Parking light won't come on
Old Aug 6, 2006 | 06:05 PM
realmac's Avatar
Quick question. The small parking light (assuming they're halogens) on above my xenons on my 5.5th gen on the left side sometimes comes on and sometimes doesn't. I have the factory xenons. I can't really reproduce when it does vs doesn't. In the morning it seems to come on fine though. Anyone else experience that?
Old Aug 6, 2006 | 06:13 PM
MIXXMAX's Avatar
Check the bulb connection. It may be loose or something. Also, hook up a DMM to see the voltage. It should read 12V or so. If not, you may have a short in the wire. I would start from here, or maybe put in a new bulb. The old bulb may be going bad.
Old Aug 6, 2006 | 07:56 PM
realmac's Avatar
I slammed the hood shut and the light came back on.
Old Aug 6, 2006 | 08:14 PM
97Se5spd's Avatar
Loose connection most likely.
Old Aug 6, 2006 | 08:15 PM
n3985's Avatar
大陆弟弟
Maybe the bulb is loose? Try taking it out and putting it back in, or just get a new one.
Old Aug 7, 2006 | 06:05 AM
Orgullo's Avatar
$$ Ballin on a Budget $$
If you check the bulb the wires that are exposed sometimes get bent out when installing. Check to see if it is and bend them straight. If that isn't it check the voltage to see if you've got a short.
Old Sep 6, 2006 | 06:47 PM
realmac's Avatar
Now my front right fog light won't come on, though the lense is somewhat cracked. Hmm
sctludwig
Sep 1, 2022 01:32 PM
mvm062
Nov 30, 2020 09:00 AM
Maxima30
Sep 7, 2015 06:13 PM
MidnightMaxima_22
Sep 6, 2015 01:18 PM
