight up. Put it aside
This is what you are replacing.
Orgullo's Avatar
Out with the old in with the new.
I skipped putting it back together. Make sure you re-insert the the plug and the cap that holds it in place. Insert the filter into the top part until you hear the click. Make sure all four sides are connected & feed the wire through. Insert the bottom part and plug it back in to the wire you just fed through. Make sure all four clips are connected. That's that. Re-insert how you took it out.
Can't forget your O-Ring which is on the top of the tank top.
It's old so don't worry about using the screw driver.
Replace with the new one.
Now all you have to do is make sure you re-insert the Fuel Filter.
* Replace the black plate with the six screws.
* Reclip the line on the clip.
* Reconnect the top plates wire. Then Secure the top plate.
Donski
Old Aug 5, 2006 | 06:27 PM
SoonerFan's Avatar
Cletus
<----- wondering why this is needed when there is another fuel filter write up the thread right under this one.
Old Aug 5, 2006 | 06:43 PM
Orgullo's Avatar
Damn man you're pest, I was asked to do one for the 5.5. I guess I should have marked one more spot due to you.
Here is the reason why this needs to be replaced.
Old Aug 5, 2006 | 07:16 PM
Metal Maxima's Avatar
SHIFT_om nom nom nom
Fantastic write-up, man.
Old Aug 5, 2006 | 07:22 PM
Orgullo's Avatar
Graciassss.....
Old Aug 5, 2006 | 07:29 PM
LA02MAX's Avatar
great job on the write-up...it looks pretty difficult, but i'm going to tackle this at 60k. I'll bookmark this thread for future reference.
Old Aug 5, 2006 | 07:50 PM
Stardust's Avatar
F---ing Kangaroos
http://forums.maxima.org/showpost.ph...&postcount=166
Old Aug 5, 2006 | 08:01 PM
zagzig's Avatar
Thanks, Orgullo! This is now on my to-do list.
Suggestion: Add the part numbers for the fuel filter and O ring if there is one.
Old Aug 5, 2006 | 08:19 PM
Paulie Walnuts's Avatar
Yeah it does look tough to be honest, any MN orgers want to do it together????
Old Aug 5, 2006 | 08:20 PM
Where did you get the filter kit and what was the cost? I assume that this is dealer only?
Old Aug 5, 2006 | 10:32 PM
Stardust's Avatar
F---ing Kangaroos
~$20 for the filter and o-ring from Dave Burnette.
And no I won't tell you who he is and how to contact him.
Old Aug 6, 2006 | 05:13 AM
kvk2003max's Avatar
Excellent writeup. Thanks a lot. WIll try to do it next weekend. Need to order the parts before that.
Old Aug 6, 2006 | 06:45 AM
2002 Maxima SE's Avatar
This one is more detailed than the other one. Someone please sticky this!!!
Old Aug 6, 2006 | 10:07 AM
HotshotVQ35's Avatar
nice writeup. whats the recommended mileage to do this?
Old Aug 6, 2006 | 11:35 AM
Orgullo's Avatar
A few people recommend doing this maintenance every 30,000 miles. That also depends on what kind of petro your putting in your car. If you stick to the 97 then 30K should be fine.
Old Aug 6, 2006 | 12:53 PM
Puppetmaster's Avatar
I think you meant 91 or 93 octane gas and not 97 right?
Btw, write-up has been added to the Installation Instructions/How-To sticky.
Old Aug 6, 2006 | 01:13 PM
Orgullo's Avatar
Yeah 93 my fault...
Old Aug 6, 2006 | 01:14 PM
Orgullo's Avatar
That's what's up, thanx again.
Old Aug 6, 2006 | 01:29 PM
Part number for O-ring 2002 - 2003: 22401-27N67 comes up as a spark plug.
Part number for O-ring 2000-2001: 17342-01A00 shows up as the O-ring for all models 1995 - 2004.
Old Aug 6, 2006 | 02:05 PM
MacGarnicle's Avatar
how similar is this job for the 00/01
Old Aug 6, 2006 | 02:09 PM
Stardust's Avatar
F---ing Kangaroos
Try scrolling half way down the page and you would know
http://forums.maxima.org/showthread.php?t=314172
Old Aug 6, 2006 | 02:16 PM
I see..
Old Aug 6, 2006 | 02:27 PM
Stardust's Avatar
F---ing Kangaroos
I see..
Ok...
Old Aug 6, 2006 | 03:21 PM
vq356sp's Avatar
El Mas Noob Del Org.
Just out of curiosity, how many miles did you have when you chaged it? cause that looked dirty.
Old Aug 6, 2006 | 05:40 PM
Orgullo's Avatar
Didn't change it out until 90,000. Definitely should have done sooner from the looks of things.
Old Aug 6, 2006 | 08:22 PM
vq356sp's Avatar
Im def going to do this soon. BTW Nice write up..........
Old Aug 6, 2006 | 08:33 PM
jeepik's Avatar
any noticable power gains or loses
or maybe an improvement in gas milage???
Old Aug 7, 2006 | 05:54 AM
Orgullo's Avatar
As far as gas milage I just filled up and have to see.
Power gains, the throttle is much more responsive and I don't have any hesitation or drowning out before she kicks in. Awesome... I think it's definitely worth the maintenance.
Old Aug 7, 2006 | 05:55 AM
Orgullo's Avatar
Thanx to Metal & Stardust for the idea to run this how-to
Old Aug 7, 2006 | 07:34 AM
When using the screwdriver to undo the clips, did you push the male clip in or use the screwdriver as a wedge to separate the male clip from the female opening?
How "brittle" is the plastic? I've had issues in the past breaking these types of clips on sensors...just want to make sure I understand the technique. From your pictures, it appears you just pull the female part back with the screwdriver, slightly, to undo the male clip on the filter itself. Allowing it to slide past the female opening on the housing.
Old Aug 7, 2006 | 07:35 AM
BewstAdd1ct's Avatar
i think nissan recommended 100K for returnless filters, in initially it was lifetime, from what im told.
but again, just because it looks dirty, doesnt mean it needs it be changed.
Old Aug 7, 2006 | 07:43 AM
SoonerFan's Avatar
Cletus
what does type of gas have to do with anything? the octane level has nothing to do with how often you need to change the filter.
nissan still claims this is a non-maintenance item. that might just be because they dont want to deal with the pain of changing it.
Old Aug 7, 2006 | 09:48 AM
jeepik's Avatar
it has EVERYTHING to do with it,
cleanliness of the gas
regular has more particles in it then premium does, therefore it would clog the filter up quicker
Old Aug 7, 2006 | 10:07 AM
Orgullo's Avatar
Changed a little on the write up, hope it helps.
Old Aug 7, 2006 | 10:14 AM
Orgullo's Avatar
Regardless of what Nissan says the pics speak a thousand words.
The acceleration, overall response and idleling all run a lot smoother due to the change. If this maintenance doesn't seem worth it to you then by all means listen to what Nissan has to say.
Old Aug 7, 2006 | 10:59 AM
You might be confusing the quality of the gas with the octane level. The octane level is a measure of combustion (compression) ability and is not a measure of quality or cleanliness of gas.
Do you have any evidence to back up your claim that "regular has more particles in it then premium does"? If so, I'd be interested in seeing it.
