simple dome light question
anybody know which fuse it uses? i wanna wire some additional lights over the footwell for the driver and front passenger using the same type bulb in the dome light and so that they all turn on/off together. no neon lights for me.
any ideas? suggestion?
i wanted to know the same thing... YES neons for me
i think i might just wire it up straight to the dome light... doesnt seem like its a big deal...
tapping the step lights seems like a good idea. do i need to put in an in line fuse?
also, if i go with neons, don't they pull more amps?
Originally posted by punkdork
I didn't put in a fuse and I dunno how many amps they pull. They only come on when I open the doors so I'm not concerned.
Originally posted by areX
oh yeah, you had to take apart the doors, right? or is there a certain color wire that we can tap into?
No cause that doesn't turn on the step lights (I think).
but then you can do the roundabout way and wire to the dome lights directly from the roof. sounds a bit tedious, but doable, i'm sure.
hence, my original question: which fuse does it use? that way, wiring to the footwells would be much more direct and would enable the use of a fuse tap.
the reason i want to wire it to the dome light is because when u close the door when the car is off the dome light is still on.. and when u open the car using the key FOB the dome light goes on and when u lock it the dome light goes off... so i want my neons to do the same thing... right now they just go on when i turn the car on and off when i turn it off... i do have a switch though that i can turn it off when i get tired of them... what is really ****ing me off is that my neon on the right side is turning purple (originaly it was blue)
carguy96
20
Feb 6, 2021 06:21 AM
vingodine
45
May 21, 2016 12:46 PM
King_Ten_Ahead
Sep 30, 2015 04:27 PM
doobadoo
Aug 15, 2015 06:43 PM
kirkhilles
Aug 8, 2015 10:53 AM
gottem in my trunk already! LOL!
